actuator change out
Discussion in 'Gen 2 Prius Technical Discussion' started by Tombukt2, Dec 12, 2025.
  1. Tombukt2
    13,336
    2,401
    Okay so I've been playing with this for a while now and I've got it down . I changed the actuator on a buddy of mine's car yesterday follow that I've been messing with awhile . Used actuator k pen good on another car that's here . Connected the new actuator plugged all else up sat in car . Bottled car . No lights nothing perfect pedal . No bleed . I've driven car. I'm going to go through the bleed procedure just because. To rule out all the nonsense . Working perfectly regen abs all of it .
  2. Hayslayer
    Hayslayer Active Member
    458
    264
    and guaranteed you will eventually start getting a small, sometimes barely audible, chirp when the brakes are pressed or randomly when stopping due to an air bubble. If you don't care about a chirp or an air bubble, no big deal.
