Wheel and Tire fitment and TPMS questions
Discussion in 'Gen 5 Prius Main Forum' started by kev604, Nov 6, 2025.
  1. VelvetFoot
    VelvetFoot Active Member
    1,213
    473
    New York State
    2026 Prius
    Perhaps the 17s don't emphasize the small size of the rotors as much.
  2. kev604
    kev604 Junior Member
    56
    49
    Vancouver, BC Canada
    2026 Prius Plug-in
    Also the OEM wheels and tires weigh a ton.
    VelvetFoot likes this.
  3. Alyssa L
    Alyssa L New Member
    Los Angeles
    OEM TPMS sensors from the dealer are definitely more reliable and avoid most compatibility issues. But I’m using Autel sensors on mine and programmed them with a TPMS tool—no problems so far. DIY guy passing through.
  4. kev604
    56
    49
    2026 Prius Plug-in
    What year your Prius though?
  5. Tekz
    Tekz New Member
    British Columbia
    2026 Prius Plug-in
    unfortunately here in NA, the CC3’s aren’t coming for a while hence I fitted the CC2 on my recently acquired’26 PHEV in SE trim using 215 55 17 but the dealership had to install new alloy rims and couldn’t use the OEM rims (not exactly sure why) as it had something to do with the fitment/width of the new tires vs OEM. I used tire size comparison and the specs are within tolerance but hey, dealership supplied the new alloy rims as part of the deal so why not
  6. kev604
    56
    49
    2026 Prius Plug-in
    A 215 tire is slightly oversized but doable on the 6.5 OEM wheel. I can understand though the dealership not wanting to do it to protect themselves from liability issues.
    Tekz likes this.
  7. Tekz
    Tekz New Member
    British Columbia
    2026 Prius Plug-in
    I think you’re right that it was the main reason why (avoid any liability issues) but as it turned out, the new alloy rims they installed looked better than the stock OEM wheels with hub caps and OEM tires (stored in their storage for 3yrs free btw), see the new rims:
  8. blfuller
    blfuller Junior Member
    37
    Eastern Washington State
    2026 Prius
    XLE AWD-e
    BIG difference on wheel and tire weight compared to my dead 2009. I was surprised how much more the OEM 2026 weighed.
