Another 2103 :(
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by djimbuser, Dec 1, 2025.
  1. djimbuser
    djimbuser Member
    102
    36
    Henderson, Nevada
    My 2103 situation is the car is driving around just fine then BEEP there's the triangle and gas pedal does practically nothing and if you come to stop you're not going to move after that. This morning I was able to remove the glove compartment and disconnect the ECU connector that has the wires leading to the TAC and plug it back in and the car turned on and I continued the rest of my drive no problem.
    Some history:
    I had this problem about 16 months ago and I couldn't seem to resolve it so I bought a "new" TB and installed it. Here we are again. The new TB was only $114 did I get a fake?? It does say "TOYOTA" on it. It's not that dirty. The return spring is super clean still. The throttle plate has a little gunkus on it but the shaft rotates smoothly in both directions (however keep in mind the motor is being turned as well).
    I'm going to disassemble the TB I took off the car last year and compare.
    I did do like the repair manual said and ohmed the wires to ground and it reads infinite like you would expect. The motor terminals measure 0.4 ohms on the "new" TB I still have find the old TB and see what that motor measures.
  2. PriusCamper
    PriusCamper Senior Member
    12,758
    5,168
    Pacific Northwest, USA
    Do you have any symptoms like an unsteady idle? I bought a used TB's at wrecker for like $45 before... Buying brand new for an old car doesn't make any sense.
  3. Brian1954
    Brian1954 Senior Member
    2,201
    866
    South Central PA, USA
    A diagnostic trouble code starts with an alphabet letter followed by four more digits. The 2103 is not a complete trouble code. Do you mean P2103 is the trouble code that you have?
    #3 Brian1954, Dec 2, 2025
  4. djimbuser
    djimbuser Member
    102
    36
    Henderson, Nevada
    P2103: Throttle actuator control motor current (high current).
    Unfortunately I've already cleared the code so it's a little late to connect TIS and get the detail code if any. That said I know it will happen again unfortunately when I least expect it.
    I've attached a photo of both throttle bodies. The greasy one is the old one I took off about 16 months ago. The right one is the "genuine" one I bought for $116 last year. IMG_1651.jpg
  5. djimbuser
    djimbuser Member
    102
    36
    Henderson, Nevada
    Idles perfectly.
  6. djimbuser
    djimbuser Member
    102
    36
    Henderson, Nevada
    My next attempt will be to try a different ECU.. which I happen to have a spare in my parts drawer.
  7. djimbuser
    djimbuser Member
    102
    36
    Henderson, Nevada
    Ok.. temp install of other ECU complete... if no issues after a couple dozen drives and I'll install it properly. IMG_1665.JPG
  8. djimbuser
    djimbuser Member
    102
    36
    Henderson, Nevada
    Five drives in with replacement ECU and no issues yet.
