Solution to 12V issues? Disconnect 12v negative terminal sensor plug
Discussion in 'Gen 5 Prius Main Forum' started by Halcykon, Dec 1, 2025.
  1. VelvetFoot
    VelvetFoot Active Member
    756
    268
    New York State
    2026 Prius
    Nice chart.
    I took a couple of 22mi/35min drives this afternoon, with a detour for groceries.
    I had OBDC adapter voltage displayed via CarPlay and OBD Fusion.
    It was steady on 14.3/14.4v the entire way. I did take my eye off the road a fair number of times, lol.
    I managed to log the values as well-it backs up my assertion, lol.
    Several OBD Fusion and Car Scanner (both display on CarPlay) notes:
    -Graphing on both are lame
    -OBD Fusion does log files in .csv format, whereas I could not see a way to export data in Car Scanner-perhaps the Pro version?
    For those Gen5'ers who are into it, there's a profile in Car Scanner for '23 and up 'Primes', but I found a lot of stuff works on the LE as well. Do I understand it all? No. But others might. :). I didn't systematically try everything-perhaps I should. Maybe connect to car and do an "all sensors" take some screen pics-see what fields are populated with data. Perhaps that would be most expeditious.
    Gokhan likes this.
  2. mva
    mva Member
    139
    83
    B.C. Canada
    2024 Prius Prime
    SE
    On my 2014 F150 the original battery lasted 3 years 10 months. At that point, after a bit of research, I disconnected the current sensor on the negative battery cable and it’s stayed unplugged since 2018. The replacement battery lasted 7 years and still had some life left. It is a well known issue on the F150 forums.
    On my 2024 Prius I am keeping a close eye on the battery and charging rate and it’s been good so far. But, if I start finding it undercharged I will try unplugging the sensor.
    reservoirblue likes this.
  3. VelvetFoot
    756
    268
    New York State
    2026 Prius
    Interesting that there seems to be a temp sensor in the battery current sensor.
    From Car Scanner:
    upload_2025-12-4_11-53-16.png a
    As well as current:
    As well as voltage:
  4. VelvetFoot
    756
    268
    New York State
    2026 Prius
    I ordered a BM-2. Mostly for something to do...I hope, anyway.
    I imagine charging voltage may be attenuated during the warmer seasons.
    Roy Peterson and Gokhan like this.
  5. Gokhan
    Gokhan Senior Member
    6,249
    2,480
    Paramount CA
    Yeah, it has temperature (a thermistor) along with voltage, current (a shunt resistor), SOC, SOF, SOH, and self-diagnosis sensors.
    #45 Gokhan, Dec 4, 2025
  6. Roy Peterson
    Roy Peterson Member
    99
    129
    Richland WA
    2024 Prius Prime
    I have a voltmeter that plugs into the 12 volt aux adapter plus the BM2 on my 2024 Prius.
    My experience (AGM battery) is when the battery temperature is in the mid 40’s F and below, the charge voltage stays a constant 14.4 volts which is what is did last winter and now currently. During warmer months, the charge voltage defaults typically to 12.8 volts after a short period of driving.
    My truck has an AGM battery and during colder months the charge voltage is 14.4 volts per a plug-in voltmeter in the 12 volt aux port. The charge voltage decreases with temperature. Typically 13.5 volts on a hot summer day in the 90’s.
    I replaced the OEM battery after it went flat and unable to start the car. I still have it and it tests good after charging with the Noco Genius 5. That said, the AGM has been in the car since October 2024 with no issues.
    Cheers
    Gokhan and VelvetFoot like this.
  7. mva
    mva Member
    139
    83
    B.C. Canada
    2024 Prius Prime
    SE
    So I decided that I should test my 12 volt battery which good (12.75 volts) when I tested it in July. I disconnected the battery and it was at 12.2 volts at 7 Celsius! This is under 50% state of charge.
    This is not due to lack of driving or short trips since I have done four 80 km trips in the past week.
    I put the car in “Ready” mode for 5 hours, to charge the 12 volt, since I don’t have 120 volt power for my battery charger where the car is parked. It showed over 14.2 volts the entire time, but, this morning, the battery was only at 12.3 volts. So, I removed the battery and I charged it with my 10 amp battery charger. It came back up to 12.8 volts quickly and tested good at 295 CCA.
    I will be keeping a closer eye on it. Fully charged, it shows 12.1 volts at the cigarette lighter, in ACC mode, so checking this periodically might help me see if it is getting low.
    soft_r likes this.
  8. BiomedO1
    3,665
    1,899
    SacTown, Ca
    did you get a starting voltage measurement before starting the 5 hrs charge cycle?
  9. mva
    mva Member
    139
    83
    B.C. Canada
    2024 Prius Prime
    SE
    The battery when disconnected was at 12.2 volts, I reconnected and put the car into “Ready” for 5 hours which used 10 km of EV range. I then shut the car off and plugged it in overnight. In the morning I disconnected the battery again and it was only at 12.3 volts. I then removed it and charged it back up to 12.8 volts with a 10 amp charger.
    The ready mode should charge it up pretty well if left long enough. Especially in winter when the car seems to charge over 14 volts much longer.
    BiomedO1 likes this.
  10. BiomedO1
    3,665
    1,899
    SacTown, Ca
    I get similar results on my gen4 - 12V battery always in the low 12's.
    When I started my test. it was 11.8 - traction pack fully charged and car sat for a day parked.
    soft_r likes this.
  11. Gokhan
    6,249
    2,480
    Paramount CA
    But the most interesting part is 20 ℉ in Beverly Hills.
    PrimeDan likes this.
  12. Gokhan
    6,249
    2,480
    Paramount CA
    That sounds too low for a flooded cell. Here is the chart for SOC vs. voltage, with AGM on the left and flooded cell on the right. Note that the voltages are open-circuit voltages after at least 12 hours of rest. Make sure that the key is more than ten feet away and the car is at deep sleep when you test the voltage.
    It looks like AGM batteries do better with Gen 4 and Gen 5 Prius/Prius Prime. The lowest I have seen with my AGM was around a 71% SOC (12.53 V) after a long rest.
    In any case, I would hook up a Noco Genius with either a flooded cell or an AGM periodically to fully charge the battery to reduce sulfation.
    BiomedO1 and VelvetFoot like this.
  13. BiomedO1
    3,665
    1,899
    SacTown, Ca
    That's what I do; I try to check the battery at least every quarter with my calibrated Fluke meter. If/when it needs replacement - I'll probably move to an AGM or lithium battery, depending on price vs performance. I'm going to see if I can squeeze 10 years out of the OEM battery. I've got several jump-packs on-hand that gets tossed into the trunk, whenever I go out of town.
  14. Mendel Leisk
    41,519
    That seems long, what's the amperage, what specific Noco model?
  15. Gokhan
    6,249
    2,480
    Paramount CA
    It is a smart maintainer. If it charged at full amperage the whole time, your battery would be toast. It has a charging profile with about seven phases. The last phase is the small-constant-current charging phase to reach true 100% SOC. The small charging current is probably around 100 mA in that phase, which is the phase that takes close to two days, and charging stops when about 14.12 V is reached for an AGM.
  16. Mendel Leisk
    41,519
    My CTEK MULTI-US 4.3 is 4.3 amps, typically takes around 4~6 hours to run it's multi-stage program. Current iteration is MXS-5, basically the same thing, same 4.3 amps. Our battery more-or-less LIVES on it, due to our low usage. Battery's over 10 years old now.
    Gokhan likes this.
