Gen 2 jump start question:
Discussion in 'Gen 2 Prius Main Forum' started by priusrust, Dec 7, 2025.
  1. priusrust
    priusrust Member
    216
    79
    MA
    Hello,
    To jump start a Gen 2 Prius, you hook jump battery cable to 'positive' tab inside fuse box under front hood, and ground at recommended spot close by.
    My question is: can you alternatively jump directly to the 12 volt in back of the car? I assume you can, but want to avoid blowing up car :)
  2. pasadena_commut
    pasadena_commut Senior Member
    2,776
    831
    Southern California
    Yes, you can jump there. Just like you can swap the discharged battery for a new battery and the car will start again (if the battery is the only problem.)
    I would be careful though that bare metal on the positive clamp on the jumper cable is nowhere near any bare metal on the chassis, that it is firmly attached, and the negative cable should not be attached when the positive is placed. Lots of sheet metal, bare bolts, and I think even some bare metal nearby. It would be bad if the positive cable popped off and hit any of that while the negative cable was attached. Find a nice big bolt elsewhere in the trunk (NOT the normal battery ground bolt) to attach the ground clamp on that cable. I wouldn't go straight onto the negative post, just in case something goes dreadfully wrong with the battery in the car when power hits it. You really don't want to be leaning over a battery if that happens. (Do AGMs ever blow up, maybe that is just a flooded lead acid battery problem?) The problem with the normal ground bolt is that it is tucked back in an awkward place posterior to the battery, and it seems fairly likely to me that a cable clamped to it might pop off.
  3. PriusCamper
    PriusCamper Senior Member
    12,986
    5,281
    Pacific Northwest, USA
    Yes, no problem... Main issue with Prius is if you get polarity reversed you damage the car.
    priusrust likes this.
  4. priusrust
    priusrust Member
    216
    79
    MA
    Thanks, mission accomplished worked fine. I actually did carefully clamp neg jumper to neg post...lived to type this! Hate parting with my gen 2. It has 199,200 miles. Engine fine, uses no oil, recent OEM traction battery. (3 yrs) Love reading the gen 2 manual. simple, logical. unlike my 2016 manual of tangled minutia !!
  5. lexidium
    lexidium Active Member
    300
    141
    manchester
    just jump stared mine on the battery at the back with one of those small boosters with the capacitors in.
    The only difficulty was that I couldn't open the hatch because of the flat battery so had to crawl inside and release the catch by hand.
    That's a pain in the arse when you are my age. :):(
    priusrust and bisco like this.
  6. VelvetFoot
    VelvetFoot Active Member
    1,135
    448
    New York State
    2026 Prius
    Was the booster in the trunk? You couldn't jump it from under the hood?
  7. priusrust
    priusrust Member
    216
    79
    MA
    Ha! I had to do the same! agree ....not designed to be spine injury friendly.
  8. bisco
    52,286
    if you put 12 volts to the jump point under the hood, the hatch will open
    priumium and Brian1954 like this.
  9. lexidium
    300
    141
    manchester
    I've read several people saying not to try and jump it from the front so I didn't.
  10. ChapmanF
    18,458
    Did any of them elaborate on why they were saying not to try it there?
    That's like literally where Toyota designed the electrical system for you to jump it.
  11. qmanqman
    qmanqman Active Member
    439
    152
    CO
    Yup. First time I jumped a Prius I dug out the battery in the rear. Then I had the bright idea to read the owners manual and laughed at my ignorance.
  12. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    To add to all great info here, adding a string to the emergency opener in the trunk might be lame, but relevant.
    @bisco Just to clarify, can I attach a ie CTEK charger that is grounded and this trick will open the trunk?
  13. ChapmanF
    18,458
    To avoid any possible confusion, putting a 12-volt source at the jump point under the hood will supply power to the car, including the unlocking circuits, so you can then go back and open the hatch in the usual way by pushing its button (if you have all-door 'smart key', or if you've pushed the fob unlock button first). It's not really any kind of a 'trick', it doesn't change any normal behavior, and it won't make the hatch pop open by itself.
    priumium likes this.
  14. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    Ok, thanks for the clarification. My hope of having another solution to not climb into the trunk and pull my string has been crushed.
    (But I could then likely supply 12V at jump point while removing the battery to prevent this lock (that trunk lock seem to only be there to force validate the key code after reconnecting? Or more likely due to the constant lock structure of the trunk when I think of it, that would be very annoying if applied to any entry door….)
  15. BiomedO1
    4,019
    2,109
    SacTown, Ca
    Your also assuming that whatever your trying to power with the CTEK cable isn't going to exceed the 7.5A-10A fuse for that circuit. Unlocking doors is doable; but don't expect to use it as a jump-point - you'll most likely pop the circuit fuse. Ditto if you have one of those trunk lid lifts.
    Just my two cents...
  16. Mendel Leisk
    41,826
    If I want to preserve the car's settings, say during a battery replacement, I lay this in the driver's seat footwell:
    (Clore Automotive Jump-N-Carry JNC660 1700 Peak Amp 12 Volt Jump Starter)
    Then, plug this into it's 12 volt port (circled in above):
    (Clore Automotive Solar ESA30 OBD II Memory Saver Connector)
    And plug the other end into the car's OBD port. It only has the necessary pins to supply power.
    The cable also has an indicator light, which will light if you've made a single good connection, so good to connect first to one end, then the other. There are other cables available with an indicator light at both ends, a little less cumbersome: you don't have to trial-connect both ends individually.
    priumium and VelvetFoot like this.
  17. ChapmanF
    18,458
    Crushed, how?
    Pop the hood, attach jump box to jump terminal, walk around behind car, open hatch.
    How does that crush the hope?
    jonsey1886 likes this.
  18. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    Well, my oldest gen2 2005 SKS has a strange issue with the trunk not unlocking with 12V switched/re-attached and the unlock button on fob pressed, even long or twice as mentioned in the manual and on techstream. Any tips there? My 2007 always behaves.
  19. pasadena_commut
    2,776
    831
    Southern California
    Interesting, but more details needed.
    1. The hatch unlocks with the switch on the driver's door under normal 12V battery conditions?
    2. The hatch unlocks with the switch on the driver's door after 12V restored (as at the jump point)?
    3. Other than the hatch failing to unlock after 12V restored, do all the fob buttons do what they are supposed to?
    4. Do all the fob buttons do what they are supposed to under normal 12V battery conditions?
    5. When 12V has been reapplied and the unlock button on the fob pressed do all the doors unlock even though the hatch does not?
    6. When 12V has been reapplied, if the fob "lock" key is pressed a couple of times, if "unlock" is then pressed, does the hatch unlock?
  20. AzWxGuy
    AzWxGuy Weather Guy
    1,065
    547
    Tucson, AZ
    2021 Prius
    I remember an older thread about this. If you look closely at the battery positive jump point inside the fuse block in the engine compartment, you will see that it makes use of a plastic vertical support fin to hold the positive connection plate. That plate is only on one side of the fin. When connecting the typical jumper cable clamp, one should always make sure that the side of the clamp that meets the plate is also the side that has the cable in the insulated handle. Otherwise there may be a significant addition of resistance when the current attempts to pass through the clamp's spring-loaded rotation point to get to the other side of the clamp. Especially significant if your jumper cables are old and rusted.
