12V battery isolator/switch
Discussion in 'Gen 2 Prius Main Forum' started by priumium, Dec 4, 2025.
  1. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    I finally tested to install a battery switch for the negative/ground terminal on the annoying trunk battery placement in my gen 2s.
    I wish to recommend this to everyone DIY since it makes me able to cut power over winter or when doing maintenance work without even removing one piece of the trunk pieces.
    Just by opening the right backlight cover I am now able to reach this switch and cut 12V. This might have been posted before, but I failed to find anything like this.
    I bought one version from temu first, this had the best design in my mind. I had to grind the pole down a bit, but this version has adaptable screws that easily fits the small sized poles that the Prius uses and locks them into place real good.
    #1 priumium, Dec 4, 2025
    VelvetFoot and bisco like this.
  2. PriusCamper
    PriusCamper Senior Member
    13,104
    5,311
    Pacific Northwest, USA
    That's a great looking design but there's no way I'll buy it from Temu. I wonder who else sells them?
  3. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    (Why not temu? Tariffs? Sex dolls..?)
    For your information I have failed to find this much smarter design anywhere else. Contact the seller directly and ask, it seems like a very much smarter version with the screws.
    I bought four different designs from AliX and the other ones are all to big for the poles and are also hollow (bad for grinding) and without screws! Easily fixed with a drill, but I have now bought three of these instead.
  4. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
  5. Mendel Leisk
    41,951
    There are also switches that don't directly connect to the battery posts. Depends on the application, ease of access.
  6. pasadena_commut
    pasadena_commut Senior Member
    2,885
    863
    Southern California
    Yeah. If I was going to do this I would pick up a battery to ground cable at the junk yard and splice a switch into it.
  7. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    Those are marine versions and are good, but the switch is then loose unless you fasten it to something sturdy. That’s a big plus of this design (pun).
    This was flawless in my mind. Reachable from the lower cover.
  8. VelvetFoot
    VelvetFoot Active Member
    1,245
    487
    New York State
    2026 Prius
    Even on an older Prius, don’t you lose some settings when you disconnect the battery?
    also, do you have a link for the posted picture?
  9. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    Indeed, radio channels, clock and so called learned values are reset. That might be befinitial in some scenarios.
    I am not sure how fast this happens, Toyota states 90 seconds to empty all current.
  10. ChapmanF
    18,590
    Hold on a sec. Are you thinking this happens while the car is off?
  11. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    No, I do not, but running short trips when the battery is in bad shape or has been emptied previously and lost 80 percent capacity to store the charge, the hybrid battery will waste many A on it, especially when below zero.
    When stored the 12V gets destroyed due to many many factors. It’s even in the manual to disconnect it when storing for more than a couple of weeks, as you know. When big subzero, this value can be a few hours..
    #11 priumium, Dec 7, 2025
  12. Mendel Leisk
    41,951
    Maybe in your translation? Just curious, I don’t recall seeing that in the North American owners manual.
  13. VelvetFoot
    1,245
    487
    New York State
    2026 Prius
    This dude is in Sweden. It gets cold in Sweden. :)
    edit: Then again, it gets cold in Canada....
    priumium and Mendel Leisk like this.
  14. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    The instruction is to loose a bolted cable under the jump start red bracket (@hood) and leave cable disconnected if the engine will not be started within 10 days (if stored or very cold).
    I am certain this is not a special instruction for the Nordic’s - but it is likely from another source than the owner manual unfortunately…. I will post this when I find it.
  15. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    It was from a TSB! An early one after gen2 release, attached in full and relevant snippet.
    #15 priumium, Dec 10, 2025
    Mendel Leisk and VelvetFoot like this.
  16. VelvetFoot
    1,245
    487
    New York State
    2026 Prius
    Interesting.
    My takeaways (for a GEN5'er)
    -You can isolate the battery in the trunk by doing something under the hood, for GEN2 at least.
    (Now that I think about it, it makes sense.)
    -GEN2 used AGM batteries. Mine is a flooded model. Progress? :)
    priumium likes this.
  17. Mendel Leisk
    41,951
    Thanks for finding and posting that.
    Interesting, the first attachment in post #15 refers to the proprietary Toyota charger as a “trickle” charger. Granted it’s a misnomer, but some here lose their minds if the term is used incorrectly. Language is an evolving concept, many words came to be because of confusion, or their meaning shifted over time, that’s just how it is.
    #17 Mendel Leisk, Dec 10, 2025
  18. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    This is one version I also tried, made for marine usage and that needs an extra battery/ground cable. Works great but needs to be fastened to be stable and easily reached.
    VelvetFoot and Mendel Leisk like this.
  19. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    I ”love” those TSBs, they are the only source of confirmed Toyota issues.
    Notice for everyone; these TSBs are not any kind of official recall: it’s instructions for dealerships what to do with issues identified after the initial workshop manual was released.
    So they are gold for any DIY in my mind.
  20. Mendel Leisk
    41,951
    That one seems to be directed at Toyota dealerships, how to care for languishing-on-the-lot cars.
    the dealership where we got our 2010 didn’t heed it: ours had a totally-dead battery, build-date was 15 months back. They even tried every trick, to mask its condition.
