Gen 2 jump start question:
Discussion in 'Gen 2 Prius Main Forum' started by priusrust, Dec 7, 2025 at 3:11 PM.
  1. priusrust
    priusrust Member
    204
    73
    MA
    Hello,
    To jump start a Gen 2 Prius, you hook jump battery cable to 'positive' tab inside fuse box under front hood, and ground at recommended spot close by.
    My question is: can you alternatively jump directly to the 12 volt in back of the car? I assume you can, but want to avoid blowing up car :)
  2. pasadena_commut
    pasadena_commut Senior Member
    2,624
    777
    Southern California
    Yes, you can jump there. Just like you can swap the discharged battery for a new battery and the car will start again (if the battery is the only problem.)
    I would be careful though that bare metal on the positive clamp on the jumper cable is nowhere near any bare metal on the chassis, that it is firmly attached, and the negative cable should not be attached when the positive is placed. Lots of sheet metal, bare bolts, and I think even some bare metal nearby. It would be bad if the positive cable popped off and hit any of that while the negative cable was attached. Find a nice big bolt elsewhere in the trunk (NOT the normal battery ground bolt) to attach the ground clamp on that cable. I wouldn't go straight onto the negative post, just in case something goes dreadfully wrong with the battery in the car when power hits it. You really don't want to be leaning over a battery if that happens. (Do AGMs ever blow up, maybe that is just a flooded lead acid battery problem?) The problem with the normal ground bolt is that it is tucked back in an awkward place posterior to the battery, and it seems fairly likely to me that a cable clamped to it might pop off.
  3. PriusCamper
    PriusCamper Senior Member
    12,751
    5,160
    Pacific Northwest, USA
    Yes, no problem... Main issue with Prius is if you get polarity reversed you damage the car.
    priusrust likes this.
  4. priusrust
    priusrust Member
    204
    73
    MA
    Thanks, mission accomplished worked fine. I actually did carefully clamp neg jumper to neg post...lived to type this! Hate parting with my gen 2. It has 199,200 miles. Engine fine, uses no oil, recent OEM traction battery. (3 yrs) Love reading the gen 2 manual. simple, logical. unlike my 2016 manual of tangled minutia !!
  5. lexidium
    lexidium Active Member
    297
    139
    manchester
    just jump stared mine on the battery at the back with one of those small boosters with the capacitors in.
    The only difficulty was that I couldn't open the hatch because of the flat battery so had to crawl inside and release the catch by hand.
    That's a pain in the arse when you are my age. :):(
  6. VelvetFoot
    VelvetFoot Active Member
    650
    230
    New York State
    2026 Prius
    Was the booster in the trunk? You couldn't jump it from under the hood?
  7. priusrust
    priusrust Member
    204
    73
    MA
    Ha! I had to do the same! agree ....not designed to be spine injury friendly.
  8. bisco
    51,906
    if you put 12 volts to the jump point under the hood, the hatch will open
    Brian1954 likes this.
