Adaptive Cruise Control and Road Sign Assist
Discussion in 'Gen 5 Prius Main Forum' started by notspam3, Nov 24, 2025.
  1. notspam3
    notspam3 Junior Member
    Toronto
    2024 Prius Prime
    XSE Premium
    Do the 2024 Gen 5 Prime XSE cars have the capability to automatically change/adapt the cruise control set speed to the posted speed limit signs using Road Sign Assist?
    I can't remember if this car has the capability and I shut it off, or does it only provide notification alerts if you are exceeding posted speed limits.
    I was driving a VW Golf rental car in Europe recently with this feature and I grew to like it.
  2. KMO
    KMO Senior Member
    1,965
    687
    Finland
    2023 Prius Prime
    Not fully automatically, but it can prompt you with an up or down arrow on the speed limit sign.
    While the prompt is there, a long press of the speed adjustment button in the corresponding direction will set to the speed limit (with a configurable fixed margin).
    Except it seems that's not present in North American cars. The "Dynamic Radar Cruise Control with Road Sign Assist" section and associated configuration options seem to be missing in your manual.
  3. BiomedO1
    3,665
    1,899
    SacTown, Ca
    In north America RSA simply warns it doesn't automatically adjust your speed. On my software version, the speed sign would be outlined in red if I'm traveling faster than posted. I'm sure there's other versions of the same software like KMO that has an up/down arrow displayed. Another issue would be if there is NO posted speed limit sign while entering a freeway/highway - is the car only going 30 mph on a roadway until it reaches a posted speed sign???? I should probably turn RSA off; since mine does this all the time - it doesn't stop blinking red until I reach a posted speed limit sign a few miles down the highway.:(:mad:o_O I wonder if the car is relaying this false information to my insurance company????:eek::rolleyes: I'd be flagged as a speeder and my rates would escalate based of that false intel.
    Be careful what you ask for........:whistle::censored:
  4. Paul Gregory
    Paul Gregory Senior Member
    2,163
    571
    Alberta
    2024 Prius Prime
    XSE
    I have a 2024, and the best you can do is set it to turn red when you are exceeding the speed limit.
    Best to be super alert at all times, because a few of the things you might expect the car should do.
    it does not do. For example, when someone is stopped up ahead, the car will give you a warning, but it doesn't always stop. You could easily run into them.
  5. fuzzy1
    10,481
    The version in my 2024 RAV4 can be set to different overages before outlining in red. Default is 1 mph over, other choices 2 or 3 mph over.
    Mine usually just blanks out when it understands that I changed roads.
    It also suffers from a stale database. In what was a construction zone several years ago, it occasionally flips to the work zone speeds that were posted there during active construction. It gets corrected each time it sees a new sign, then reverts to the stale database figure a few miles later. Work in that zone ceased before I bought this vehicle, so it never saw those slower work zone limits itself.
    I got the impression that if the driver efficiency scoring feature was turned on in mine, the results were reported to 'the Cloud'. After it dinged me for too-hard braking when I properly stopped for a last-moment yellow light, instead of running the light (there are a number of red light cameras around here), I shut that feature off.
  6. VelvetFoot
    VelvetFoot Active Member
    756
    268
    New York State
    2026 Prius
    Especially if you're watching a YouTube video on your mirrored phone. :)
    BiomedO1 likes this.
  7. BiomedO1
    3,665
    1,899
    SacTown, Ca
    When you believe in all the autopilot scam.
  8. Paul Gregory
    2,163
    571
    Alberta
    2024 Prius Prime
    XSE
    If I were brain-dead.
  9. VelvetFoot
    756
    268
    New York State
    2026 Prius
    That'd be after the crash.
  10. notspam3
    Toronto
    2024 Prius Prime
    XSE Premium
    In situations with no posted speed limit signs the rental car would accelerate to the default speed limit of 130kph;)
    What I liked is that the vehicle would automatically slow down when the electronic speed signs lowered the speed limit to 50kph. Hopefully no speed camera tickets are coming in the mail
  11. Paul Gregory
    2,163
    571
    Alberta
    2024 Prius Prime
    XSE
    60 years without an accident.
    Can you say that?
  12. fuzzy1
    10,481
    I think he was using future tense, not past tense.
  13. sclevine
    sclevine Active Member
    161
    155
    Northeast Florida
    2024 Prius
    I had a rental car with this feature last year in Europe and it was pretty awesome.
  14. Paul Gregory
    2,163
    571
    Alberta
    2024 Prius Prime
    XSE
    My dad started me driving at age 8. I think he believed it would make me a better driver.
    I think he was right.
    Tande likes this.
