Engine Code P1121 with check engine light
Discussion in 'Gen 2 Prius Main Forum' started by Rick 432, Nov 25, 2025 at 3:01 PM.
  1. Rick 432
    Rick 432 Member
    105
    26
    I have a 07 Prius that just displayed check engine light. Code found was P1121 which is a coolant flow malfunction according to research I did. Checked coolant for inverter and it is moving very nicely. Inverter is very hot! Information I found says it is a coolant inverter valve. Also, prior to this issue when I stopped the car the sound from the engine (pump antifreeze/coolant into storage tank) was odd. Snapping sounds and not the usual buzzing sound. Anyone every change one of these flow valves? Thanks guys.
  2. ChapmanF
    18,092
    Brian1954 likes this.
  3. PriusCamper
    PriusCamper Senior Member
    12,708
    5,135
    Pacific Northwest, USA
    While I may agree checking the inverter cooling system isn't perfect, it also isn't that far off when you're new to it all... Why not just tell OP that the sensor in the 3-way coolant valve has gone bad and it happens in almost every really old gen2 Prius and it's fairly easy to replace and there's lots of cheap after market ones that runs just as good as OEM: http://www.ebay.com/itm/394097566363 And you might also help OP by letting them know they can go years without fixing this problem and it won't be any concern other than a slight loss in MPG when engine is running cold.
  4. Rick 432
    Rick 432 Member
    105
    26
    Just looking at threads and what is on the internet. Having written that, my inverter was hot after I drove the car today. Maybe I have multiple issues. I will look at that coolant control valve. I have never replaced one of those so I will see what happens. Thanks for the information.
