Free Gen 2 stealth camping set up
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Queueball, Dec 11, 2025.
  1. Queueball
    Queueball Junior Member
    17
    Saline, MI
    2019 Prius
    IMG_7556.jpg IMG_7558.jpg IMG_7618.jpg IMG_7614.jpg IMG_7615.jpg IMG_7617.jpg IMG_7613.jpg
    My Gen 2 recently concluded its 2+ decades of efficient and faithful service. Among my favorite memories was fabricating removable modifications that allowed for surprisingly comfortable solo stealth camping. It keeps the narrow back seat in place allowing two passengers plus the driver. We used this for two separate trips between Michigan and SoCal during the pandemic hysteria as well as for various shorter road trips.
    These pieces are now available to anyone willing to pick them up in southeast Michigan. I will look for comments to this post for anyone who wants it.
    I made a similar set up for my Gen 4 which allows me to depart at any time of the day on an 8 hour trip to Tennessee. I can drive until I’m tired, pull over and sleep comfortably then finish the trip safely refreshed.
    Too bad Gen 5 took on a lower profile that makes this arrangement less practical for my 6-1 frame. However my 2019 Limited will likely outlast me so NP.
  2. Templeton
    Templeton Member
    306
    99
    usa
    2024 Prius Prime
    SE
    I gotta say, this is very impressive.
    I have a gen5, so l can't use this, but l would love more details on how you made and attached the large light shade that is just behind the first row. Could you post more photos and info on how you did that? Thanks.
  3. Queueball
    17
    Saline, MI
    2019 Prius
    The Gen 5s look so much nicer but I'm in it for utility so have to settle for Gen4.
    Happy to share. It's a room darkening curtain black on the front side cut to fit the opening plus 3" on the top and sides. My wife sewed a 3" sleeve and the individual pockets for a series of magnets. I fabricated an 18 gauge steel strip about 2.5" wide to match the roof contour and fit tightly against the headliner. To that I riveted stops that straddled the plastic pillar trim. Lastly I screwed three 1" fender washers to the trim on each that lined up with the magnets in the curtain. After putting both front seats all the way forward the curtain was easy to snap in place and adjust to hang straight down.
    I've attached thumbnails, let me know if you want full image phots for better detail. IMG_7549.jpg curtain arch 2.jpg curtain arch 1.jpg IMG_7548.jpg IMG_7547.jpg IMG_7568.jpg
    Templeton likes this.
  4. Templeton
    Templeton Member
    306
    99
    usa
    2024 Prius Prime
    SE
    Thanks, very helpful , and looks great.
    A question: rather than fabricating the long steel strip, any reason that you didn't just screw in a few fender washers into your headliner instead (to line up with the upper magnets in your curtain divider) ?
  5. Queueball
    17
    Saline, MI
    2019 Prius
    I wanted to be able to remove the stealth camping option with little evidence it was ever there in case I sold the car. Also, I was unfamiliar with the composition of the headliner and how it was attached to the car and didn't want to chance piercing the roof. another unforeseen advantage turned out to be how convenient it was to have the magnets grab the bar wherever and then spread them apart into a taught smooth arrangement.
  6. Templeton
    Templeton Member
    306
    99
    usa
    2024 Prius Prime
    SE
    How/where did you source the steel for the roof piece? thanks again!
  7. Queueball
    17
    Saline, MI
    2019 Prius
    You might look for Alro Steel or Alro Metals who sell cut offs and other scraps for cheap. They will cut a piece down to the dimension you need for a fee. If you're not much into DIY I suggest searching for local sheet metal fabricators or custom metal fabricators. Maybe try Thumbtack or Fiverr. Like with most things, it's straightforward if you have the right tools.
  8. Templeton
    Templeton Member
    306
    99
    usa
    2024 Prius Prime
    SE
    DIY is no problem, getting it to fit looks pretty simple. But finding a strip like this is the challenging part. Any idea how thick the metal is? Is it plain steel, or stainless?
  9. Queueball
    17
    Saline, MI
    2019 Prius
    I think 18 gauge which is readily workable yet adequately stiff. No stainless if you will be using magnets.
    If you aren’t concerned about the stealth aspect and would be content with a gap between the black out drape and the headliner then an adjustable curtain rod should work fine and be plug ‘n play. Happy camping!
