Doctor Prius battery
Discussion in 'Gen 2 Prius Main Forum' started by bigblockcutlass, Dec 7, 2025 at 6:16 AM.
  1. bigblockcutlass
    bigblockcutlass Junior Member
    33
    But of course.
  2. Carall
    Carall Active Member
    314
    104
    Harrisonburg, VA
    Things worn out in this world, especially if they are batteries over 20 years old. And they wear out in different ways under different conditions of use.
  3. bisco
    51,908
    are there 2 dr. prius? it is confusing
  4. PriusCamper
    PriusCamper Senior Member
    12,755
    5,164
    Pacific Northwest, USA
    It's not a myth if you have good enough equipment to accurately measure capacity after reconditioning and have a large module library so you can group together modules that are near the same capacity. The best rebuilders can offer a 3 year warranty and not lose money doing that.
    But yes, from a capitalist perspective a Toyota Stealership will only sell brand new packs even if the only problem with original pack is a corroded sensor wire that takes 5 minutes to fix... Ripping people off as much as possible is the highest moral virtue of a capitalist society.
  5. PriusCamper
    12,755
    5,164
    This is just a battery rebuilder in Tennessee.
    Dr. Prius app is looking into trademarking "Doctor Prius" but its difficult because obviously "Prius" is already trademarked. Originally it was going to be called Dr. Hybrid app for these reasons, but then Toyota corporate said they were ok with 3rd party use of Dr. Prius.
    ericbecky and bisco like this.
  6. Carall
    314
    104
    Harrisonburg, VA
    I meant that balancing a 2004 module with a 2015 module can sometimes be compared to trying to weld a piece of metal that is rusty to the core with rust-covered metal.
  7. PriusCamper
    12,755
    5,164
    Unless you're welding pre WW2 metal to Post WW2 metal its easy to do it at maximum strength and eliminating rust is the equivalent of reconditioning and disposing of any module with a weak cell...
    qmanqman likes this.
  8. qmanqman
    qmanqman Active Member
    431
    146
    CO
    Ya that doesn't make it a myth. My '07 has 155 kmi and daughter's has 325 kmi and both sets of OE batteries are still fully functional. And with my ignorance on batteries I'm figurin you just have to mix good with good and toss out the bad.
