Hi all Background Bought a 2008 Prius online at auction Received the car without a key Had locksmith program a fob Car turns on but will not go into Ready I tried to scan for codes but the OBD2 port was not getting power. Discovered the 7.5A fuse was blown. Replaced that and was able to scan Dr Prius shows the hybrid battery to be fine No error codes due to the fact that the 12v was dead so I charged it up to 13v When I tried to start the car on the 2nd push of the start button I hear only 1 click vs 2 clicks I assumed there is a bad relay in the hybrid so I took one out of my other prius which works fine. Switched the hybrid battery and the same thing. 1 click and it won't go into Ready mode Checked all fuses in engine compartment and all are good (AM2 fuse specifically was double checked) The car comes on. Windows work. Lights all come on. 1 push of the start button turns on the MFD. 2nd push od the start button lights up all the warning lights on the dash but will not go into Ready Confirmed 12v at the fusebox as well Since the battery was replaced there are no error codes to list Any ideas to try would be appreciated
Ybrid isolation fault comes to mind with scanner connected try clearing codes back to back as per scanner screen do it ready now? That's hybrid iso fault usually. Now take service plug out remove cap showing fuse reinstall SVC plug leaking out last slam step dvom on silver screw on fuse in plug other probe to chassis ground meter should count down to Zero . If not say it stops at 75 bad battery is not isolated from frame of car . Which is your 12 volt ground point which now having havoc wreaked on it .
