ABS Pump issue (pump motor replaced)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nirosorin, Dec 3, 2025.
  1. Nirosorin
    Nirosorin Junior Member
    27
    Sorry for the quite long story here, but I'm feeling like I'm still in the middle of it.
    2005 Prius with the ABS, VSC, brake light problem. All light up, the assisted brake was gone, plus the continuous beeping alarm noise.
    Used a tester and identified the C1256 code - Accumulator Low Pressure. Also didn't hear the little pump engine working at all. Decided to take out the ABS assembly and see what could be the problem.
    Identified that the ABS pump motor was gone, took it out of the assembly to see if it works, but it didn't turn at all, when hooked up to 12v, opened it up and found why it was seized up: full of rust and with two of the magnets detached from the case and stuck to the rotor. Also the rotor looked and smelled burned - didn't measure it but was garbage anyway.
    Figured out that most probably the motor was causing the low pressure. From all available options for me, decided to buy a new motor (from China) and replace it in the assembly (a new pump was out of the question expensive, and used ones I really didn't trust by the looks of those available in my area, also read about others going through 3 used ones and still no fix).
    I've put the whole ABS assembly back to the car, connected all lines very carefully - no leaks.
    Did all that work myself, and only asked a mechanic-enthusiast neighbor for help with a compatible tester - that looked to be capable of air bleeding for Toyota. Turned out it was only sort of guiding us through manual air bleeding and didn't actually electronically air bleed the pump - or maybe we didn't explore all the available options of that software. Managed to air bleed the lines for each wheel (I hope), but I don't think we've got the air out of the pump itself, as it never got to that stage of pressing the pedal 30 times in 30 seconds that I saw other testers or Techstream required.
    Now I still have codes for low pressure. But while doing the air bleeding the manual way, I saw that the pump motor used to crank and build pressure every time we took out the R8 (ABS MTR) Relay, the pump motor starts pumping and the errors and beeping goes away. Then if I press the pedal a few more times it cranks again and rebuilds it, but after a few presses the codes and beeping comes back. And if I repeat the relay take out process it builds pressure back again, and so on.
    Also I noticed that the regular bussing of that little pump motor that we hear every time we open the driver door after it's been sitting for a while doesn't happen. I only hear the relay clicking, an no motor buzzing. An when I press the pedal I think I hear the solenoids working.
    A few days ago I managed to get a Mini VCI and installed Techstream and get them properly working. Cleared codes and rebuilt pressure like I've described above (taking out the relay), the C1253 still lingers. As I'm preparing to do a complete ABS Pump air bleed, my question is: do I need to measure or replace relays to prepare for the air bleed?
    #1 Nirosorin, Dec 3, 2025
  2. Tombukt2
    13,306
    2,398
    When you go through the bleed procedure with textstream and you pick actuator has been replaced it's to go thru all steps and I believe the first step is to remove the blue relays bleed fronts manually then relays go back in to bleed rears because they electric only. Then there's a part where you'll pump brakes 40 times in 30 seconds this is where the internal valves activate. What you can do is bring up tech and go thru bleed menu dry just to see the basic gist of it nothing to it . I usually have my fronts and rears manually bled already I know there's no air . Then I connect the Toyota software and I go through the bleed menu and I skipped the manual bleeding of the front and rear and the relay removal and replacement and valve activation . Any air that's found in the internal valves just gets bled back up into the reservoir it needs nothing done at wheels . And usually that does it in all four of mine Ive not had to even mess with linear valve
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,083
    1,995
    NJ-USA
    So, there are two relays for the brake actuator pump. Both just supply power to the pump motor when the ecu turns one of them on. The pump pushes brake fluid into a storage accumulator at high pressure (over 1000psi).
    The ecu controls valves to direct the high pressure fluid to the actual friction brakes at each wheel. Normally your foot has NO direct connection to the brakes. Stepping on the pedal tells the (hybrid control) ecu what you want to do and the ecu decides how.
    The ABS MTR (1) relay is usually used for "normal" brake operation - such as when you open the door or step on the pedal to slow down.
    ABS MTR 2 relay is usually used when ABS brake operation is called for. The ecu will also use it if ABS MTR (1) is "failed" or missing.
    It sounds like something is wrong (ie, the pump won't run) when the motor relay 1 is activated. Time to get a diagram out and test the relay, fuse, wiring, etc.
    The C1252 code sets when the "motor relay is ON for at least 5 minutes".
  4. Nirosorin
    27
    I think I have committed a mistake here it's actually C1253 the error code that lingers.
    So it's something to do with Hydro Booster Motor Relay.
    I've read something called subcodes in techstream. I don't know how to get to them.
  5. mr_guy_mann
    4,083
    1,995
    NJ-USA
    If you have Techstream, look at the code list. If there's a snowflake symbol next to a code, then click on the symbol (that's FreezeFrame). The FF is a momentary snapshot of data the ecu saw when the code set. Somewhere in the list are some lines titled "detail" - that's the INF code.
    The short form is this: does the pump run when the ecu turns on Motor relay 1? Does it run from relay 2?
    #5 mr_guy_mann, Dec 4, 2025
    Nirosorin likes this.
  6. Nirosorin
    27
    Thank you. Will do that. Didn't really know what that symbol was abaut.
  7. Nirosorin
    27
    If this is answering some questions, please help me figure this out.
    I've done an extensive research in the past few days and I find that the motor going out like this most times also kills the Power Resistor.
    What do you all think?
    I thought of using one of the other resistors (fuel pump or AC) and swapping it for the ABS pump a bit, just for diagnostic purposes.
    #7 Nirosorin, Dec 10, 2025
  8. Nirosorin
    27
    Other details:
    I swapped the relays with others from different functions (which physically fit the same connector and pins, and I also had two spares) - nothing changed. The pump motor does not buzz when opening the door after a short rest. So the problem starts when the door is opened. I hear the relay clank, it seems like it tries to spin, but nothing with the proper duration needed to build pressure.
    However, if I start the car or leave it in READY mode, then open the hood, and, while it is still in READY, I remove relay R8, the pump starts (the characteristic buzzing), works for 2-3 seconds and builds pressure. The little pump motor starts running immediately when I pull the relay, before I even put it back, so keeps working with the relay in my hand. After I reinstall the relay and get back behind the wheel, the pump motor sounds correct every time it's needed, on the third or fourth consecutive brake press, just as it should and just as it worked when everything was fine. So the pedal press demands the pump to run and seems to work fine. True, the warning lights stay on, but the annoying beeping goes away.
    Then, after turning the car OFF and ON again, if the car had the correct pressure before shutting it off, it won't throw errors immediately, but if I press the brake pedal a few times (so with the pump motor not starting), the low-pressure errors appear.
    But it resumes working if I repeat the relay-pull trick.
    From that point on, the car works perfectly. I did a test drive for 20 minutes and over 10 miles; the pressure does not drop, no more errors, the pump motor runs at the correct intervals, and the car drives and brakes properly, with assisted braking and apparently enough pressure (it does not seem to have air in the system). The ABS also kicks in when needed.
  9. Tombukt2
    13,306
    2,398
    I've never seen the relay or resistor go out and don't think I've had a pump failure that I know of all. Pumping wen removed . The pressure just can't be stored anywhere is generally my problem the lack tank or such leaking down . Sounds to me like whatever is controlling all of this maybe the issue don't know what that is. So far beyond my pay scale maybe I get they're someday . But we 20 some odd years in now . So maybe not for me
  10. mr_guy_mann
    4,083
    1,995
    NJ-USA
    R8 is the ABS MOTOR relay (1). That's what the ecu tries to use for normal brake operation. When the ecu turns it on, it should connect B+ power from the 25A ABS-1 fuse through the "brake actuator resistor" (item B19 under the driver's side dashboard) to the actuator pin 2 (BM1 ckt).
    When you pull that relay, the ecu stops trying to use it, it only uses R2 (ABS MOTOR 2) relay.
    If you swapped both blue motor relays and the R8 position still "doesn't work" even though it clicks, then you have a problem with the wiring.
    Does 12V battery power get to the correct terminal of the R8 socket? Does 12V get to the B19 actuator resistor when R8 is turned on? What voltage (if any) is on the actuator side of the resistor? ie, at terminal 2 of the actuator (BM1).
    I would not be surprised if this "power" resistor WAS damaged by the pump motor failure.
    I have never had to replace the resistor, but have read that it is (just) possible to do so without pulling the entire dashboard out.
    #10 mr_guy_mann, Dec 10, 2025
    Brian1954 and Nirosorin like this.
  11. Tombukt2
    13,306
    2,398
    It is possible . Noticed no difference changed or not that I could tell anyway tried em both original and new supplied w actuator .new actuator worked with both resisters I had. I kept using original .
  12. Nirosorin
    27
    What I read about the reason Toyota supplies new actuators with a resistor is this exact scenario I'm in: old pumps go out because of the motors 9 out of 10 times. So the seized up motor usually pools a lot of current that eventually burns the resistor.
    I'm going to get to it and measure it's resistance. Hopefully it's out of range. That would be an easy fix.
  13. Tombukt2
    13,306
    2,398
    Yep twould. I've never had a no pumper. I always have the crickets always . What I don't have is accumulator pressure which equals brake pedal more or less. All 4 times so far .
