Inner fender connectors
Discussion in 'Gen 4 Prius Main Forum' started by Frogerelli, Mar 13, 2022.
  1. Frogerelli
    Frogerelli Junior Member
    Fort Smith, Arkansas
    Do these unthread, do they pop out by prying, or some other way? The center has a slot like for a flat blade screwdriver, but they dont really turn. 20220313_175023.jpeg
    #1 Frogerelli, Mar 13, 2022
  2. Elektroingenieur
    2,515
    3,287
    Three Touring
    The “pin hold clips” (Toyota’s term) turn 90° and can then be removed. See the Repair Manual (more info), under:
    • Vehicle Exterior: Exterior Panels/Trim: Front Bumper: Removal
    • Vehicle Exterior: Wiper/Washer: Washer Motor: Removal
    (I realize you didn’t ask about the washer motor; that’s just the topic where Toyota put the illustrated steps for “Remove Front Fender Liner RH.”)
    Parts catalog references: Figure 53-02, Hood & Front Fender (click View More Images and select the second image); Figure 52-01, Front Bumper & Bumper Stay.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Turn them 90º counter clockwise with a small screwdriver to release. It's not threaded so takes slightly more force than you would think and makes a little click when it lets go.
  4. Greg L
    Greg L New Member
    Thank you -- cleared up a mystery for me!
