3D Printed Prius Gen 5 Custom Tray - Glasses Holder with Lid
Discussion in 'Gen 5 Prius Accessories and Modifications' started by priusasa, Nov 23, 2025.
  1. AgentPTFC
    AgentPTFC Member
    58
    40
    PNW
    2025 Prius Plug-in
    XSE Premium
    I would love to add this to my car. On my printer using PLA it estimates over 2 days of printing in the current orientation. Is it possible to provide a model that doesn't have the extra supports added? I'd like to print in a different orientation to see if it shortens that time and filament amount.
  2. priusasa
    priusasa Member
    104
    53
    2023 Prius
    I dont think there is faster than what I oriented. The file I shared on Makerworld, you can delete "cube" objects and leave actual object alone. That would save you just a little bir of time but, if you rotate the object and slice, you will see that it takes more time because it created new supports. Also if you change the oriantation of the object, you will see layer lines visible and it wont look good when the print is done.
    If you really speed up, you need to cut the object half and print 2 pieces. But I have not tried this.
    For me, it takes 13 hour to print. Even if I wanted to print pla, I could not make it less than 13 hour.
  3. Roberto Amador
    Roberto Amador New Member
    Long Beach
    2024 Prius
    Limited AWD-e
    Can you share the 3d print files?
  4. priusasa
    priusasa Member
    104
    53
    2023 Prius
  5. Hodatch
    Hodatch Junior Member
    26
    2024 Prius Prime
    Thank you for ur design and also for leaving it free. Your the man
    priusasa and otatrant like this.
  6. AgentPTFC
    AgentPTFC Member
    58
    40
    PNW
    2025 Prius Plug-in
    XSE Premium
    I'm coming up on hour 24 on the main tray print. This is my second attempt. My first attempt failed at hour 20. I change the orientation and tried again. This attempt seems to be working much better.
    I'll need to do a lot of cleanup on it as I had a lot of stringing going on. I'm considering throwing on a coat or two of paint to smooth out the print lines after I do a test fit. I'll post pics of the final product.
    I'm looking forward to sunglasses season!
  7. priusasa
    priusasa Member
    104
    53
    2023 Prius
    Thats good. For the printing issue, my only problem was the bed adhesion / warphing. I have to put 3 of my jacket on top of the printer and pre-heat the printer like 30 min - 1 hour. It still warps but very small amount.
    I use asa. But if you print with basic filament like pla etc, it should not give you any problem.
  8. RobotBastard
    RobotBastard Junior Member
    17
    Connecticut
    2024 Prius
    I'd definitely buy one of those tissue-box holders, if you made one!
  9. VirginiaLeePrius
    VirginiaLeePrius Junior Member
    44
    Space Coast, FL
    2024 Prius Prime
    SE
    I'd love to have something like this to hold a tiny box of tissues. My wife leaves hers in my car to bounce around or be stepped on :mad:
  10. priusasa
    priusasa Member
    104
    53
    2023 Prius
    Out of topic but I loved your profile picture. I was looking for exactly same kind of red stript that I can pu on the wheel. I actually 3d printed red tpu and used double sided tape, but when I take it out, it literally peeled the black paint of the wheel rim. What did you actually use / buy for those? If you try to take that red strip out from the wheel, do you think it would peel the paint of the rim, have you tried?
    Maybe my wheel's rim paint is low quality, or the double sided tape I used was too strong. I would appraciate if you share what you use. It looks very good.
  11. notspam3
    notspam3 Member
    96
    51
    Toronto
    2024 Prius Prime
    XSE Premium
    The 3D printer idea sounds great until your 3D print warps and shrinks and gets brittle getting baked in the car's greenhouse. Been there, done that, I won't waste more time and money on that pipe dream.
  12. priusasa
    priusasa Member
    104
    53
    2023 Prius
    Thats where asa filament comes in. No warphing, uv and heat resistent. I havent seen any issues. Its not easy to print though
