Recharging HV battery after car sat for 2+ years?
Discussion in 'Generation 1 Prius Discussion' started by AlsoJakob, Nov 16, 2025.
  1. AlsoJakob
    AlsoJakob New Member
    Portland, OR
    2001 Prius
    I’ve got my hands on a 2001 Prius that a coworker had sitting for 2+ years after the cat was stolen. I’m trying to recharge/recondition the HV battery with a CQ3 hobby charger and so far it has been going well.
    Modules 1-22 bounced back beautifully with 5000+mAh discharges and holding steady at ~8v but 23-38 are all reading under 1v at the module. Can these be recharged/reconditioned or should I just replace them?
  2. dolj
    dolj Senior Member
    8,434
    4,285
    Wellington, New Zealand
    I think the only way is to try and see. I would charge up to 7.2 V at 325 mA, rest it for 5 - 10 mins, then do your regular charging regime.
    It will either work or it won't. You haven't lost anything trying.
    AlsoJakob likes this.
  3. AlsoJakob
    Portland, OR
    2001 Prius
    Update: replaced the weak modules and balanced the pack. Dr. Prius shows a clean bill of health :)
    dolj likes this.
