TPM Programing Questions?
Discussion in 'Gen 3 Prius Technical Discussion' started by Markee, Oct 17, 2025.
  1. ASRDogman
    ASRDogman Senior Member
    7,788
    3,975
    Seems I read somewhere that is you remove all 4 sensors from the system, you won't
    get the light. Since there are no sensors to report.
    Not sure if this is true or not though.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,508
    2,487
    Taylors, SC
    Not true.
    You would either have to disable the circuit too the light electrically with a jumper or block it off on the screen with a piece of tape.
    Brian1954 likes this.
  3. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    This is indeed not true.
    (What can be tested/done to fool the system (apart from the circuit disablement) is to put four activated cheap TPMs sensors in a pressure can (that can hold pressure and have a big enough opening to put them sensors in there :)) in the trunk and fool the ECU these readings are from the tires…) :LOL:
    NOTICE: Toyota or priumium do not recommend or condone this foolish fooling of an ECU.
  4. Georgina Rudkus
    3,508
    2,487
    Taylors, SC
    Why go through this complicated exercise and get no benefit form the TPMS transmitters?
    Just put the transmitters into the wheels with the tires and get their ful benefit.
    As I posted, a piece of wire or black tape gets the same results.
  5. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    @Georgina Rudkus As stated, this was just a suggestion - and if fooling is anyone’s game, as your own ECU disablement indicates galore, this is also a way.
    How does your own tip get any benefit at all from this feature?
    I just wrote about how easily these sensors can be added and cloned in another thread (for those of us that have to swap tires annually by law)
    #25 priumium, Nov 30, 2025
  6. VelvetFoot
    VelvetFoot Active Member
    1,161
    459
    New York State
    2026 Prius
    I've been looking, for I've always used snows.
    But, it's a major expense, when you throw in the wheels.
    I'm retired, so maybe I can pick and choose when I travel in the white stuff.
    Although, I'm looking out the window, and it's snowing, and I'm supposed to go out to a movie later. Argh.
    edit: I also live on a hill. Argh x 2.
    priumium likes this.
  7. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    Indeed it’s a major expense if the wheels are not included. Since it’s by law here up north (Sweden…) almost every used vehicle has the rims, but the tires are crap.
    In my experience, the Prius is a snow/ice master with studded tires. When I used winter tires the antislip feature would make the drivetrain unhappy.
    This year I bought GY Arctic Ice 2 and they are superb.
  8. VelvetFoot
    1,161
    459
    New York State
    2026 Prius
    I had Nordman by Nokian on my last MINI. Helped on ice, but noisy as hell!
  9. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    Agreed. Have tried these with the same feeling, and the Nordic hakkapallita model was the same. Great grip, noisy. It’s normally a trade off.
    These GY mentioned are rated for 69dB and are much less noisy with maximum grabber effect for me on ice last week. Impressed!
    VelvetFoot likes this.
  10. Purrius
    Purrius Member
    166
    49
    Northeastern US
    I'm unsure if there's any negative side-effects to running the set without the sensors, but I've been pleased with the results of just swapping back and forth with my two sets of wheels to combat the weather.
    My car is inspected until next year, so currently an angry dash light is a non-issue for me.
    Georgina Rudkus likes this.
  11. Tombukt2
    13,335
    2,401
    Do they really ding you for your TPMS light being on holy cow . Even in winter with your winter wheels on that's too funny . Why I had to get out of those States
  12. VelvetFoot
    1,161
    459
    New York State
    2026 Prius
    On the new cars I think it’s more than just putting a piece of black tape over a red light. A whole big warning thing comes up and you have to dismiss it blah blah blah blah blah. A PITA.
  13. Georgina Rudkus
    3,508
    2,487
    Taylors, SC
    Just turn it off with a thin wire jumper.
