Auction 2008 prius will not go into Ready.
Discussion in 'Gen 2 Prius Technical Discussion' started by andy song, Dec 1, 2025.
  1. andy song
    andy song Junior Member
    Hi all
    Background
    Bought a 2008 Prius online at auction
    Received the car without a key
    Had locksmith program a fob
    Car turns on but will not go into Ready
    I tried to scan for codes but the OBD2 port was not getting power. Discovered the 7.5A fuse was blown. Replaced that and was able to scan
    Dr Prius shows the hybrid battery to be fine
    No error codes due to the fact that the 12v was dead so I charged it up to 13v
    When I tried to start the car on the 2nd push of the start button I hear only 1 click vs 2 clicks
    I assumed there is a bad relay in the hybrid so I took one out of my other prius which works fine. Switched the hybrid battery and the same thing. 1 click and it won't go into Ready mode
    Checked all fuses in engine compartment and all are good (AM2 fuse specifically was double checked)
    The car comes on. Windows work. Lights all come on. 1 push of the start button turns on the MFD. 2nd push od the start button lights up all the warning lights on the dash but will not go into Ready
    Confirmed 12v at the fusebox as well
    Since the battery was replaced there are no error codes to list
    Any ideas to try would be appreciated
  2. Tombukt2
    13,303
    2,398
    Ybrid isolation fault comes to mind with scanner connected try clearing codes back to back as per scanner screen do it ready now? That's hybrid iso fault usually. Now take service plug out remove cap showing fuse reinstall SVC plug leaking out last slam step dvom on silver screw on fuse in plug other probe to chassis ground meter should count down to Zero . If not say it stops at 75 bad battery is not isolated from frame of car . Which is your 12 volt ground point which now having havoc wreaked on it .
  3. bisco
    52,303
    brake pedal switch?
    pasadena_commut likes this.
  4. andy song
    Some more info. I took the hybrid pack which was in the car that didn't go into Ready and put it into another prius. It started right up. Test drove it for 20 miles. No issues.
    This tells me it is not the pack so not isolation fault since the battery works fine in a different car
    Or am I missing something?
  5. Tombukt2
    13,303
    2,398
    Yep simple enough sort of its sensitive and can change values I guess I tend to use the count down method W Dvom . Must be some lites I'd hope . Until it readies I don't think any data for scan is they're ? To get
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,083
    1,995
    NJ-USA
    As mentioned, make sure the brake switch works.
    What scantool are you using? DrPrius is handy but is very limited. I would use a capable scantool (such as Autel AP200 or maybe a copy of Techstream) to check all 15-16 systems for fault codes.
    strawbrad and Brian1954 like this.
