Gone in 60 seconds! No key required
Discussion in 'Fred's House of Pancakes' started by Stevewoods, Dec 7, 2025.
  1. Stevewoods
    Stevewoods Senior Member
    662
    1,147
    Seattle, WA
  2. BiomedO1
    3,777
    1,968
    SacTown, Ca
    The thieves electronically rekeyed or added another fob to the trucks' ECU. You noticed the thieves crawled through the window instead of opening the door - that would've triggered the car alarm and a 5 minute lock-out unless you cancel the alarm with an existing fob. Adding a tremble and/or glass breakage switch may have avoided this thief. A smart thief would run away as soon as an alarm is triggered. If they find that car, they can see who's credentials was used to add the fob. We leave electronic fingerprints everywhere, that's why your not suppose to share your electronic access credentials.
    I had a cheap department manager try to make me give up and share my credentials with the rest of our shop after I got back from training. I told him to put that in writing and I also need an official letter drafted by our company lawyers, that I will not be held accountable if someone reprograms a system and it results in injury or death of someone. I never got that letter.:cool::p
    The second thief shouldn't have happened to begin with; IMHO. Relay spoofing a fob is well known and could've easily been avoided by placing the fob in a metal box or fariday bag.
    Live and learn......:whistle:
  3. futurist
    futurist Member
    42
    73
    United States
    2024 Prius
    Just got my promised second key, programmed at the dealer. Don't have to tell you, unless pressed into service, that fob will never leave my faraday box (except to pull out and check for battery-good, every month or so) :cautious:
  4. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    If someone wants you vehicle it will be gone in less than a minute...regardless.
    Skiddmore likes this.
  5. BiomedO1
    3,777
    1,968
    SacTown, Ca
    you can turn-off that secondary fob, once you make sure it works and the back-up manual key works.
    option #2 on the link.
    How to Disable Your Toyota's Smart Key System (3 Easy Methods)
    futurist likes this.
  6. bisco
    52,068
    another reason not to move to LA
  7. ETC(SS)
    7,216
    Outlaw Tow Trucks!!!
    BiomedO1 likes this.
  8. Mendel Leisk
    41,628
    Were physical keys better for security?
  9. ChapmanF
    18,300
    futurist and BiomedO1 like this.
  10. BiomedO1
    3,777
    1,968
    SacTown, Ca
    FWIW; the news last night stated that CAT thieves are now targeting older RX series-Lexus.
    I guess you'll have to look-up how to disable the fob on newer Prius.
  11. BiomedO1
    3,777
    1,968
    SacTown, Ca
    Not really, that's why OEM's added steering locks, chipped keys, and The Club. Where's there's a will, there's a way....
    futurist and Mendel Leisk like this.
