1. hendr1x
    hendr1x Junior Member
    US
    Hello everyone,
    Last night my 2011 Prius decided to practice Karate. Took a look at it tonight and it seems like the rear "control arm" is actually one big assembly? So...does anyone know any info about attempting this repair? I assume I have to change the entire thing? Used part is probably best I assume? Brakes, Speed sensor, E-brake, Spring, Struts....all have get moved over. Anything really tricky or am I missing something. Would appreciate any thoughts/suggestions.
    51,916
    do not know if this helps:
    edit: nevermind, that was the front, sorry!
  3. Tombukt2
    12,969
    2,327
    Looks like pretty serious metal damage that's only X arm I don't see it . But it is a horrid picture.stuff un volts but maybe the mounts are more taken out or twisted . Proceed carefully. That vehicle may have to go on a frame machine. It is a thing
  4. Tombukt2
    12,969
    2,327
    I don't think there's any 11 out there that are worth frame table time . Personally.
  5. Mendel Leisk
    41,442
  6. bisco
    51,916
  7. hendr1x
    US
    All the damage is rust. The bottom rotted and then it eventually cracked.
    That's some amazing resources. Thanks everyone but if @MrPete is still around, thanks so much. The vehicle is over all in decent shape. I don't have money for a new car so I don't think I have a choice but to try and fix. I'm not clear, why would replacing the rear axle beam require a frame machine? A couple questions came to mind while I was reading....is there a way to test a strut at home when its not on the car? I guess I can test the other side and see how it is. How about testing the wheel bearings. Is that something you can just feel/hear? Lastly do the springs ever get worn out? This car was never abused...only two owners, me and my father.
  8. Tombukt2
    12,969
    2,327
    Then you probably don't need to test all that stuff you just need to repair the rusted beam axle for the mount points n all . I guess that's what I'm seeing in the picture that I can hardly see that's beam rusted in half more or less
  9. hendr1x
    US
    I think the beam is the main thing. I'll go through the entire vehicle again but I don't think anything is that rusted. Clearly I didn't check that part properly before. I guess I was just thinking what else I should do while I'm in there/things are apart.
  10. Tombukt2
    12,969
    2,327
    Yes that beam is literally the main rear suspension component there's a sway bar thru it 8 believe too various bushes etc
