How to anticipate timing of battery replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatorback, Nov 29, 2025 at 4:26 PM.
  1. gatorback
    gatorback New Member
    27
    A 2010 Prius (90K Miles) was inherited: seems to be well maintained.
    I would like to know how I can electrically measure (or otherwise) the battery performance so I can anticipate / time the hybrid battery replacement.
    QUESTIONS
    1) What is the lifespan of the battery in terms of shelf life / miles (cycles)?
    2) How to measure battery cycles?
    3) Have I provided enough information to anticipate a battery replacement? If not what else is needed?
    I would be interested in hearing from others that have:
    1) performed DIY battery replacement (link to battery please)
    2) replaced battery with a better spec (more charge / faster charge rate / etc.)
    3) replaced OEM equivalent at significantly better cost
    This video prompted me to anticipating battery replacement:
  2. Brian1954
    Brian1954 Senior Member
    2,172
    850
    South Central PA, USA
    Use the Dr Prius app to get an idea of the health of the hybrid battery. Search for the website to learn more.
  3. gatorback
    27
    Thanks for the recommendation. Any "lessons-learned" from using the Dr. Prius App?
  4. bisco
    51,871
    it could last forever or throw a code tomorrow, there's no way to know.
    more importantly, you should look into the head gasket/egr problem, and the brake actuator. then decide how you want to proceed.
  5. Brian1954
    2,172
    850
    I have learned that the hybrid battery in my 2011 Prius is in good condition for its age. I have been using Hybrid Auotomotive's Prolong charger and discharger, once per year, for the last three years to recondition the battery.
