Michelin CrossClimate 3 being released - contact Michelin to encourage them to make it for Prius
Discussion in 'Gen 5 Prius Main Forum' started by Hammersmith, May 23, 2025.
  1. Hammersmith
    Hammersmith Senior Member
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Michelin has just announced the new CrossClimate3 and CrossClimate3 Sport for Europe(North America sometime later). The CC2 is arguably the best all-weather tire on the market, but it doesn't come in Prius sizes. With Michelin coming out with the CC3 and CC3S, maybe we can influence them to consider us poor Prius owners. ;)
    Certainly can't hurt to drop them a line and let them know there's interest.
    Contact us form
    otatrant likes this.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I tried winter tires, which have a special rubber compound that grips on ice at temperatures below freezing (depending on formulation) I believe. The downside of this, I found, is that the tires become very slippery at temperatures higher than this. So much so, that I was often getting stuck on level, snow surfaces. The car appeared to have zero traction, and the tires would spin out in a small depression, leaving the car immobile.
    This did not happen with the all-season tires I had on. I was able to easily manage on all the road surfaces I encountered throughout the winter. Safety trolls will no doubt gang up to tell me I'm stupid, but I find all-season tires to be safer overall.
  3. Hammersmith
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yes, that's the point of an all-weather tire. (note that we're using the North American definitions, not the European ones)
    Basic tire categories:
    Summer - great on dry and wet; made for temps above 40F/5C; terrible on any snow/ice
    All-season - made for dry, wet, and mild snow; best at temps above 0F/-15C
    Winter - great on snow and ice; not for use above 40F/5C
    All-weather - truly made for all seasons - wet, dry, med/heavy snow & ice; good at all temps; not quite as good on wet/dry as dedicated summer tires or as good on snow/ice as dedicated winter tires, but very close with no serious weaknesses
    Which category you go with depends on your conditions. I'm currently going with all-season during the summer(the stock Toyos) and winter tires for winter(Mich X-Ice Snow). But I don't really put on enough miles to justify two sets of tires(they will get too old before they wear out). All-weather tires would be perfect for my case, but nobody makes them in stock Prius sizes.
    General rule of thumb in areas where all-seasons aren't really enough in winter:
    12k miles/20k km per year or less- definitely 1 set(all-weather)
    15k miles/25k km per year - borderline
    18k miles/30k km per year or more - definitely 2 sets(all-season + winter)
    otatrant and mva like this.
  4. soft_r
    soft_r Active Member
    178
    142
    Beverly Hills
    2024 Prius
    Honestly I'm glad I sold my stock wheel setup and grabbed some light weight 16s and CC2s. Winter driving has been great and I've got enough tread wall where I have very little concern over wheel damage. Even just on wet roads there is a noticeable difference in grip. Had a couple light oversteering on wet roads with the stock tires but same roads, weather, and speed with the CC2s never have an issue.
  5. sufyant
    sufyant Junior Member
    39
    2024 Prius Prime
    XSE Premium
    what rims are those and where did you get them from?
  6. Zeromus
    Zeromus Active Member
    553
    307
    Ottawa Canada
    2024 Prius Prime
    SE
    Not entirely true on the rule of thumb depending on where you live.
    In Quebec, winter tires are required by law, and I get a discount on my insurance here in ontario with winter tires for the winter months as well.
    They tend to perform better through most of the winter and it regularly gets down below -10 to -15C. So swapping the tires, even though we average 15k km a year on the main car, works well for us.
    Unless of course, I'm misunderstanding and all weather tires qualify for winter tire benefits under the laws and insurance discounts as well.
  7. Hammersmith
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    First, a small rabbit hole...
    Like most everything else, "all-weather" is really just a marketing term. That being said, all the quality brands make all-weather tires that qualify for the three-peak mountain snowflake symbol (3PMSF), a.k.a the Alpine symbol. There are probably some low-quality brands that label tires all-weather but without the symbol, but I don't pay much attention to that segment of the market. (I've had enough bad experiences that I now view it as tires=life and I don't skimp on them.)
    now to the point...
    I can't speak for Canada, but I understand that having the 3PMSF rating means all-weather tires that have it qualify as winter tires in at least some(all?) states where winter tires are required.
  8. Mendel Leisk
    41,430
    Michelin's going to look at 5th gen Prius sales volume, how many other cars have that size, and of those groups, how many are looking for an all-weather option. In other words, see if it's worth it.
    daisy555 likes this.
  9. Hammersmith
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Sizes for the CrossClimate 3(CC3) and CrossClimate 3 Sport(CC3S) are starting to come out of Europe. There will be a combined total of 186 sizes available by the end of 2026. 130 CC3 sizes, 60 CC3S sizes, with only 4 sizes coming out in both. Currently, 53 of the 130 CC3 sizes have been announced, and 28 of the 60 CC3S. No way to know yet if all 186 sizes will make it to North America, but we can hope.
    Neither stock Prius size is on the list yet, but the 205/55-17 that is on the list would work fine on the stock 17" wheel. There's also a CC3S in 225/40-19 that is probably a touch too wide for the stock wheel but is almost the same outside diameter if you switch to a slightly wider wheel. FYI, the CC3S will be limited to 18"-23", so there won't be any CC3S for the 17" wheel.
    17" - MICHELIN CROSSCLIMATE 3 - Car Tyre | MICHELIN United Kingdom Official Website
    19" - MICHELIN CROSSCLIMATE 3 - Car Tyre | MICHELIN United Kingdom Official Website
    19" - MICHELIN CROSSCLIMATE 3 SPORT - Car Tyre | MICHELIN United Kingdom Official Website
    First testing (CC3 vs. CC3S vs. Pirelli Cinturato All Season SF3 vs. Bridgestone Turanza All Season 6
    Julio_E and otatrant like this.
  10. GeoJ
    GeoJ Active Member
    204
    187
    United States
    2023 Prius Prime
    XSE
    Anyone know updates on this? And, wondering, is there a CC3 that fits the 19" wheels? Thanks.
  11. notspam3
    notspam3 Junior Member
    36
    Toronto
    2024 Prius Prime
    XSE Premium
    All-season tires are 3-season tires.
    If you get a lot of black ice conditions try the Michelin X-Ice - they work really well, ride like an all season tire and have good fuel economy. If you drive in a lot of deep snow and slush and unploughed roads get the Bridgestone Blizzak WS90. They have a softer ride, worse fuel economy and sluggish handling but better deep snow/slush traction. I have first hand experience with both and prefer the X-Ice for our mostly highway use here in the snow belt in southern Ontario.
    To the OP: I use the X-Ice on all my vehicles with dedicated 16" wheels...it's easier to find tires for 16" wheels over the 19". Buying 19" wheels for winter tires is a waste of money in my books. What you save on rubber you can buy a set of dedicated steel wheels for your winter tires.
  12. GeoJ
    GeoJ Active Member
    204
    187
    United States
    2023 Prius Prime
    XSE
    Well if the X-ice truly ride like an all season and have good fuel economy, why not just leave them on year round if you live in areas where it snows?
  13. Mendel Leisk
    41,430
    Some do around here. I’d think they’d wear fast in the heat of summer (due to softer rubber formulation), still, it’s simpler, one set of rims, which counts for something.
    GeoJ likes this.
  14. Gokhan
    Gokhan Senior Member
    6,196
    2,452
    Paramount CA
    LOL
    I have been more than happy with my OEM Dunlops. I just got a new set before they even half wore out. Besides, the fuel economy with this “world’s best tire” will suck, which is what I care about most.
  15. mingc
    mingc Member
    40
    26
    Portland, OR
    2023 Prius
    XLE AWD-e
    Michelin USA has since announced that that the CrossClimate 3 isn't coming to North America anytime soon and that it will continue to sell the CrossClimate 2 "for the next several years":
    MICHELIN CROSSCLIMATE 2 - Vehicle Tires | Michelin USA (last FAQ on the page)
  16. Mendel Leisk
    41,430
    And that comes in the size you need?
