Solar Charging Roof Not Working!
Discussion in 'Gen 5 Prius Main Forum' started by maiki, Oct 30, 2025.
  1. Gokhan
    Gokhan Senior Member
    6,154
    2,433
    Paramount CA
    As I said in my previous post, if he gets the BM2 battery monitor, he will find out of it is working or not, as the solar panel will start charging the 12-V battery.
    51,851
    is there a parasitic loss on the hybrid battery when the car is off?
  3. bisco
    51,851
    does the prime charge the 12v or hybrid battery?
  4. hill
    8,794
    ..... And - only if it's a cloudless day at that minute of the day,
    AND not extremely hot as panels easily lose 15%-20% of their efficiency.
    AND - That highest Angle of the Sun At best Is Less than an hour before & less than an hour afterwards. Azimuth before & after perfectconditions being lower than perfectly ideal.
  5. Gokhan
    6,154
    2,433
    Paramount CA
    Of course not, as that would eventually brick the car and ruin the traction battery.
    Both.
  6. bisco
    51,851
    hard to believe it won't add a tenth of a mile over the course of several sunny days
  7. bisco
    51,851
    the solar roof?
  8. Gokhan
    6,154
    2,433
    Paramount CA
    Not sure what exactly you are asking.
  9. bisco
    51,851
    does the gen5 prime solar roof charge the 12v and hybrid batteries when off
  10. Gokhan
    6,154
    2,433
    Paramount CA
    Yes, both.
  11. bisco
    51,851
    the 12 volt drain must be uge
  12. Gokhan
    6,154
    2,433
    Paramount CA
    I doubt it. I doubt the solar panel turns on the main DC–DC converter to aggressively charge the 12-V battery at around 14.1 V.
    In the Gen 4 Prius Prime PHEV, there is an auxiliary DC–DC converter in the AC charger that keeps the 12-V battery at float at around 13.0 V. This doesn’t really charge the 12-V battery but prevents it from draining during AC charging. It is turned off when the traction-battery SOC reaches 100%. The main DC–DC converter is not turned on during AC charging. I am guessing something similar is done by the solar-panel computer and it has an auxiliary DC–DC converter in it to provide a small power to the 12-V system. Note that in Gen 5, the main DC–DC converter is turned on during AC charging.
    Again, all these answers can be provided by getting a BM2 battery monitor.
    #32 Gokhan, Oct 31, 2025
  13. Hammersmith
    Hammersmith Senior Member
    2,305
    2,320
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    As some others have said, just take it in. They'll plug in their computer and see if it's thrown any codes. If it hasn't, there are troubleshooting steps in the repair manual that they will follow to track down any problems.
    Just note that it won't be particularly quick. Unless it's a huge dealership, it's likely they'll only have a couple/few techs that are qualified to do the work(probably only Certified Tech, Master Certified Tech, or Master Diagnostic Tech). Depending how busy they are, they might not have a spot for you for awhile. Then, they'll only be able to do the testing between 11am and 2pm on sunny or mostly sunny days(that's part of the repair manual procedure). So it might take them a few days to track down the problem if it doesn't show itself right away.
    otatrant likes this.
  14. Starship_Enterprius
    Starship_Enterprius Active Member
    329
    162
    Ottawa, Ontario
    2018 Prius Prime
    i also had the 2010 version and even with snow on the roof here in Canada, i'd still occasionally hear a momentary sound from my fan.
  15. ATalkingRock
    ATalkingRock Junior Member
    2023 Prius
    XLE AWD-e
    Has anyone taken it to a dealer to see if there is a fix?
    My solar roof has worked as intended until a couple months ago, which i attributed to just winter and cloudy weather. But today was warm (50 degrees and sunny). After being out all day, there was 0watts generated at all, however upon turning it on it was then starting to read 50-60w from the sunlight almost indicating the solar roof wasnt charging at all when the car was off. [​IMG]
    As you can see in this image (only focus on the today mark, as my car was ina parking garage prior days), there was 0 watts gained today but currently when car was on 52 watts are being generated.
    Gokhan likes this.
  16. Gokhan
    6,154
    2,433
    Paramount CA
    Your best friend is probably the owner’s manual. It could give a clue on what is happening. It lists many scenarios that can affect solar charging.
