My old Prius losses MPG suddenly
Discussion in 'Gen 4 Prius Fuel Economy' started by al espenschied, Nov 28, 2025.
  1. al espenschied
    al espenschied Junior Member
    Ohio
    I have a 2016 Prius. It has always achieved excellent MPG, averaging 62 mpg over the lifetime of the vehicle which is currently 206,000 - it would be closer to 65 mpg if I had installed the blocks for the radiator from the beginning. I live in Ohio and winter took it's toll on mpg until I found this hack here on PriusChat.
    This fall I got new tires, I ordered the same tires as before, which gave me excellent service. I did note a 5% drop in mileage with the new tires. The last couple of tanks of gas have yielded substantial losses of mpg from around 66 to 53 mpg. The last tank, I noticed the highway mpg was very similar to the city driving mpg, which is incredible to me as it always in the past was MUCH easier on gas during city driving, in fact displaying 70 mpg frequently when not engaging in any highway driving... I'm wondering what beside tires, winter gas formulation, mpg calculation would be causing this?
    I drive the Prius to near empty every tank, when the 'low fuel' light comes on, I have always gotten at least 100 more miles. I always do this, driving to near empty, rarely do I fill up before this, I would guess less than 10 times I have added gas before the low light has come on. I've calculated my mileage separate from the displayed value many times and have found it to be about 2 mpg less than the displayed value consistently. This car has had 4 sets of tires, and this is the first time I've had a drop in mileage that I can recall.
    With this many miles, I'm wondering what I can do to restore my mileage and what it would cost, or perhaps just leave as is and continue to observe. Please share your high mileage Prius experience with me, perhaps you have an anecdote that will help me decide what to do next.
    #1 al espenschied, Nov 28, 2025
  2. BiomedO1
    4,019
    2,109
    SacTown, Ca
    All that rain and cold snap you've been experiencing over the past month may have something to do with this? Perhaps some fuel contamination or sticky calipers?
    Just spit-balling here....
    Bill Norton likes this.
  3. bisco
    52,286
    can you tell us what services have been performed over the lifetime of the car? there are so many things that can affect mpg's.
  4. al espenschied
    Ohio
    Historically, it's not a lot of cold or rain - I'm getting into 48 mpg on the highway, typically this level has only occurred with temps around 0 F, it was 30 F last night when I was seeing this.
    The services I have done myself, I did have the Dealer replace my exhaust catalytic converter and heat exchanger in July, afterward my mileage was normal as stated above. I did all my own oil changes and changed out the cooling fluids in inverter and radiator. Ran fine afterward, and the problem just happened last week, 2 tankfuls of gas, now the third one just started on the 26th.
    I'm guessing my battery is failing, I'm told I will know for sure when I get it scanned. The car sat for a year in 2021-2022, I understand this is hard on hybrid batteries. I haven't done the recommended services on this at all. Never had any problems until this year, over 200K miles.
    #4 al espenschied, Nov 28, 2025
  5. bisco
    52,286
    you might look into things like throttle body cleaning and etc.
  6. BiomedO1
    4,019
    2,109
    SacTown, Ca
    so no spark plugs or air filters changes????? If the gap has widened on those plugs, it's going to run less efficiently. Ditto with a weak traction battery; usually discharges and recharges at a faster rate than 'normal'.
  7. al espenschied
    Ohio
    Yes, air filter changes along with oil changes every 13 to 15k miles, oil filter changed every oil change. Rotated tires also, always even wear on them as far as I can tell. I failed to state above, that at the same time I changed the coolants, I changed the ATF, All the fluids were from Toyota for my model.
    Yes, I see the rapid discharge of the battery, and also the rapid charge of the same, but it is not especially pronounce, to put another way, I need to actually time it to be sure it is taking longer. A diagnostic for the battery I read on a non-Toyota website is to start the hybrid system and time how long it takes for the ICE to shut off, if it runs for longer than 2-3 min, it may be failing. I called a retail battery replacement place, Green Tec,, the salesman said that it is diagnosed for sure with an OBD reader, I'd like to know for sure if this is true, I read some negative reviews of their batteries, as they did not last long or expired just out of warranty.
    I am concerned about the spark plugs, but I'm not an expert mechanic, not even close, I worry that I might break the plug or knock dirt into the cylinder - it's run perfectly up until now, and I don't hear any misfires. I don't trust Toyota service, and have reason not to. I only used them for my converter replacement because my trusted mechanic wouldn't do this job, as he had a contract for farming out exhaust work to a nearby exhaust specialist shop.
    #7 al espenschied, Nov 28, 2025
  8. al espenschied
    Ohio
    Is there a "How to" on throttle body cleaning?
    FWIW, my engine compartment is cleaner than any vehicle I'n ever owned, and no visible leaks at gaskets on the upper half of engine and no oil traces on my lower cover or garage floor.
  9. bisco
    52,286
    yes, there are threads here, i'm not sure about gen 4, or if it's different in any way. there should also be youtube videos available
  10. BiomedO1
    4,019
    2,109
    SacTown, Ca
    A misfire means the cylinder is completely DEAD - no combustion. A weak spark means partial combustion, less power - meaning more gas needed to do the same job. Isn't that what you were asking about, more fuel being burned?
    Ditto with the traction battery. Around 28 batteries in series; you get a few weak batteries that isn't pulling it's weight, those other batteries in the chain needs to make-up for them - ergo the faster than normal discharge and recharge cycles. I don't know if the Dr Prius app is still free, that'll scan your pack an give you an idea of it's condition. IMHO; don't do a refurbished pack - get a new one if your going to keep the car. Less headaches and hassles in the long run. That's why there's bad reviews on Green Tec; swapping out old batteries with other old batteries is a crap-shoot. It's not like a mechanical part that you can see it's too worn-out to be reused.
    #10 BiomedO1, Nov 28, 2025
  11. al espenschied
    Ohio
    My response last week didn't post for some reason.
    Thanks for the info on spark plugs.
    I've been working on getting the battery to perform better, and watching lots of video about battery maintenance, refurbishing and replacement. I think I could replace all my cells if need be, but first I;ll try to see what it would cost to balance and recondition the battery, I read it would take up to 3 days to do, which would be alright if it is reasonable - not many places do this in Ohio. Today my car is running at around 57MPG, not too shabby for this weather. But historically this should be over 60. So it's really close now, but I wonder what caused the sudden drop, and if a recondition will help me get a couple more years out of this battery in the 60's mpg range, I can switch to LiFePO or sodium pack when they get the tech working better for them.
  12. BiomedO1
    4,019
    2,109
    SacTown, Ca
    IMHO; I would prioritize the spark plug replacement - since that's way overdue and an obvious cause to your problem. I wouldn't be wasting my money, time, and effort chasing after 3-mpg that could be explained by weather change or air density drag, or weak spark. If you want to place this argument into mathematical terms; that's 30 miles/tank (3x10 gallons) - so actual cost is $3. Is it worth your money, time, and effort going after that $3 a tankful of gas?????
    You've stated that you do your own maintenance; I'm assuming you don't have a mechanical background and you've learned how to do this from watching videos. Well you don't know what you don't know - It might be time to take the car to a professional experienced shop for a full inspection. They may find something obvious that you've overlooked.
    Why was the CAT replaced, was the exhaust gas heat exchanger leaking?
    #12 BiomedO1, Dec 7, 2025
  13. al espenschied
    Ohio
    Thanks for the reply.
    Yes the CAT was leaking cooling fluid.
    I have found the "professionals", especially in recent years, to be over rated.
  14. If you're running a Nickel cell car from the factory, the Nexpower Sodium Ion is a great upgrade for Gen 4.
  15. Bill Norton
    Bill Norton Senior Member
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    Some Gen 4's had Ni-Mh packs and some had Li-ion, so don't be going after a pack replacement without thoroughly determining a problem there.
    And be aware that 'reconditioned' Ni-Mh packs are not reconditioned at all. Their age remains the same. All they can do it find 'Modules' with similar capacities and assemble a pack from those. There is no way to test them at the individual cell levels.
    I would think Li-ion packs are much easier to find a bad cell or two and deal with that accordingly.
    'Iron man priuis'----
    Why are you recommending a sodium pack when you are using a Li-ion after market pack?
    BiomedO1 likes this.
  16. BiomedO1
    4,019
    2,109
    SacTown, Ca
    I've found the same; but there are good ones out there - unfortunately 10x more that just hang a shingle and call themselves a professional. If you take your car to a shop because of low prices and discounts, there's a really good chance that they are 'professional' in name only. Excellent mechanics don't need to advertise or give away discounts, because they already have more work than they can handle.
    My last decade of training people, their resumes looked great; but they didn't know which way to turn a wrench to loosen a bolt. The sad commentary is that you could've strangled them with a plastic bag without tying their hands down. That's usually the picture that jumped into my head when they do something really stupid. Had to retire before I actually did that to someone. It's kinda like turkeys that drown in the rain because they keep looking up.
    As far as replacing the traction pack goes, does it make any sense to spend $3K+ for NO guarantee of getting that 3 addition mpg back?
    It's your money, spend it as you please.........
    I've already broke it down for you - your losing $3 per a tank of gas. So that makes 1000 tankful of gas to get you to your breakeven point. At 50 miles per gallon, so 500 miles per tank, 500,000 miles on that pack just to break even - What's the likelihood of that??????
    Good Luck on your future endeavors...
  17. Mendel Leisk
    41,826
    Video #14 here will be helpful, shows the steps to access the throttle body, and he cleans it in-place. My preference is to remove the hold-down nuts and bolts (2 of each) and lift the throttle body, just makes it easier to clean thoroughly. You need to disconnect the electrical connector, but you don’t need to pull off the coolant hoses: they have sufficient slack to leave as-is, avoids spilling coolant. When reinstalling, torque is 7 ft/lb, a 1/4” drive torque wrench would be appropriate.
    incidentally, video #13 (same location) is spark plug replacement. Again, the preponderance of the video is parts removal, just to get to the plugs. One thing, he applies anti-seize liberally to the plug threads, and says to torque to 20 ft/lb’s. I would stick to repair manual recommendation: 15 ft/lb, and it makes no mention of applying any sort of grease, so presumably clean, dry threads.
    attachments show throttle body and spark plug torque specs:
  18. VelvetFoot
    VelvetFoot Active Member
    1,134
    448
    New York State
    2026 Prius
    If nothing else, this shows how keeping track of economy over the years can give one an early warning of a problem.
    You would think if you're not getting any DTC's, (you've read for them, right?), the car thinks it's still running in tolerance.
    How about first going for the low hanging fruit, like brakes, including parking? I'd say diagnosis is key, before throwing money (and time) at it, willy nilly.
