What does rear bumper applique look like on this gen?
Discussion in 'Gen 5 Prius Main Forum' started by JB88, Oct 26, 2023.
  1. Blackat
    Blackat Active Member
    478
    339
    Colorado
    2023 Prius
    Limited AWD-e
    I have a moving blanket thjat I cut to fit and flip it over the back bumper area when I load and unload things.
    daisy555 likes this.
  2. kev604
    kev604 Junior Member
    56
    49
    Vancouver, BC Canada
    2026 Prius Plug-in
    Raising this thread from the dead. Has anybody applied the Rear Bumper Appliqué themselves? Pretty easy? Thinking of getting this as my wife is already doing a number on the top of the bumper.
  3. otatrant
    otatrant Active Member
    348
    211
    San Francisco
    2023 Prius Prime
    XSE Premium
    I have installed this rear bumper applique.
    It was the first one of the paint protection film pieces I installed and came out the worst. What made my later installations on the hood, door cups and side mirrors go smoother was using two solutions referenced in this youtube 3M video. One a slip solution with baby shampoo in a ratio of 2mL of baby shampoo in 1000 mL of water. The second solution a tack solution made of of 150 mL of 99% Isopropyl Alcohol and 850 mL water. The key I found to doing a better job is a little bit of tack solution on parts you want to stick like a corner of the film and a lot of slip solution on the remainder of the film on both sides and a good squeegee to squeegee out the air bubbles.
    There is also a Toyota Japan 08178-47040 for rear bumper applique that you would have to import from some site like impex. It looks a little better in the sense that it has two pieces whereas the USA version is one piece. Similar in price. Attached is a pdf version of the Japanese version instructions translated by google translate.
    VelvetFoot likes this.
  4. VelvetFoot
    VelvetFoot Active Member
    1,209
    472
    New York State
    2026 Prius
    The Infotainment screen protector is the farthest I'll go! :)
    (I'm not counting the seat covers, lol.)
  5. Hammersmith
    Hammersmith Senior Member
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Boy, I like that Japanese one better than the US one I've got(port installed). A place called JDMYamato has it for about $20 + $45 S/H. Seems legit enough that I might give it a shot. Going to think on it a few days.
    otatrant and Gokhan like this.
  6. Mendel Leisk
    41,898
    With a lot of these hatch threshold applique images posted, I'm thinking "uh, where is it?". On our '10:
    otatrant likes this.
  7. kev604
    56
    49
    2026 Prius Plug-in
    Okay thanks. I'm also going to use a hairdryer I think some heat will also help it adhere I'll report back.
  8. Blackat
    478
    339
    Colorado
    2023 Prius
    Limited AWD-e
    Looks like WeatherTech offers a protector. Black though and pretty stout
  9. kev604
    56
    49
    2026 Prius Plug-in
    Saw that. The piece looks solid but it actually looks like the OEM bumper applique has better coverage as it wraps around also I think I prefer the cleaner clear look.
  10. kev604
    56
    49
    2026 Prius Plug-in
    Got the OE rear bumper applique at the dealer last week when I was getting the wheels done. Will report back after I put it on.
    Blackat and otatrant like this.
  11. kev604
    56
    49
    2026 Prius Plug-in
    Got the OE rear bumper applique done on the weekend. Just used car wash soap in a bottle as lubricant. Used a hairdryer while I squeegee to help it set faster. Spent a good amount of time squeegee and drying. Not perfect but turned out okay.
    Overall I would say if your careful I would pass on it the coverage of the applique isn't even that good. I do like the fact it is clear though so it doesn't take away from the aesthetic and I do like how it is applied onto the bumper versus the use of something like 3M tape. For myself my wife is loading stuff daily for work so every little bit helps.
    otatrant and VelvetFoot like this.
