What headlight bulb do I need?
Discussion in 'Gen 2 Prius Technical Discussion' started by Kzbd, Nov 28, 2025.
  1. Kzbd
    Kzbd Junior Member
    I have never messed with them on my 2007 standard but the right side went out and came back on, I was going to take it out and look at it but Wth is that a weird setup. So I had to come inside and watch some videos and research and now I don't know what I need and I don't want to gouge my hands up twice taking it apart to see what I have then order something. Anyway when I put my VIN in Partsouq it says I need Toyota 9098113058 which their photo just shows a bulb with 4 prongs on it and it says
    "NHW20 12V 60/55W,HALOGEN" . The Phillips that Amazon wants to sell me without my VIN shows one of those right angle plastic things on a bulb.The existing lights looks very white.
  2. Tombukt2
    13,336
    2,401
    Hood up look at edges if headligh housing ???? See a bunch of yellow hi voltage stickers on edges of headlight housings ?? Yes that's HID system no yellow stickers it's standard H4 halogen either way led are in you're future more than likely. They also make hid d4s to LED conversions . You probably will no revist these conversions once completed. I've both types here hid and halogen once adjusted no comparision
    Kzbd likes this.
  3. Kzbd
    Kzbd Junior Member
    Thank you that's a great identifier yes there are 2 high voltage stickers. Do you have a recommendation for LED conversion brand or method?
  4. Tombukt2
    13,336
    2,401
    Alla d4s to LED conversion . Amazon generally . generally . But a smart person mite wanna pull housings and bypass the hid ballast instructions in package. To bypass ballast very simple. Then remount . You'll probably never revisit this .
    Kzbd likes this.
  5. Tombukt2
    13,336
    2,401
  6. Tombukt2
    13,336
    2,401
    I don't generally go for the fan bulbs but it seems the units I have are no more .oh well
  7. Kzbd
    Kzbd Junior Member
    What does bypassing the ballast involve? Cutting off the existing connector on the car?
  8. Kzbd
    Kzbd Junior Member
  9. Kzbd
    Kzbd Junior Member
    Here's an Alla lighting youtube video on how to do this.
  10. Tombukt2
    13,336
    2,401
    All you're doing is by passing ballast and picking up 12V near the headlight or in it to power the led so a bad ballast don't affect you're new led light. It don't need ballast for the light to light if ya will just takes a second . No need worry . If you think you're going to have to put this back it's not that difficult to do but I assure you you won't be doing that
  11. Kzbd
    Kzbd Junior Member
    Man they don't make that bulb anymore. I need another recommendation that I can bypass the ballast, their video doing so is good I don't know why the **** they would cancel that product. I ordered their direct replacement because it says it runs on 12v. - 36v I think, but I think it's going to give errors if I connect it straight to 12v like in their video. Does anyone else make a product like that? In any case their 'plug and play' that requires me to buy a new smart ballast only has 1 wire.
  12. Tombukt2
    13,336
    2,401
    Wut you talking bout williis? Bought a set other day . Maybe not that brand . Brands change like toilet water in Asia. Gotta keep the idiots fooled or sunthin. Look at all the weird names they use . Thinkin they clever hello kitty on steriods
  13. Tombukt2
    13,336
    2,401
    What kind of errors would you think you would get and what would make you believe that what kind of bulb errors we get in gen2 Prius I thinks none or headlite OUT maybe ya looking D4s to led w instructions to bypass ballast that means hookin the shiet up to 12V exactly right
  14. Tombukt2
    13,336
    2,401
    The kind that lights
  15. Kzbd
    Kzbd Junior Member
    Do you have a link to what you bought the other day? The D4 led I got only has 1 wire.
  16. Tombukt2
    13,336
    2,401
    Send me a picture of that stuff that you bought one wire ? That's for the lamp to light ? Ground? Yes if you bought d4s to led the d4s round connector goes to lamp. And some later designs don't have to bypass they pick up the 12volts at the ballast from the car battery. So you dont have to physically bypass. Doh
  17. Kzbd
    Kzbd Junior Member
    The D4S to LED connector one is garbage, I'll send a picture later but I'd have to butcher my dust cover, it has a fan and a cord coming off it with a male D4S. It's crap man.
    #17 Kzbd, Dec 12, 2025
  18. Kzbd
    Kzbd Junior Member
    My mistake, I think it was the ballast that only has 1 wire. The "plug and play LED" from Alla that's only plug and play if you want to butcher your dust cover has what looks like a multi conductor cable so I guess I could have stripped the cable wired that straight to my 12V. Wouldn't I need external capacitors though or something? 20251212_191445.jpg
  19. Tombukt2
    13,336
    2,401
    Good lordy . None of that I have I cannot post pics here easily . I have this on two car one just got wrecked I have the bulbs laying on my seat
  20. Tombukt2
    13,336
    2,401
    I have pictures my covers did not get cut or modded
