Things I would like to change
Discussion in 'Gen 5 Prius Main Forum' started by PhilHarvey, Nov 21, 2025.
Tags:
  1. PhilHarvey
    PhilHarvey New Member
    2026 Prius Plug-in
    SE
    It could be great if...
    1. The seatbelt warning didn't sound while in park.
    2. The front object detection didn't sound while in reverse.
    3. The car didn't text me with window/ door unlocked warnings when I never exited the car.
    You would think these would all be common sense design decisions, and should be easy to implement via software.
    - Phil
    futurist, PrimeDan and dolphinsil like this.
  2. PriusCamper
    PriusCamper Senior Member
    12,991
    5,284
    Pacific Northwest, USA
    Toyota is a car company not a software company... They have always sucked at software and will always continue to suck at it. If they were smart they'd build it all on an open source platform and allow users to share updated code and use crowd sourcing to fix the problems that they're too cheap and inept to fix in-house.
    #2 PriusCamper, Nov 21, 2025
  3. kellogs
    kellogs New Member
    Manitowoc
    Sounds to me you nanny 'Yota is getting a bit on your nerves :)
  4. mva
    mva Member
    148
    88
    B.C. Canada
    2024 Prius Prime
    SE
    There seems to be lots of crazy sh*t!
    I just realized that the 20 minute “warm up” initiated by the APP, recycles the air, even with front and rear defog selected! It actually fogs up the windows!
    Good thing it’s efficient and very good looking
  5. kellogs
    kellogs New Member
    Manitowoc
    Individual pressure values for each wheel would have been nice too
    dolphinsil likes this.
  6. dolphinsil
    dolphinsil Junior Member
    2024 Prius Prime
    XSE
    In addition to your Dislikes for my beautiful 2024 xSE:
    1. Hydraulic trunk lift
    2. More illumination for the door controls and dash objects when Power is on.
    3. Another seat pocket behind driver seat.
    4. Adoption of 3rd party apps for maps.
    5. Stereo sound for FM Radio and Sirius wouldn't be fluctuating fixes.
  7. lostsoul
    lostsoul New Member
    US
    2026 Prius Plug-in
    Agreed, it was driving me crazy. Especially when I always walk away from the car "assuming the car will lock itself. How or why They don't have it or at least as an option to enable baffles me. All my cars had it for a long time.
    As for the texts I was getting allot for the same things. I normally leave my windows cracked open so it drove me crazy..
    -- If you open the Toyota app- tap on the person icon at top right- under your name you should see an "account" button- then you will see the "notification Setting". From there you will see tabs to shut off alerts to all of those things.
  8. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The gen5 has this.
    PrimeDan and futurist like this.
  9. Paul Gregory
    Paul Gregory Senior Member
    2,219
    588
    Alberta
    2024 Prius Prime
    XSE
    - Phil
  10. futurist
    futurist Member
    55
    100
    United States
    2024 Prius
    1 is a regulatory thing, makes sure the driver's henpecked into belting before the car can be put in gear. For same, dislike the fact the seatbelt warning becomes this ear-piercing shriek, if you've unbelted and cracked the door open to see the parking lines, as I park in a ridiculously-small space and need to hit marks to even get out of the car (n)
    2 is more of same. Let's the driver know if anything is within risk distance when in gear, no matter forward or rear; I know, dumb but read on.
    Toyota does indeed suck at s/w and has several generations, let's make that clear... but designs it w/ the legal dept having first crack. That's why things are so annoying -- low risk for responsible drivers... but even they like to sue the pants off a deep pocket like Toyota to fund their European ski vacation, reality bites (tho doing well for making lawsuits for themselves lately, re: Tacoma glass manual transmissions; Tundra turbo V6 casting sand not removed from proddy vehicles; leaking Camry HEV timing covers; our malfing, idiotic rear door 'lectric latches taking almost a year to fix, which should've been found in the R&D phase, etc.)
    Would like to add, my soapbox of slow-reacting / indifferent CAN-connected components, like the shifter and window lifts... plus
    a. when washing a 5th-gen, w/ morning dew loads of dirt runs from the roof back to the slot in front of the rear hatch glass. In an armpit of dustiness like where I live, this can literally form drifts of red dirt that has to go somewhere... so whilst at the pressure wash, squirt a few seconds of water in there -- this moves the dirt with enough add'l running water, to rinse it out where it exits, behind the bumper.
    Well problem with this, is the dirt may get rinsed out, but some of that water enters the hatch itself (esp if you pressure-wash surface dirt off it before hand-washing). So when you open it to see whether the dirt's all been rinsed out properly... a trickle of water dribbles out a spot on the side, next to the 'crossbar' above the PRIUS lettering and will continue to dribble out... for hours. The only fix I've found is to use my little high-speed blower fan to push whatever water's in there away from where it dribbles out, then shut the hatch. This allows that water to drip out and stop leaking, hatch-raised. But doesn't remove the little snot of water spat out from those rubber plugs under the rear of the hatch edge, when you shut it. Frustrating when you've prettied up your vehicle and want to drive away, but this dribble of water's ready to water-spot the second you ignore it and drive in the sun :cautious:
    PrimeDan likes this.
  11. futurist
    futurist Member
    55
    100
    United States
    2024 Prius
    Hoo boy, not this again... pays to check my post to see every update's actually made it to the thread :cautious:
    b. why isn't present mpg always displayed on the dash? Isn't that why you buy a Prius? Why is it hidden behind a side display, then as a toggle to it? Lots of room for it, even on that smartphone of a Busy Forks dash display...
    And just reminded of:
    c. why isn't the mode button on the shifter, or somewhere more haptically accessible? Best thing about Sport and Eco, is you can choose exactly when to enable, then switch back when you don't need it. The console location takes way too long to find, even after a year with my 5th-gen. Fix this please and retrofit the solution to past MYs...
    d. why on earth do literally 2 tire mfrs, make LE-sized tires? The Toyos are eraser-soft, the Bridgestones comically hard and bad in the wet. I don't mind warm weather bias for Toyo's performance since live in H a w a i ' i, so if they kept all perf the same but increased durometer to even 400 UTQG (500 would be preferable, but beggars ≠ choosers) would be peachy. Wish we non-bougey, non-rim-bending LE drivers had access to Michelin perf like XLE / Limited do... even as overpriced as they can be. But even the SK and Thai-made budget imprints of big Japanese brands are shying away from developing any 17" tires for us :rolleyes:
    EDIT: why the hell does this forum delete the abbrev'n for Hawai'i (HI), as well as the actual state name? May your dev staff get liver failure and itch to delirium :rolleyes:
    #11 futurist, Nov 25, 2025
  12. Mendel Leisk
    41,829
    Are you using an iPhone? More than one update (aka edit), Priuschat will show you stale content, not the previous update. Unless you refresh (reload) the page.
    Do the additional changes (without first doing a refresh), save, and you’ve wiped out the previous update.
    it’s been a Priuschat “feature” for well over a year now.
    futurist likes this.
  13. rjparker
    10,415
    6,521
    The Priuschat exclusive refresh flaw when using ios is not just second edits. Even though first edits work they may not display properly without a refresh.
    The Priuschat refresh issue also shows up on alerts that may be a day old until refreshed and sometimes in missing thread posts if not refreshed. The last two situations depend on leaving Priuschat active vs what happens if your have restarted Priuschat.
  14. Mendel Leisk
    41,829
    As-in log out and back in?
  15. rjparker
    10,415
    6,521
    Logout login is not necessary. Just leaving a Priuschat window open in the foreground or background is enough to show the alert or thread issue.
    futurist and Mendel Leisk like this.
