Cannot complete replacement brake booster air bleed procedure
Discussion in 'Gen 3 Prius Technical Discussion' started by George Jung, Oct 31, 2025.
  1. George Jung
    George Jung Junior Member
    Las Vegas Nevada
    I have finally found something useful in the manual... I found the Page "ABS WARNING LIGHT REMAINS ON". It told me to verify voltage on a28-16 of 11-14 volts and less than 1 ohm resistance to ground on connectors a28-23 to 28. Those all checked out.. So im at a dead end again. I'm going to replace the 125amp fuse tonight, and see if that helps any, though i doubt it.
    indel likes this.
  2. rjparker
    10,126
    6,290
    It would be worth clearing codes, running it again and checking codes again with Techstream.
    I would not get too carried away trying to replace the 125a fuse yet. It is very difficult to access. It is possible to bypass it on top but with a 125a added. Checking that the other fuses are good is worth the time.
  3. George Jung
    Las Vegas Nevada
    Replaced the 125 amp fuse... I am now nearly 100% certain this issue is not caused by a faulty adapter, as I resubscribed to GTS and i was able to update calibration on ECU.... So im quite sure my adapter should be capable of performing the brake bleed procedure. Im sill trying to find anything in the manual that is useful.
  4. rjparker
    10,126
    6,290
    Codes?
    Is this problem coming and going?
  5. George Jung
    Las Vegas Nevada
    No. Since replacing the master cylinder I have been unable to initiate the brake bleed procedure, and the same codes remained. They're attached to the first post of this thread, but The accumulator pressure low and reservoir level are only on when the reservoir is disconnected when trying to do the bleed. When I try to initiate the zero point calibration the lights never blink.
  6. George Jung
    Las Vegas Nevada
    This video here is the type of info i'm looking for... I'm definitely checking all this out tomorrow. It's hard to navigate to this info in the manual without knowing what you're looking for. Everything in the manual is just leading leading me on a loop that always ends on "replace master cylinder"
  7. ASRDogman
    ASRDogman Senior Member
    7,569
    3,903
    Have you tried JUST doing the "brake fluid replacement" procedure?
    I seem to recall someone having similar issues, and for some reason just did the fluid replace only.
    And it worked.
    Since you have a pirated copy of techstream, that also could be an issue.
  8. George Jung
    Las Vegas Nevada
    Yes I have, basically all the utility functions fail to start or fail. I've renewed my tis subscription yesterday for two days. I successfully recalibrated the ECU, so I'm almost certain the issue is not related to the connection, adapter, or obviously not the software.
  9. Mendel Leisk
    41,397
    Have you considered handing it over to a dealership service department? Probably nightly, lol?
  10. rjparker
    10,126
    6,290
    He seems determined to diy even if it costs thousands (so far) more. The sunk cost paradox.
    I suspect his brake booster source (bamauto.com), damaged wiring during his engine replacement or fuses missed/collateral damage after his 125a overcurrent.
    #30 rjparker, Nov 28, 2025 at 1:04 PM
  11. Mendel Leisk
    41,397
    I've been there. It's pioneering spirit, cost be damned. :)
  12. George Jung
    Las Vegas Nevada
    If certain models must use a certain master cylinder, what component determines it is a match? What if for example the ECU has been replaced? Im not sure if it has, but is it possible to look of serial number of the ECU and determine the vin it was originally from, and then find what part number of the master cylinder is supposed to pair with it? I cant find any issues with any of the connections. All of the power and grounds on the A58 connector for the master cylinder are testing good on test light, and the CAN connections are all ohm'ing out around 60 ohm.
  13. rjparker
    10,126
    6,290
    If you have a used brake booster/master cylinder from bamauto.com (site?), about the only way to determine if it is compatible with your 2011 hatchback is to know the vin of the donor vehicle and look up the brake booster part number for the donor. Then you can compare to the part number for your car.
    Even if the used part number is correct. it could be bad.
    Given a new brake booster can be bought from an online Toyota dealer for $486 during the current sale (autoparts.hoovertoyota.com), if yours is used I would buy a new one quick.
  14. George Jung
    Las Vegas Nevada
    The part was shipped new OEM from a Toyota dealer, the part number is the one the dude at the parts counter verified is correct for me the othe day. So i don't have any reason to believe putting in another new part is going to fix anything. I've already said all this. You can stop repeating yourself please.
  15. George Jung
    Las Vegas Nevada
    This is the box the part came in. Does it not look legit?
  16. indel
    indel Junior Member
    71
    Northwest Indiana
    The part could be new and still defective. You could try returning it and getting a new one. Over the counter parts have 12 month warranty.
