Cylindrical batteries from Yabo
Discussion in 'Gen 3 Prius Main Forum' started by Swafdal Ahmed, Dec 1, 2025.
  1. Swafdal Ahmed
    Swafdal Ahmed Junior Member
    Uganda
    Guys, how’s everyone. I’m inquiring if the cylindrical Prius aftermarket are good or I look for the new oem shaped Prius cells. Of the 2 which do you recommend for a country with too much heat
  2. Tombukt2
    13,226
    2,392
    None of them so far has panned out anything like the Panasonic so you're gambling basically and they all want real money no. Matter
  3. Brian1954
    Brian1954 Senior Member
    2,351
    948
    South Central PA, USA
    The aftermarket cylindrical battery lasts about 4 to 5 years. A new Toyota OEM battery lasts 10+ years.
  4. Mendel Leisk
    41,785
  5. DirkAshburn
    DirkAshburn Member
    157
    65
    Virginia
    I looked into these last year, keep in mind there are several brands of these floating around which like any battery vary in use/longevity. If you get one, get it from somewhere with a good warranty.
  6. ASRDogman
    ASRDogman Senior Member
    7,723
    3,960
    If you want new, you want the Sodium ion.....
    Going oem from the dealer, you can't go wrong, but it will cost you double.
