check hybrid system light came on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bobby515, Nov 25, 2025.
  1. bobby515
    bobby515 Member
    181
    phila
    On my way home today, my check hybrid system light came on. I hooked my my basic cheap Bluetooth scanner.
    I was wondering what codes came up as I was on the way home. I hit clear. They went away. The Car is safely parked.
    Seems like the engine had a smell and was hotter than normal. 240k on it, new OEM water pump. My inverter flow was never able to see if it was running. I think maybe the pump could be bad. I want to get a more advanced code reader tool to check the car out. Any idea. Rebuilt 6 months 6-month-old. 100% don't think it's the battery, as it charges and discharges properly to me.
    Any advice. And what's a basic better black friday code reader to get? Going to load test the regular battery.
    I think it's an inverter or pump..just guessing..new headgasket 1 year..
    I put 60k on the car in 2 years...
    If the inverter is bad, is eBay bad for a used one? Thanks in advance
  2. ChapmanF
    18,601
    There are about 200 reasons for "check hybrid system", so if you want to guess you have to be very good at guessing.
  3. bobby515
    bobby515 Member
    181
    phila
    Is thier a scanner tool i could be to.narrow it down.??
    Any ideas where to start. I have tools and experience. Just the hybrid is difficult for me.
  4. bobby515
    bobby515 Member
    181
    phila
    Question on a gen 3. Invertor plastic tank. With the car running is the fluid supposed to be flowing while car is running. Mine never has. .
  5. ChapmanF
    18,601
    Gen 1 and gen 2 used a single-speed pump that's always on whenever the car is IG ON or READY.
    Gen 3 has a pump that runs at variable speed as needed for cooling. So it's harder to check just by looking at fluid in the reservoir.
    As there are around 200 different trouble codes that can give the warning you've got, best next step is to read the trouble code(s). Then you'll know whether the pump even has anything to do with the code(s) present.
  6. bobby515
    bobby515 Member
    181
    phila
    Can you recommend a black friday code reader that will give me more info or the type I need. I got the basic cheap $15 Bluetooth one.
  7. ChapmanF
    18,601
    Autel AP200 gets pretty good talk around here. I have one and it does the job. I wish it did not require signing in to their cloud (thus requiring an internet connection) every week or so. After you do that, it will keep working for a week or so even if you're on the road with no internet, but I'm sure some day I'll leave on a road trip without remembering to sign in first, and then need it on the side of the road somewhere and it'll say "signin needed". (n)
    Other than that it's pretty great.
    Brian1954 and PriusCamper like this.
  8. Brian1954
    Brian1954 Senior Member
    2,425
    973
    South Central PA, USA
    The Autel AP200 is my recommendation. It can communicate with all 18 or so ECUs in a Gen 3 Prius. What that means is that it is capable of reading all the trouble codes, not just some of them. It can do everything that the Toyota Techstream software can do. The price right now on Amazon is $49.99 + tax. I own this model, and I also have Techstream.
    The following two linked threads are good reading.
    https://priuschat.com/index.php?posts/3248209
    Read post #1 and then scroll down to post #37 in this thread, https://priuschat.com/index.php?posts/3246758
  9. bobby515
    bobby515 Member
    181
    phila
    I posted on here yesterday about the hybrid check engine light on. With a basic code reader, i removed it car was ok. Came on again I reset it.
    I brought a rebuilt battery, it went bad in only... they game me another one.
    While being stumped all night. Thinking maybe inverter or something else and ordering a better scan tool, I remembered i got the Dr. Pruis app.
    I did test today to see if the battery was ok. Test is bad, 33.3% capacity left it says at the end of life, weak block 8.
    Before buying a rebuilt battery, I got some used cells on eBay and installed them. Was better. But later on, I treated myself to a rebuilt battery.
    My question is. I will put in pictures at the bottom.
    Can I last a few weeks like this?
    I can take out and battery apart. Should I just replace 2 cells in #8 block? Happy Thanksgiving, thanks for reading.
    you guys think i will get stuck..i can put cells in myself sunday..advice
  10. ChapmanF
    18,601
    Have you found out why the check hybrid light is on, yet, or are you just assuming that because of the Dr Prius battery life report, that must be what the car wans to tell you about?
    You haven't included any screenshot where Dr Prius shows you trouble codes. I believe it is able to show some trouble codes. It can only show codes from a small fraction of the ECUs in the car, and it miscategorizes some, but it may well show you the codes that apply here.
  11. bobby515
    bobby515 Member
    181
    phila
  12. Tideland Prius
    16,624
    Threads merged
  13. bobby515
    bobby515 Member
    181
    phila
    Thanks for fixing this. The senior treats people like we're stupid 200 things can be wrong. Why say such a hi number.
    I worked my career customization of cars.
    My buddy of 45 years is an EV tech at Cadillac. Since 1979. Yes 79. His only job. Some here rough you up. I know 1 thing for sure my car will be fixed really soon. Thanks for the help.
  14. bobby515
    bobby515 Member
    181
    phila
    Come on 200 things. Ok . You know, i'm a forum member on an uber forum with over a million subs. I share my experience and wealth and knowledge with a lot of people.Some of you guys with the knowledge like you above seems like you don't really want to help at all.And with so much advertisement on this forum, maybe I need to move to a different one.This is the only prius forum.
    There's no urgency to help nobody the one man that posts all the diagrams and online files from canada.He seems really nice.
  15. ChapmanF
    18,601
    The list of trouble codes in a gen 3 that can turn that light on appears in compact form in the "DIAGNOSTIC TROUBLE CODE CHART" for the Hybrid Vehicle Control System.
    If you don't have a subscription to TIS, you can look around for an oldish PDF copy of the 2010 Repair Manual that floats around on the net. If you find it, that compact list of the codes will be on pages 3917 through 3952 (inclusive, so that's 36 pages).
    The number of codes on each of those pages varies. The first page has just 5, the next page 12, the next page 7, the next two pages 4 each, the page after that 7 again, and so on.
    My estimate of "around 200" would call for the average number of codes per page to be around 5.6.
    How exaggerated or unrealistic do you think my estimate is?
    He is. If you're interested, he might post pages 3917 through 3952 of the manual for you, and you can go through and count the trouble codes one by one, which I admittedly didn't do, then come back and tell me how far off I was when I said "around 200".
    #15 ChapmanF, Nov 26, 2025
    bobby515 likes this.
  16. bobby515
    bobby515 Member
    181
    phila
    You're making it sound like building a rocket. Ok, take to Toyota. Pay $300 to look at. Fix what they say is wrong. Pay for reprogramming if someone needs it done. or borrow my foreign neighbors $2500 scanner he dont know how to use and deal with his albaninan headache. poor english he has. no matter what whats wrong is not major. my car earns me $5000 a month. i just dont have any hybrid shops i ever used.
  17. Brian1954
    2,425
    973
    In another one of your threads that you created on this forum, you wrote:
    Wait until you receive the Autel AP200 scanner that you said you ordered. Follow the instructions and install the proper Autel app on your phone. Create an Autel online account. Pick Toyota as the brand of car that you want for free. Download the additional app for the Toyota brand. Open the Autel app on your phone and log in to your newly created Autel account. Install the Autel AP200 Bluetooth dongle into the OBD2 port of the car. Turn the car on and use the app to do a full scan of the car. The app will scan all 22 or so ECUs in the car and find all the diagnostic trouble codes the car has. Come back and post all the current codes that are found.
    #17 Brian1954, Nov 27, 2025
  18. bobby515
    bobby515 Member
    181
    phila
    Hey thanks so much . I have the scanner now amazon. Will do this afternoon and report back. You are a big help. I know my battery has a weak cell block #8. I got 2 cells coming to install. I believe it's not just my battery.Some strange region, I think it's the inverter cooler pump or the inverter.But it's no big deal.I'll figure it out.I'll do a scan, get the results.And I'll post them, thanks for your time.The scanner was on sale.I think back friday.I think it was like ten dollars off.Fifty bucks or so
  19. ChapmanF
    18,601
    Am I making it sound that way, or are you trying to make me sound that way?
    My usual approach when the car has codes is (a) read the codes so I'm not guessing what it's telling me, (b) look up what the codes mean, (c) use the troubleshooting steps to pin down the cause, (d) fix it, (e) move ahead with my day.
    Was there somebody else telling you go to Toyota and build a rocket, that you're mixing up with me?
    Brian1954 likes this.
