Able To Slightly Wiggle/Teeter Steering Wheel When Held At 3 And 9 & Pushed Back & Forth
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by fishingtimoteo, Nov 24, 2025.
  1. fishingtimoteo
    fishingtimoteo Junior Member
    Idaho
    Hello,
    Any experts that could tell me how to troubleshoot this? My 07 Prius has developed a little wiggle/teeter in the steering wheel (No turning of the steering wheel is involved). It doesn't matter if the car is off or on, driving or parked, when I hold the steering wheel at 3 and 9, and then push and pull, there is some movement/play. Is this a problem with the steering column?
    Any insight would be greatly appreciated. Thanks!
  2. PriusCamper
    PriusCamper Senior Member
    12,719
    5,143
    Pacific Northwest, USA
    I doubt it, but to be sure grab your front wheels and see if there's any play in them when car is off and trying to term them left and right... Also look for uneven tire wear. That's the other end of your steering rack and that's where the concerns will most likely be.
    But please clarify what you mean by "some play" in terms of measuring the amount of movement? Are you talking1/32nd of inch or more than that?
  3. fishingtimoteo
    Idaho
    Thanks for your reply. I just tested with the car off while in the garage. When I push (not turn) the steering wheel back and forth at 3 & 9, there is close to I would say 1/8 inch of play. and a small clunk noise at both sides (3 & 9). when driving, the car drives smoothly without any vibrations or noises when turning. It almost feels like upper part of the steering column is loose or something.
  4. JC91006
    JC91006 Senior Member
    16,766
    8,563
    It's probably just the nut that's holding the steering wheel to the steering column, needs to be torqued down.
  5. fishingtimoteo
    Idaho
    Thanks, do you happen to know how long of a job that would be? I'm sure I will get around to checking that, its just bad timing with the holidays coming.
  6. JC91006
    16,766
    8,563
    it takes 5 minutes or less to tighten a nut....if that's the problem.
  7. Tombukt2
    12,923
    2,322
    Go to another vehicle and take the assist system out of another car I can send pics thres a few things that could wear. Once on floor there's a bit to look over. You're talking about pulling up on the steering wheel and door pushing down not turning on its intended path .?
  8. ChapmanF
    18,115
    This nut, however, is behind the airbag that you must remove first, and that's after disconnecting the 12-volt battery in the back of the car and waiting 90 seconds for airbag backup power to drain before messing with the airbag.
    And you may then find that the nut is nice and secure and the play is in something else, like a worn bearing near the top of the column. But that's ok, this is probably the procedure you'd have to use to find that out anyway.
    By the way, for your 1/8 inch or so of play to be coming from the nut, the nut'll have to be pretty obviously loose, like daylight visible between the nut flange and the wheel and that daylight moving around as you wiggle the wheel.
    If you get there and the nut is sitting there tight and snug, don't just grab a bigger wrench and crank on it harder hoping that might be the problem. Look elsewhere nearby for the play.
    #8 ChapmanF, Nov 25, 2025 at 8:07 AM
    PriusCamper likes this.
