Occasional death rattle on startup – but not during day – chances engine dies during day?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Twoos, Nov 20, 2025.
  1. Twoos
    Twoos New Member
    Illinois
    My question is: Assuming my engine does not destroy itself during the death rattle in the morning, how likely is it to do so during the day?
    This might be an odd question because I am wondering when (time of day) my engine is going to fail as opposed to how to diagnose / fix something. My 2011 Prius with 198k miles sometimes has a minor death rattle on cold start in the morning. It is a very minor rattle and resolves itself within 5 seconds. Car runs fine for the rest of the day, until the next morning, when the cycle repeats. Yes, it appears to be burning coolant, so there is likely a head gasket issue. It takes a little over a year for the coolant to go from full to low (supposedly .5 liters) which in my mind is a very small leak. For purposes of this question, just assume there is a small head gasket leak.
    The death rattle only occurs in the morning. My typical drive cycle is that my drive to work is long enough that the engine comes up to normal temperature. Some days I take a short trip after the engine has cooled to get lunch, where the engine does not get up to temp. Other days I don’t get lunch so the engine stays cool for the full work day until I go home. My drive home gets the engine back up to normal temp. The only time the death rattle ever occurs is in the morning after an overnight cold soak.
    If the engine blows up in my driveway at home, I am perfectly ok with that. I will just get in my other car and go about my day. If the engine blows up while I am at work/driving, it is a much bigger problem. First, I park in an underground parking garage in a high rise building in Chicago. Getting a tow truck in there is difficult and expensive. Second, if my engine blows up in the underground garage, they are going to be upset about 5 quarts of oil being dumped on their clean garage floor. I am sure they will charge me a huge cleanup/environmental fee. Third, if the engine blows up while I am driving on the road, I may block traffic on a major highway, inconveniencing an uncountable number of people.
    To anticipate some questions / comments:
    1. I am aware of the multiple techniques for confirming head gasket leaks. The majority involve some level of disassembly of the engine compartment (wipers, cowl, etc.). It is November and I am in the Chicagoland area. It is cold and my only place to work on the vehicle is outside. I am not doing that until next May at earliest
    2. I don’t want to pay for repairs. Local Toyota dealer quoted $5176.00 for head gasket replacement. Another chain shop was $3600.00+. I can’t imagine an independent mechanic would be less than $2500.00. I feel I have gotten my full value out of this car and don’t want to put more money into it.
    3. Some are going to say the prices quoted for repair are too high. Although I might agree with that statement, these are the prices where I live. I don’t necessarily live where you live.
  2. ASRDogman
    ASRDogman Senior Member
    7,675
    3,945
    Don't you already have a thread for this?
    NO ONE, I repeat, NO ONE can tell you when the head gasket will completely fail, NO ONE!
    You are tempting fate, and other drivers safety.
    You don't want to pay the money to fix it. Fine, that is your choice.
    Then sell it as is, and tell potential buyers the head gasket failed.
    Get what you can for it and move on to a non hybrid vehicle. Then deal with the issues for
    that vehicle.
  3. bisco
    52,130
    it's not always the head gasket. it doesn't sound that bad to me, i would just drive it.
    the engine is not going to 'blow up', if there is adequate oil in it.
    if you can't sleep due to worry, sell it
    Cornvalue likes this.
  4. Mendel Leisk
    41,706
    Yeah, Toyota reliability.
    Nobody can make your mind up. When I’m in such a quandary, wether to hold or fold, I’ll do nothing, for a good while, sleep on it.
    my 2 cents: when you’re ready, sell it, with full disclosure, as a mechanic’s special. Should fetch a grand or two.
  5. AzusaPrius
    AzusaPrius Senior Member
    2,214
    927
    I will tell you how it feels and about how long it will last.
    The engine will not explode but will sound and feel like it has no gas.
    Depending on the leak in the headgasket you can drive it for 50k miles if you use Kseal carefully.
    I drove mine until it couldnt and then replaced the whole engine with a rebuilt one with updated pistons/rings.
    You can also just call Gasket Masters and replace the gasket before more damage happens.
  6. Twoos
    Twoos New Member
    Illinois
    Thank you all for you responses!
    I completely understand that no one can tell me for sure when it will fail. I am looking for probability based on symptoms. From the searches I have done, the most common scenario is that the death rattle in the morning gets progressively worse over multiple days/weeks, then the engine completely dies one morning. I am sure it has happened, but I have not come across a post where the engine started up with a minor rattle in the morning, then destroyed itself 8 hours later. Also, I don't understand why you say I am risking other driver's safety. You said that no one can tell when a head gasket will completely fail (which can happen in a brand new car), so that means every vehicle on the road is risking other driver's safety? Aside from the possible issue of a piston being shot out of the engine block onto the road, how is a blown head gasket putting other driver's safety in any more risk than someone running out of gas? Also, why would I move onto a non-hybrid (which I have not)? This is an ICE only problem, hybrid has nothing to do with it.
    Looking back on my original post, I think I might not have been clear. I am going to drive this Prius until it has a failure that renders the car undriveable (see reason why below). I understand the head gasket issue will cause the car to eventually die. I would just prefer that it die as close to my house (as opposed to 30 miles away at work) as possible. Who knows what the failure will be though? I am still on the original 15 year old traction battery. There is also the ABS booster failure that has a $4k repair that I keep hearing about. Maybe those happen first? What should be understood is that I am not going to get anything preemptively fixed.
    I am not going to use any of these types of seal products because I don't want to screw the next guy down the line. Maybe the traction battery dies first and I sell the car to an informed buyer. He may want to legit fix the engine. Dealing with that sealant stuff is going to make his job so much harder, if not impossible. I don't want that kind of karma.
    Multiple commenters have suggested selling with full disclosure. I wish I could do this, but I can't (see below). It is way too easy to hide a Gen 3 Prius blown head gasket if the car still moves. Car flippers are out there and they are garbage people (see my reason below). I am going to drive this vehicle until it dies in such a way that it is very clear you will need to do major repairs before selling.
    TL:DR version of see below
    Early this year I decided to replace my 22 year old Nissan Pathfinder with a 2025 RAV4 Hybrid. The dealer didn’t want the Pathy as a trade-in and said to just sell it myself on Marketplace. I went home and wrote a two paragraph description that fully disclosed every single thing that I knew was wrong with it. I even finished my description by saying that if you don’t have the skills to do the repair work yourself, I would strongly advise against buying the vehicle because mechanic’s costs are going to eat you alive. The car had less than 100k miles and the drivetrain ran like it was brand new. I needed it gone within two weeks, so I priced it at the real low end of the Blue Book value.
    A guy came to see the vehicle Saturday afternoon saying he was looking for a car for his daughter. For even more full disclosure, I reiterated verbally everything I knew that was wrong. Two of the things (ABS system and front shocks) were things that I considered safety concerns that should really be addressed before you let your kid drive it.
    Sunday morning (less than 18 hours later) I look on Marketplace and see my car up for sale again (this time at the high end of the Blue Book value). You know what was missing? My two paragraph description of everything wrong with the car. I felt so bad that this dude was trying to flip this car onto some unsuspecting person who might just see the low mileage for a 22 year old car and think it was great. The only things that assuaged my guilt were that 1) it is very difficult to hide ABS faults by resetting the codes because unlike emissions faults, they come back right away and 2) a quick test drive / pushing down on the front end would easily reveal the shock problem.
    A small Prius head gasket leak is just too easy to hide. Keep the coolant full and don’t let the potential buyer hear the first start after an overnight cold soak. No seller is going to let you dissemble half the engine compartment to get a scope in the cylinder.
  7. bisco
    52,130
    so where does that leave us?
  8. ASRDogman
    7,675
    3,945
    :( The likely hood of a NEW vehicle failing is slim. Yes, it does happen, but not likely because of
    NEW parts. ya ya ya, new parts do fail, but it's rare compared to old parts.
    You seem to really wants to know exactly when your car will fail. Only God know, so maybe ask him
    and perhaps he will tell you.
    The best you can do is guess. Based on what I've read on here from the people who have experience it
    anywhere from today until 5 years from now. 5 miles to 150,000 miles.
    If the engine throws a rod and the engine locks, it's likely the car will stop suddenly and quickly or you will
    lose control of the vehicle and won't be able to safely pull off the road.
    Depending on how fast everyone is driving, someone could run into the back of your car. And then someone into
    the back of them, and others avoiding them could crash into others trying to avoid them.....
    Hope you have very good insurance.
    Anytime anyone drives a vehicle with knows issues that could make it fail abnormally is risking the safety
    of other drivers.
    The earlier you fix it, the less damage is risked and likely will cost you less to repair it.
    You put your car up for sale and made know the issues. That is rare. But someone bought it, then decided
    to resell it without disclosing the issues. That is NOT on you. You could post something about it letting
    others know. Maybe his daughter didn't like it and so he
    decided to sell it. Or they found something for less.
    What you don't know is, did he fix the issues? And they still decided they didn't like it so they sold it?
    People would cry who put dogs up for sale on craigslist. Or gave them away. They saw the same dog for
    sale for twice the amount. Then they would cry about it. Welcome to America!
    They purchased something for a low price and resold it for a profit. Just because they weren't smart enough
    to figure it out is no reason to be mad at them. Be mad at themselves.
    Remember, it's your car, do with it as you want.
  9. rjparker
    10,299
    6,443
    It can and will become undrivable on the road. Especially if your plan is to drive it to that point. I have seen them get 200 yards down the road before clanking to a stop requiring a wait for the tow truck.
    This is a perfect situation for the "Hey Walt" video
    #9 rjparker, Nov 24, 2025
  10. bisco
    52,130
    kid looks like a mass murderer :cool:
  11. Twoos
    Twoos New Member
    Illinois
    I am going to stop driving the Prius to work. I had been driving it (30 mile commute to downtown Chicago) because it gets slightly better mileage than the RAV4 Hybrid and, because it is smaller, it is slightly easier to maneuver in the city. The RAV4 will now become my commuting car.
    I will continue to drive the Prius locally until some catastrophic failure, whatever that may be. This means within a 5 mile radius of the house, with speeds generally under 40 mph, and with pretty low traffic density. I feel that even if the worst case scenario as outlined by ASRDogman happens, at such low speeds I should be able to handle it with minimal safety concerns for myself and others. If it dies and comes to a sudden stop and someone hits me from behind, that is a classic case of following too closely. I am not worried about it. These are basically the same rules I had for the last 7 years on that 22 year old Pathfinder.
    I understand how bad the damage can get once the engine hydro locks. I think I am not properly conveying how minor what I am calling the morning “death rattle” is. I bet if I posted a video of it, half the people would say it is not a leaking head gasket but is just how a Gen 3 Prius engine with 200k miles normally sounds. It took over a year for the coolant to go from the full line to the low line. I figured the worst (i.e. most expensive) possible cause for this is the head gasket, so just assume that is what it is.
  12. bisco
    52,130
    sounds like a plan, all the best!
  13. Twoos
    Twoos New Member
    Illinois
    Thanks! I will report back when it dies and let you all know what caused it to die. Hopefully this means you don't hear from me for years and/or thousands of miles:)
  14. Mendel Leisk
    41,706
    That elicited a wry smile here.
  15. Twoos
    Twoos New Member
    Illinois
    Well, I guess I jinxed myself with the "years and/or thousands of miles" part, because here I am less than two months later :). Technically, it is not dead yet. Dashboard is lit up like a Christmas tree and is throwing a P0A80 (replace traction battery) code. I am glad I didn't premptively get the head gasket done. I am also glad I didn't try to use sealant on the head gasket in case I sell it and the next owner ends up needing to fix the head gasket.
    Not sure what I am going to do with the vehicle yet. But if I do decide to sell, with full disclosure of the battery issue, I will have no guilt. A dead traction battery, unlike a head gasket issue, is something that a car flipper cannot hide.
    So, I am now off to research the P0A80 code to decide what I want to do next. Thanks to all of you who took the time to comment and provide your insights.
    CR94 likes this.
