2024 PRIUS XLE AWD TPMS SENSOR QUESTION
Discussion in 'Gen 5 Prius Technical Discussion' started by longshot, Nov 26, 2025.
  1. VelvetFoot
    VelvetFoot Active Member
    644
    228
    New York State
    2026 Prius
    Good luck!
    My motto is "Nothing's Easy".
    longshot likes this.
  2. Gokhan
    Gokhan Senior Member
    6,196
    2,452
    Paramount CA
    Well, it was a long shot, @longshot. :p
  3. VelvetFoot
    644
    228
    New York State
    2026 Prius
    @longshot :
    If nothing else, others will learn from your experience. :)
    Gokhan likes this.
  4. Gokhan
    6,196
    2,452
    Paramount CA
    According to the FCC IDs, they are all 314.98 MHz.
    Interestingly, Pacific Industrial Co., Ltd. also manufactures them in the US (the part numbers with letters in them).
    Genuine OEM Toyota 42607-33050 TPMS Tire Pressure Monitoring System Sensor | eBay
    Genuine OEM Toyota TPMS sensor 42607-0E090 Fits Camry, Corolla, Grand Highlander | eBay
    FCC ID PAXPMVC015
    FCC ID PAXPMVG001
    VelvetFoot likes this.
  5. longshot
    longshot Junior Member
    83
    Update: Bought a set of 315mhz off Amazon which showed the factory part # as well as others these would work on. Drove 45 min or so. Car didn't pick them up.
  6. VelvetFoot
    644
    228
    New York State
    2026 Prius
    Crap. Nothing's easy.
  7. KMO
    KMO Senior Member
    1,957
    683
    Finland
    2023 Prius Prime
    Getting the correct original part fitted at a Toyota dealer would be easy.
    Touring the cheapest possible clones could save you money, but it's going to cost you effort.
    I don't actually recall any success stories here of Toyota compatible TPMSs being auto-detected - do they always clone the old style?
    And at least the first listing in question was honest and did say that they'd need OBD programming - unlike their listings for some other brands they said would be auto-detected. Did your new listing claim auto-detection?
    At this point, it would make sense to start trawling through the cheap knock-off Amazon OBD tyre programming tools - you've got more chance of finding one of those that works than finding auto-detectable TPMS clones.
  8. Gokhan
    6,196
    2,452
    Paramount CA
