My recent experience with a blowout on the right rear tire
Discussion in 'Prius v Main Forum' started by Georgina Rudkus, Nov 25, 2025.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,508
    2,487
    Taylors, SC
    Since I acquired my 2012 Prius v new in that year, I've been contemplating on how to handle a tire blowout on that car.
    My first purchase was a full sized spar, in that on a freeway trip, I did not want to trust the donut spare that came with the car.
    Over the years, I carried a Harbor Freight aluminum flat top 1-1/2 ton racing jack. The original was bulky and weighed 23 pounds. Unfortunately, while Toyota provided a strap and instructions on how to hold down the full sized spare on top of the rear compartment platform, there was no way to tie down the Harbor Freight jack to keep it from flying in case of an accident.
    I had developed and made various versions of pinch weld adapters for the flat top jack over the past 12 plus years with good success.
    I was always concerned with the clearance under the pinch weld jacking point with a completely flat tire. That was the reason for the Harbor Freight low clearance racing jack.
    After all my three Harbor Freight racing jacks fail due to leakage of stuck internal valves, I acquired really cheap Walmart Hyper Tough two ton trolley jacks with the first being only less than $30. To my amazement, they weighed at least 5 pounds less than the lightest Harbor Freight aluminum jack with the latest version now available weighing 33 pounds plus. To defray rising cost, apparently, Harbor Freight has converted a lot of parts to steel.
    I have developed and made various versions of pinch weld adapters for the flat top jack over the past 12 plus years with good success.
    After all my three Harbor Freight racing jacks fail due to leakage or stuck internal valves, I acquired really cheap Walmart Hyper Tough two ton trolley jacks with the first being only less than $30. To my amazement, they weighed at least 5 pounds less than the lightest Harbor Freight aluminum jack with the latest version now available weighing 33 pounds plus. To defray rising costs, apparently, Harbor Freight has converted a lot of parts to steel.
    To my surprise, the Walmart Hyper Tough jack is amazingly easy to carry in one hand with the top handle and stores well completely and safely under the hinged panel of the cargo area foam insert.
    My only concern was that the lowered height of the jack was over four inches and might not fit under the pinch weld with a flat tire and the stupid little cut swivet top of the jack.
    On that account I carried a low rise ramp and made a flat top adapter for tTo my surprise, the Walmart Hyper Tough jack is amazingly easy to carry in one hand with the top handle and stores well completely and safely under the hinged panel of the cargo area foam insert.
    On that account I carried a low rise ramp and made a flat top adapter for the jack.
    Monday before last, I visited the local Lowe's and when I left the parking lot, I heard a flapping noise as I drove off. As I went to the parking lot of the Home Depot across the street, I looked at all the tires and found the right rear tire to be totally flat.
    Using the Ryobi inflator, I could not get the pressure to go above 5.5 pounds. That told me that the tire needed to be changed.
    I was happy when I found that the flat top converted Walmart jack had over an inch of clearance under the pinch weld with the car lowered by the flat tire. Having more than enough clearance, I slid the pinch weld adapter under the flat top of the jack, jacked up the car and changed the tire.
    I no longer need to carry the low rise ramp.
    I have uploaded photos of the flat top converted jack and the pinch weld adapter as I used it.
    flat top jack mod.jpg installed wo rubber.jpg on trolley jack lowered.jpg on trolley jack raised 2.jpg on trolley jack raised.jpg
  2. Mendel Leisk
    41,850
    The one out-and-about flat I had with our '10, I set the parking brake, got out the scissor jack and lug nut wrench, slightly loosened the nuts, raised the corner with the flat, swapped to the spare, drove home, plug repaired the flat.
  3. rjparker
    10,438
    6,545
    First, the original post has many duplicated paragraphs.
    I have had flats on my 2012 v - in fact I had a complete rear tire flat when the car was less than a week old while parked at my wife's workplace drop off circle. This was in November 2011 with my 2012 v.
    I tried calling Toyota's roadside assistance but the dealer had not registered my car. At the time I did not have USAA insurance with free roadside which has been used several times since.
    Regardless, after the Nov 2011 failure I pulled out the standard scissor jack. It worked fine as did the compact spare even at minimum freeway speeds.
    Since then I have lifted the car with the scissor jack closer to the wheel than specified to allow a high lift hydraulic jack to get it further up. I have used a hydraulic jack at the recommended front driver's pinch weld to lift the whole side of the v, allowing quick rotations. After the first set of tires, I have the tire store rotate them free.
    Bottom line, after 14 years and 340,000 miles the pinch welds have held up fine, no adapters necessary and sometimes jacked up forward or rear of the recommended locations. Obviously I would never get under it without heavy duty jack stands (typically the entire front end requiring the hydraulic jack to place) and I keep the jack positioned capable of taking the weight if the stands were to bend (the harbor freight trick).
    #3 rjparker, Nov 25, 2025
  4. Mendel Leisk
    41,850
    Worth noting: the stock scissor jack just cups around that outstanding seam; the bearing point is inboard of the seam, on the car body. At least for gen 3, there is no apparent reinforcement, either on the seam or the bearing point. The aforementioned one time I used the scissor jack was on the rear, and even being the lighter end of the car, the bearing point indented slightly.
    Another thought: a floor jack is intended to be used on concrete; gravel road side, or even asphalt, might get challenging.
    One accessory worth taking along is a pair of wheel chocks. They're noted in the owner's manual, but not supplied. Also, a small square of 3/4" plywood, to provide a stable base for the scissor jack on soft earth.
  5. BiomedO1
    4,059
    2,136
    SacTown, Ca
    If all we're talking about is the occasional flat - running with a pint size floor jack always bouncing around in you trunk, seems to be a bit of over-kill.
    I've gotten a flat on my driveway. I'll use my floor jack, simply because I'm too lazy to unpack and pack everything back up. My power tools are also readily available; so why not use them.
    Just my 2-cents.....
  6. Georgina Rudkus
    3,508
    2,487
    Taylors, SC
    The jack does not bounce around in the cargo area. It fits conveniently in the foam lined well under the top cargo floor.
    In the Prius v, the entire top floor panel and two long awkward slender foam storage pockets have to be removed to access the donut spare and scissors jack.
    In my case, the full sized spare is held to the top of the cargo area flat floor with the Toyota supplied full sized tire retention strap.
    The full size spare is retained forward enough that the hinged part of the floor can be swing up to quickly pull out the jack from the foam lined well.
    Anyone owning a Prius v might want to move the scissors jack and tire changing tools to the readily accessible foam well and the donut spare to and strap it to the top of the cargo compartment platform in n a position behind the rear seat.
    On grass or gravel, I have a square piece of plywood to place under the of the jack for full support.
    #6 Georgina Rudkus, Nov 25, 2025
  7. Georgina Rudkus
    3,508
    2,487
    Taylors, SC
    Here's a photo showing how the flat top converted Walmart Hyper Tough two ton jack can be stored under the rear floor panel of the Prius v with all the necessary tire changing tools.
    Uberdriver2710 and Air_Boss like this.
  8. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Been using this smaller jack on motorcycles for several decades but it started to lose pressure long ago so I got another one from HF this spring.
    Yes, they will fit under with a flat. Pics from 7 years ago with Honda Clarity that had a perfect sub-trunk space for it and other safety items:
    Georgina Rudkus likes this.
  9. Georgina Rudkus
    3,508
    2,487
    Taylors, SC
