Need help finding connecter AL2 and DA2
Discussion in 'Gen 3 Prius Technical Discussion' started by ptrustfull, Dec 8, 2025.
  1. ptrustfull
    ptrustfull Junior Member
    24
    Suriname
    2012 Aqua
    Hello, I'm resurrecting a Prius. I'm in the stage where i noticed that when i connect the scan tool the check engine light turns on. Removing the scanner will turn off the check engine light. I measured the wires at the obd connector and the brown wire nr 5 does not have ground. Since the car was soaked in water i do not only want to check the ground but the complete connector Al2 and DA2. Can you guide me to the connectors?
  2. ChapmanF
    18,457
    DA2 can also be seen in this old pic (showing engine water pump circuits that also run through it):
    frodoz737 and ptrustfull like this.
  3. ptrustfull
    24
    Suriname
    2012 Aqua
    Thank you Chapman F
  4. ptrustfull
    24
    Suriname
    2012 Aqua
    I found both connectors and they were in good shape. The problem was with the ground connectors on the valve cover. Gave them a good clean and all was good. Still no start but we are getting there
