Parking brake question
Discussion in 'Gen 5 Prius Technical Discussion' started by HamiltonPrius, Nov 29, 2025.
  1. HamiltonPrius
    HamiltonPrius Member
    210
    98
    Parts unknown in Virginia
    2026 Prius
    What is the purpose of the parking brake button? When you put the car in park it automatically engages the parking brake. When you put the car in drive the parking brake automatically disengages.
    I’m trying to think of a use for the parking brake button…..I can’t. What am I missing?
  2. KMO
    KMO Senior Member
    2,011
    734
    Finland
    2023 Prius Prime
    The automatic parking brake can be disabled, in which case it is the manual control.
    And I suspect manual control is a legal requirement.
    broderp and Trollbait like this.
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,271
    879
    Monument, Colorado USA
    Yes I think if you hold it down for 3-5 seconds it will turn off the automatic feature.
    Another puzzling thing, in my wife's 2024 Corolla Hybrid is the "Hold" button....I know it's for use like when you're at a stop light and don't want to hold down the brake pedal (or in a drive through) BUT why does Toyota put TWO "HOLD" symbols on the dash?? That's puzzling
  4. HamiltonPrius
    210
    98
    2026 Prius
    Is there a setting that can turn off the auto parking brake? But if you mean the auto parking brake can be turned off by clicking the parking brake that’s true but why would anyone do that?
  5. HamiltonPrius
    210
    98
    2026 Prius
    So what you are saying is if I put the car in park and the auto parking brakes engages I can hold the parking brake down for 3-5 seconds and the next time in put the car in park the auto parking brake will not engage?
  6. ColoradoBoo
    1,271
    879
    Yes...did you try it? It's 17 degrees this morning so I'm not going out to try it in my wife's car! (Or get her Owner's Manual to look it up!)
  7. Mendel Leisk
    41,913
    Before I raise the front of any car, I like to tap heavy, rubber wheel chocks fore and aft of each rear wheel, and then release the parking brake. That way, when the front goes up, the rear axle is free to hinge, but pinned, not fighting the parking brake. One time for having the parking brake off.
    I dislike those electronic parking brakes, find them a PITA, both setting and releasing. Seems like they're a convenience for manufacturers, not so much for anyone else. Definitely complicates rear brake jobs too.
  8. VelvetFoot
    VelvetFoot Active Member
    1,231
    480
    New York State
    2026 Prius
    The manual also mentions cold weather operation. I have it set to Auto and probably will keep it that way over the winter. I live for thrills.
  9. Hammersmith
    Hammersmith Senior Member
    2,326
    2,378
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I had an interesting morning. I'm not sure if the automatic parking brake was a symptom or a cause.
    Because of bad weather, my car has been mostly sitting for the last week. A few short trips in between for groceries and the like. The temps have also dropped from the 40s-50s down to the 10s-20s this week. I went to fill up the car this morning and it started fine. Drove to the station(1.3mi) and popped the fuel door. Car gave a single long beep while I was at the pump, but I ignored it in the moment. Filled, closed it up, and went in to pay.
    Came back out, got in, and the car was in Power On mode, not Ready. Tried to start it, and it said EPB Activation Stopped Incompletely, as well as other errors. I tried manually cycling the parking brake, but it didn't work and I eventually got a low battery message and then later a lot of flashing lights(which usually confirms a low 12V batt). I eventually got a jump and the car worked properly from then on(drove it 100mi round trip at highway speeds so the batt should be recharged - I'll probably throw a tender on for awhile to be certain).
    So the question is whether the EPB malfunctioned due to the cold and drained the 12V battery while attempting and failing to actuate because it froze up, or whether the battery was barely hanging on and the EPB activation when I stopped for fuel was just enough to put it over the edge so it couldn't restart? It's a pretty new battery(maybe 8 or 9 months old), but the EPB has also handled over two winters by this point(one of them very, very cold) without having any problems. Neither seems to be the smoking gun.
    The coincidental thing is that I'm convinced my old NoCo 1000A jump pack is mostly toast, so it's out of the car while I wait for my new Gooloo 4000A jump pack with preheating tech to get here this coming week. So the one time I needed a jump pack is the one time I didn't have one. lol
    Gokhan and VelvetFoot like this.
  10. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    My door locks are tied to the parking brake. I think that's the default from the factory.
    If I "park" the doors unlock. I find the large "P" button easier to use to unlock the doors.
  11. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    The explanation in the Owner's Manual.
    broderp likes this.
  12. HamiltonPrius
    210
    98
    2026 Prius
    Didn’t work for me. It only disengaged the parking that the one time.
  13. Gokhan
    Gokhan Senior Member
    6,548
    2,613
    Paramount CA
    No, it is not your electronic parking brake. It is your battery. Was it you who was torturing his battery so that it could fail and he could get a free replacement under warranty? I don’t remember.
    I highly recommend the Uplus AGM battery sold on Amazon I have a dedicated thread on. I also highly recommend connecting a Noco Genius every few months to fully charge the battery, as the car will never fully charge the battery otherwise due to its buggy BMS. You might want to do it more frequently if you don’t drive much. Since you had a full drain, your battery has degraded and you might want to consider replacing it.
  14. VelvetFoot
    1,231
    480
    New York State
    2026 Prius
  15. Xse
    Xse Member
    74
    31
    Brighton Ontario Canada
    2024 Prius Prime
    XSE Premium
    My epb has been off when parked in my garage so the brakes don’t bind
    I manually on and off the epb myself like regular handbrake when I go places
    If you decide to take it off and manual activate yourself
    Simple hold epb for a few seconds info will appear on the screen
    Voila
  16. VelvetFoot
    1,231
    480
    New York State
    2026 Prius
    I might turn it off for the winter.
    broderp likes this.
  17. Mendel Leisk
    41,913
    We’re around 3k kms a year, on our ‘10: it LIVES on a smart charger regimen, near-constantly.
    Gokhan likes this.
  18. Xse
    Xse Member
    74
    31
    2024 Prius Prime
    XSE Premium
    Both my Miata/Prime also live on a battery plus tender since 94
    Again plugged in daily
    The Prius’s battery CCA is (a joke)as low as my Miata which is in hibernation right now
    They may have over engineered the Prius forgetting the 12 Volt battery
    if you live on a fairly level ground I would deactivate it (bind, seize who knows)
    On a hill make sure it’s activated or your car might disappear
    Gokhan likes this.
  19. Mendel Leisk
    41,913
    Lowish CCA can improve the amp hours; the latter is important as well, I believe higher numbers improve the battery's ability to bounce back from a drain?
    Xse likes this.
  20. ChapmanF
    18,556
    I don't know that it's so much higher amp hour numbers making the battery more robust under deep discharge: more directly, it's higher CCA numbers making it less robust.
    Higher CCA is achieved by increasing the surface area for the electrochemical reaction—by using more plates and making them thinner. Those thinner plates take more damage every time the battery is deeply discharged. So, for an application like a Prius, which doesn't need a lot of cranking amps, it's advantageous to choose a battery whose CCA figure isn't crazy high.
    Tande and Mendel Leisk like this.
