How to anticipate timing of battery replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatorback, Nov 29, 2025.
  1. gatorback
    gatorback Junior Member
    58
    A 2010 Prius (90K Miles) was inherited: seems to be well maintained.
    I would like to know how I can electrically measure (or otherwise) the battery performance so I can anticipate / time the hybrid battery replacement.
    QUESTIONS
    1) What is the lifespan of the battery in terms of shelf life / miles (cycles)?
    2) How to measure battery cycles?
    3) Have I provided enough information to anticipate a battery replacement? If not what else is needed?
    I would be interested in hearing from others that have:
    1) performed DIY battery replacement (link to battery please)
    2) replaced battery with a better spec (more charge / faster charge rate / etc.)
    3) replaced OEM equivalent at significantly better cost
    This video prompted me to anticipating battery replacement:
  2. Brian1954
    Brian1954 Senior Member
    2,408
    964
    South Central PA, USA
    Use the Dr Prius app to get an idea of the health of the hybrid battery. Search for the website to learn more.
  3. gatorback
    58
    Thanks for the recommendation. Any "lessons-learned" from using the Dr. Prius App?
  4. bisco
    52,393
    it could last forever or throw a code tomorrow, there's no way to know.
    more importantly, you should look into the head gasket/egr problem, and the brake actuator. then decide how you want to proceed.
    gatorback likes this.
  5. Brian1954
    2,408
    964
    I have learned that the hybrid battery in my 2011 Prius is in good condition for its age. I have been using Hybrid Automotive's Prolong charger and discharger, once per year, for the last four years to recondition the battery.
    #5 Brian1954, Nov 29, 2025
  6. gatorback
    58
    I'd like to understand the electrochemical issue that the HA-Prolong Charger / Discharger and the approach it takes. Is there anywhere that discuss the theory in-depth?
  7. Brian1954
    2,408
    964
    Search Hybrid Automotive and read the material on their website.
