4th gen Engine swap
Discussion in 'Gen 3 Prius Technical Discussion' started by Ata, Nov 18, 2025.
  1. Ata
    Ata New Member
    St louis
    Swapped the engine with a 4th gen engine
    Now it says hybrid malfunctioning and throws
    Poa40 and poa41 error
    Anybody has any idea whats up with it?
  2. Tombukt2
    13,444
    2,418
    Looks like the Gear wrench software. . I got a bunch of this changing from federal to JDM gen3 swap . The JDM throttle body didn't seem to be happy and a miserably failing HV battery. Once dealt with . All worked for a short while . Everything's plugged up safety plug in and all that ,?
  3. ASRDogman
    ASRDogman Senior Member
    7,827
    3,986
    Everyone has issues when the put the different engine in. If you search prius chat you can find many
    threads about the issues and how to possibly get a fix for them.
  4. Mendel Leisk
    41,911
    What was the miles, and the reason for doing the swap?
  5. Farkhod
    Farkhod Junior Member
    Missouri
    Three Touring
    Hi Mendel it’s Frank I did for him swapping engine for now this fault is gone p0a40/p0a41 but we have new issue there is no coolant circulation ( I did several times swapping gen4 to gen 3 but this is first ever times happening with me )
    Vehicle get almost overheating thermostat is not opening I swapped old engine thermostat housing also swapped water pump but something nothing is changed is there could be engine defect? Again all houses lined up connected no leaking coolant but no circulation flowing
  6. Rational_lnsanity
    Rational_lnsanity New Member
    St. Louis
    Have you found a solution. I just did the swap on mine and have the same issue. Heater works normally, but the car idles at 203 and overheats on the road. New thermostat. Water pump was new on the old engine before it overheated.
