12V battery isolator/switch
Discussion in 'Gen 2 Prius Main Forum' started by priumium, Dec 4, 2025 at 12:06 PM.
  1. priumium
    priumium Member
    176
    37
    Sweden
    I finally tested to install a battery switch for the negative/ground terminal on the annoying trunk battery placement in my gen 2s.
    I wish to recommend this to everyone DIY since it makes me able to cut power over winter or when doing maintenance work without even removing one piece of the trunk pieces.
    Just by opening the right backlight cover I am now able to reach this switch and cut 12V. This might have been posted before, but I failed to find anything like this.
    I bought one version from temu first, this had the best design in my mind. I had to grind the pole down a bit, but this version has adaptable screws that easily fits the small sized poles that the Prius uses and locks them into place real good.
    #1 priumium, Dec 4, 2025 at 12:06 PM
    VelvetFoot and bisco like this.
  2. PriusCamper
    PriusCamper Senior Member
    12,748
    5,156
    Pacific Northwest, USA
    That's a great looking design but there's no way I'll buy it from Temu. I wonder who else sells them?
  3. priumium
    priumium Member
    176
    37
    Sweden
    (Why not temu? Tariffs? Sex dolls..?)
    For your information I have failed to find this much smarter design anywhere else. Contact the seller directly and ask, it seems like a very much smarter version with the screws.
    I bought four different designs from AliX and the other ones are all to big for the poles and are also hollow (bad for grinding) and without screws! Easily fixed with a drill, but I have now bought three of these instead.
  4. priumium
    priumium Member
    176
    37
    Sweden
  5. Mendel Leisk
    41,427
    There are also switches that don't directly connect to the battery posts. Depends on the application, ease of access.
  6. pasadena_commut
    pasadena_commut Senior Member
    2,623
    776
    Southern California
    Yeah. If I was going to do this I would pick up a battery to ground cable at the junk yard and splice a switch into it.
  7. priumium
    priumium Member
    176
    37
    Sweden
    Those are marine versions and are good, but the switch is then loose unless you fasten it to something sturdy. That’s a big plus of this design (pun).
    This was flawless in my mind. Reachable from the lower cover.
  8. VelvetFoot
    VelvetFoot Active Member
    637
    225
    New York State
    2026 Prius
    Even on an older Prius, don’t you lose some settings when you disconnect the battery?
    also, do you have a link for the posted picture?
  9. priumium
    priumium Member
    176
    37
    Sweden
    Indeed, radio channels, clock and so called learned values are reset. That might be befinitial in some scenarios.
    I am not sure how fast this happens, Toyota states 90 seconds to empty all current.
  10. ChapmanF
    18,160
    Hold on a sec. Are you thinking this happens while the car is off?
  11. priumium
    priumium Member
    176
    37
    Sweden
    No, I do not, but running short trips when the battery is in bad shape or has been emptied previously and lost 80 percent capacity to store the charge, the hybrid battery will waste many A on it, especially when below zero.
    When stored the 12V gets destroyed due to many many factors. It’s even in the manual to disconnect it when storing for more than a couple of weeks, as you know. When big subzero, this value can be a few hours..
    #11 priumium, Dec 7, 2025 at 5:51 AM
  12. Mendel Leisk
    41,427
    Maybe in your translation? Just curious, I don’t recall seeing that in the North American owners manual.
  13. VelvetFoot
    637
    225
    New York State
    2026 Prius
    This dude is in Sweden. It gets cold in Sweden. :)
    edit: Then again, it gets cold in Canada....
