Is replacing TPMS transmitters worth it? I think NOT
Discussion in 'Prius v Main Forum' started by Georgina Rudkus, Nov 27, 2025.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,508
    2,487
    Taylors, SC
    Recently I purchased a new set of tires at Discount Tire.
    They wanted $240 to replace the 14 year old TPMS transmitters; one of which had a dead battery and the others which will soon expire.
    Over the pas 14 years, they have only detected a low tire pressure warning no more than 10 times, mostly due to reduced tire pressure form sub freezing temperatures.
    The local Toyota dealer quoted $550.
    I decided no and just disabled the TPMS warning light.
    I wanted them to remove the old transmitters and replace them with standard rubber valves.
    They refused, claiming that Federal law requires that they install TPMS transmitters.
    So they reinstalled the dead or soʻn to be dead ones.
  2. Brian1954
    Brian1954 Senior Member
    2,386
    958
    South Central PA, USA
    I purchased $40 aftermarket TPMS transmitters on Amazon and took them to my local tire store when I purchased new tires for my Gen 3 Prius one month ago. The morning of the tire change, I used Techstream to upload the new transmitter ID numbers into the ECU. The tire store installed the new transmitters for free. I drove away from the tire store, and within 100 yards, the TPMS light went out. To me, it was worth the $40 to have a functional TPMS in the car for the next 5 to 10 years.
    Air_Boss likes this.
  3. Mendel Leisk
    41,850
    With our snow tires on rims I opted for conventional valves, no sensors, and just let the warning light do its thing. Every spring I swap back to all seasons with the stock rims and TPMS sensors, light goes out. When they eventually fail, life goes on.
    Canada has no regulations mandating TPMS by the way. In the States I believe it can mean an inspection fail, in some locations.
  4. VelvetFoot
    VelvetFoot Active Member
    1,162
    459
    New York State
    2026 Prius
    I've got to loo
    That's all well and good, with a little piece of electrical tape if it's too annoying, but the new models have a mini mutipurpose screen where this wouldn't be practical.
  5. Georgina Rudkus
    3,508
    2,487
    Taylors, SC
    Just a small jumper wire, when placed correctly will turn off the light on the dash.
  6. Mendel Leisk
    41,850
    Like a banner notice obscuring other info? Can you enlarge on that?
    #6 Mendel Leisk, Nov 27, 2025
  7. rjparker
    10,438
    6,545
    Exactly what I did several years ago. They work fine.
  8. VelvetFoot
    1,162
    459
    New York State
    2026 Prius
    If it's not telling you your TPMS system is out, it telling you to watch out when you open your door, what your next turn will be, it's getting near freezing, etc, etc. It's basically the left side of the gauge cluster, or whatever the Toyota name for it is (meter something or other?).
  9. ChapmanF
    18,486
    I tend to push back a little on that conventional wisdom that when one goes the others are right around the corner.
    The first of my TPMS transmitters to go went 3 years and change ago (natural causes, battery conked out). Next was 2 years and change after the first (hastened to its grave by an incautious tire-machine operator). It's been another year and a bit since then, with no further attrition yet.
    While it's a truism that the four units have the same MTTF and were installed by the factory at the same time, it's also true that the mean is the central point of a probability distribution that can be rather wide and squat.
    I like to also think about whether there's a natural economy of scale to doing more at once. You wouldn't replace piston rings one piston at a time because so much disassembly work is common to them all. But changing 4 TPMS transmitters is just pretty much four times the work of changing one, so I might just do the one, unless combining it with some other reason to have all the tires off.
  10. notspam3
    notspam3 Member
    88
    45
    Toronto
    2024 Prius Prime
    XSE Premium
    My other Toyota requires a dealership visit to reprogram the TPMS whenever I switch to winter wheels. I said FU Toyota I'm not paying you to change a software setting because you won't remember more than 4 tires. I don't mind driving with my TPMS light flashing all winter.
    Thankfully the Gen5 Prime lets me store two sets of wheels and switch between them without a dealer visit. The other miracle is the Gen5 Prime actually has an oil life reminder...the Prius V was the first car we had in the past 30 years that didn't have oil life monitoring.
    frodoz737 and Mendel Leisk like this.
  11. Mendel Leisk
    41,850
    I got snow tires mounted on Corolla rims through a dealership in 2010: mechanic came out and asked if I wanted tpms, while shaking his head. I didn't need convincing, but it was comical.
  12. Prodigyplace
    12,654
    11,825
    Central Virginia
    My 2025 Camry does that and attempts to display the tire pressures but my window tint apparently blocks the TPMS signal to the dash. *sigh* It is like this image but obscures part of the digital combo meter.
  13. Prodigyplace
    12,654
    11,825
    Central Virginia
    You are in a different country than most of us. For now, at least. LOL
  14. bisco
    52,337
    I like having the pressures available without checking the tyres, so I would pay to do them as they die
  15. Prodigyplace
    12,654
    11,825
    Central Virginia
    We wanted the window tint due to having to get the black interior.
  16. VelvetFoot
    1,162
    459
    New York State
    2026 Prius
    That's a thing? I hadn't heard of it. There's a metallic component to the tint film?
  17. Prodigyplace
    12,654
    11,825
    Central Virginia
    It is a ceramic tint but it is mentioned in the manual.I made the assumption my ceramic tint fit into their description rather than a system failure.
    The warming system works but does not display the individual tire pressures.
  18. Winston Smith
    Winston Smith Active Member
    390
    268
    OH
    2024 Prius
    LE AWD-e
    I'm impressed that they lasted 14 years.
    Same here. If you know the light isn't cause for alarm, it isn't distracting at all.
  19. Mendel Leisk
    41,850
    I do value the benefits of TPMS, but the clunky implementation by Toyota makes it very awkward with two set of wheels. I hear that's been rectified finally, with gen 5.
  20. Air_Boss
    Air_Boss Senior Member
    4,219
    1,188
    New Yawk
    If TPMS signals are transiting the locations of window tints, there are much, much bigger fish to fry.
