How to verify OEM spark plug compatibility Prius Gen3
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatorback, Dec 6, 2025.
  1. gatorback
    gatorback Junior Member
    36
    I am seeking confirmation from owners that I have installed OEM spark plugs in their Gen3 Prius. I believe OEM is Denso SK16R11. Possibly the Denso SC20HR11? Has anyone installed the Denso SC20HR11
    It is unclear to me if the Denso SC20HR11 is a suitable OEM replacements for my Gen3 Prius. As I newbie, I am inclined to use OEM unless Mendel or other senior member recommend otherwise.
    I understand that Denso manufactures spark plugs in China / USA: is there a preference for spark plugs made in Japan?
    Google Indicates:
    For a 2010 Toyota Prius, the recommended Denso iridium spark plug is the
    SC16HR11, also known by Denso part numbers 3499, SK16R11, or the OEM Toyota number 90919-01275, which supersedes the older SC20HR11 specification and offers long-life performance for daily driving.
    Key Denso Part Numbers:
    • SC16HR11 (or SK16R11): The modern, recommended long-life iridium plug.
    • 3499: The retail number for the SC16HR11 plug.
    • 90919-01275: The official Toyota OEM part number for these plugs.
    eBay indicates the seller indicates SC20HR11compatibility: 4Pcs New 90919-01253 DENSO Iridium Spark Plugs SC20HR11 3444 for Lexus Toyo | eBay
    Toyota indicates part number #90919-01275
    Spark Plug #90919-01275 | Autoparts.toyota.com
    #1 gatorback, Dec 6, 2025
  2. Hayslayer
    Hayslayer Active Member
    409
    233
    DO NOT purchase spark plugs from ebay or amazon. There are just too many counterfeits out there.
    get the 3444 plugs from RockAuto.com they're less than $10 each and will be actual denso plugs, not some chinese imitation.
    Zeppo Shanski likes this.
  3. gatorback
    36
    #3 gatorback, Dec 6, 2025
  4. Tombukt2
    13,056
    2,340
    I used the twenties in my cars down here in the southeast United States where it's really hot most of the Year always have most all toyz come w 16 HR or did forever . I always used the 20 since working at dealer down here . I use the long life model of whatever plug series I'm using at time denso. Makes a bunch . Fine wire racing etc .
  5. gatorback
    36
    What is the difference between the 16HR and 20HR spark plug? Does the 20 somehow last longer? perform better? This car is driven in Hotlanta and Florida.
  6. Mendel Leisk
    41,545
    Can't remember where I heard it, but the story was the 16's are a slightly hotter plug, ie: they'll burn off deposits better. The owner's manual says 20's, but Toyota revised, presumably due to plugs building up deposits. I had the 20's for 12 years, looked virtually new when I pulled them after 12 years (and 95k kms), replaced with the 16's, per Toyota's recommendation.
    I'd just go with the Denso 16's, that's the recommendation.
    Sort of the exception, but this time round the dealership parts department was actually cheaper than my usual local automotive go-to place. Are you near a dealership?
  7. gatorback
    36
    Good to hear from you Mendel. Thanks for the interesting explanation. Yes, I am within 15 minutes of a dealer. At $4 per plug: I thought these were a good price: 4PCS GENUINE IRIDIUM SPARK PLUGS 90919-01275 FOR TOYOTA SCION LEXUS SC16HR11 | eBay
    Tombukt2 likes this.
  8. Mendel Leisk
    41,545
    Good price, but maybe counterfeit?
    FWIW, I paid $16.50 CDN apiece for mine, in 2022, through dealership. The Toyota part no (it's the denso, just in different box) was 90919=01275.
  9. Leadfoot J. McCoalroller
    8,100
    7,581
    Pennsylvania
    2018 Prius c
    Carall, StarCaller and Brian1954 like this.
  10. ChapmanF
    18,256
    Choosing a hotter plug improves burning off of deposits, at the trade of a lower safety margin from pre-ignition (the hotter plug tip may ignite the mixture before the spark is timed to occur). That's what makes the choice a trade-off, and not just a simple "get hotter plugs, they'll stay cleaner" rule.
    The language and the numbering are tricky. Denso uses lower numbers for hotter-running plugs (so 16s run hotter than 20s). Some other manufacturers use an opposite numbering convention.
    Denso uses the term "low heat range" (and a low number) to mean slower heat dissipation toward the plug shell—meaning a plug that stays hotter. They use "high heat range" (and a high number) to mean faster heat dissipation toward the shell, meaning a plug that runs cooler. So in Denso literature, "low heat range" means a hot plug, and "high heat range" means a cold plug.
    NGK avoids that mess by not even using terms like "low heat range" or "high heat range"—they say "hot heat range" or "cold heat range" (respectively!), instead.
    Heat Range | Basic Knowledge | SPARK PLUG | Denso
    Understanding Spark Plug Heat Range - NGK Spark Plugs
  11. Tombukt2
    13,056
    2,340
  12. ASRDogman
    ASRDogman Senior Member
    7,618
    3,922
    Just be careful about "senior members". Some want you to believe the know everything,
    and they are never wrong. If you disagree with them, they will attack you.
    Sticking with the OEM is a good idea, can't really go wrong.
    Buying from ebay or amazon, it's extremely likely they are cheap chinese copies, and won't last.
    That's why they are cheaper.
    Buying from autozone, or similar auto parts store it's less likely that they are cheap copies.
    I've been using Bosch plugs without any issues. But the last time I changed them they were
    out of them, so I tried ngk. 1 failed after about 2000 miles, and possibly a 2nd one also.
    I think Toyota went to the hotter plug to help offset the oil burning. It really won't hurt to use it,
    but using the original one will work fine.
    Every manufacturer uses different countries to make there parts. Some have strict standards and
    even if they are make in china, they use the correct parts and tolerences. It's when the chinese
    COPY them, and use cheaper components and don't care about tolerences is where the issue is.
  13. Patrick Wong
    18,210
    6,510
    I just replaced the original spark plugs on my 2015 with 99.8K miles, which were Denso SC20HR11, and replaced with Denso SC16HR11 purchased from Amazon. The price was $49 plus tax for four so I hope they are not counterfeit.
    The Denso website shows SC16HR11 as the correct choice for the 3G Prius.
    The old plugs had some deposits on the ceramic tip and the porcelain tail had a narrow brown band where the porcelain is left exposed by the coil socket that fits over the plug. The amount of deposits on the tip was sufficient so that I think a hotter-running plug is appropriate for my environment.
    I understand that narrow brown band is a corona stain caused by high voltage ionizing the air and causing oil or dirt particles to adhere to the exposed porcelain. This is supposed to be a normal phenomenon and does not imply a problem with the plug or coil.
    I hope the OP understands that the wipers, black plastic cowl, wiper motor and sheet metal tray will need to be removed as pre-requisite to pull the spark coils out of the cylinder head. That is not a difficult job but will take another 40 minutes to an hour to remove and replace.
    #13 Patrick Wong, Dec 7, 2025
    gatorback likes this.
  14. ASRDogman
    7,618
    3,922
    My bet is they are cheap chinese copies......
    I don't have the link, but they guy from illinois that is a toyota guy did a program on how to
    spot the cheap copies.
    Hopefully, someone will have it and can post it.
    Patrick Wong likes this.
  15. Mendel Leisk
    41,545
    Excellent @NutzAboutBolts video on 3rd gen spark plug access:
    BTW, it's video #13 , here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    One quibble with the video: he puts a generous coat of anti-seize on the new plug threads, and says to torque to 20 ft/lb. Repair Manual specs 15 ftr/lb, and no mention of lube, so presumably clean/dry threads.
    For a torque value that low, a 3/8" or 1/4" drive torque wrench is appropriate. The latter typically uses inch/pounds. If you have a value like 8 foot/pounds, that is equal to 96 inch/pounds (8x12).
    Further on inch versus pound torque values, I've lost count of the reports here, novice mechanics see the torque value for the spark plug coil hold-down bolt, gloss over that it's inch pounds, get out the 1/2" torque wrench, set it to foot pounds, and consequently snap the head off, leave the bolt fragment stuck. Suffice to say: reserve the torque wrench for the spark plugs, just use common sense on the rest of the fasteners you encounter.
    Regarding lube on the threads, try googling: "denso recommendation for anti-seize on spark plugs". The AI summary says Denso, and others, are against it.
    Repair Manual excerpt attached, and another quibble, regarding that publication: the spark plug section makes NO mention of the torque value for the plugs, I found that about a thousand pages distant, lumped in with the valve cover removal, which makes no sense. Anyway, tacked that page on, at the end of the excerpt.
    #15 Mendel Leisk, Dec 7, 2025
  16. Patrick Wong
    18,210
    6,510
    IDENTIFY COUNTERFEIT DENSO SPARK PLUGS
  17. Patrick Wong
    18,210
    6,510
    I agree there is no need for anti-seize especially since these plugs have such a small threaded shell diameter. I had absolutely no issue removing the original plugs that had been sitting there for 10 years. With 2G Prius, I recall the plugs had some reluctance to come out after such a long service duration.
  18. Mendel Leisk
    41,545
    Tried googling:
    does denso coat their spark plug threads with a lubricant
    and again, AI was very helpful, saying in part:
    Denso spark plugs (and NGK) come with a special trivalent plating on their threads that acts like a built-in lubricant
    Regarding counterfeit plugs, simply purchasing from dealership, or reputable, local, brick-and-mortar automotive specialty shop, should improve the odds of not getting burned. Again, I went with dealership (at the 12 year mark), they were lower priced than my go-to third party store, but that place is always first on my list; they're very hands-on, sell specialty tools, have a machine shop section, can sell you stuff like fuel line by the foot, and so on.
    This is something you do every 120k miles or 12 years, not worth gambling.
    #18 Mendel Leisk, Dec 7, 2025
  19. ChapmanF
    18,256
    ^ This. Don't take it lightly. I was in a traffic slowdown the other day because an ambulance was loading in somebody who'd been attacked by a senior member he'd disagreed with. It was grisly.
  20. indel
    indel Member
    142
    51
    Northwest Indiana
    I always get spark plugs from the dealership. Last time I bought some (early Nov 2025), they cost me $13 a piece including shipping during their 25% off sale. I got free shipping because I had more items in the cart.
    Part Number: 90919-01275
