Two Mods That Actually Made My Prius Feel Safer
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Mccoy, Dec 10, 2025.
  1. Mccoy
    Mccoy Junior Member
    Vancouver
    2024 Prius Prime
    XSE
    Hi all,
    Just wanted to share two upgrades I did on my 5th-gen Prius that made a big difference in daily driving.
    1. stick-on wide-angle side mirror
    The stock mirrors view field felt narrow, so I stick-on wide-angle side mirror made for the Gen 5.
    This one also keep the BSM light visible (semi-transparent section) and the extra field of view makes lane changes way easier.
    2. OEM style Digital rearview mirror w/ dashcam
    I’ve always felt the rear visibility on this car… just isn’t great. And with no rear wiper, it basically drops to zero the moment it starts raining. I eventually found an OEM-style digital rearview mirror (Sinjet H10 Pro). The specs are actually pretty impressive — super smooth 50fps rear feed, a screen that goes up to 3000 nits, and no clutter or distracting info on the display. Night and rain visibility are so much better now.
    Installation note: removing the taillight was a pain — definitely something I’d let a shop handle next time. But totally worth it once installed.
    I posted more on my Instagram as well..
    otatrant, 2023p, bisco and 1 other person like this.
  2. pascalvin
    pascalvin Junior Member
    2024 Prius Prime
    XSE Premium
    do you have a product name or link for the stick on wide angle side mirror please?
    IntnsRed likes this.
  3. Mccoy
    Mccoy Junior Member
    Vancouver
    2024 Prius Prime
    XSE
    I actually picked mine up while visiting Taiwan. I’ve tried looking for a similar solution in North America, but so far I haven’t had any luck. At the moment, I think the only way to get this exact style is from Taiwan. If you have a friend there, I can share a local shopping link and they might be able to help you grab one.
    Templeton likes this.
  4. notspam3
    notspam3 Junior Member
    60
    33
    Toronto
    2024 Prius Prime
    XSE Premium
    Our new Prius has the camera RVM but I find I can't use it for driving. For some reason it takes me a second to focus on the camera display whereas I don't get that delay as a mirror. I leave the camera feature off as it feels like too much of a distraction. It's the same reason I don't like cars with touch screens in place of buttons (Tesla 3 expects you to tap and pinch to turn on the AC vents while driving, Wth).
    Anyone else feel that way about the camera RVM?
  5. RX808
    RX808 Junior Member
    31
    2025 Prius Plug-in
    XSE Premium
    I didn't initially like the camera rvm - but now I do! Major increase in rearward visibility.
    The trick (for me) was to stop setting its position as if it were a (traditional) mirror, and just set it perpendicular to the axis of the car. It's just a monitor, after all.
    Now when I get in my other car (with a standard mirror) I'm like What the heck is this? I can't see anything behind me!
    Mccoy likes this.
  6. Leadfoot J. McCoalroller
    8,111
    7,591
    Pennsylvania
    2018 Prius c
    This is very common for drivers over age 40. When you use a traditional mirror, the focal length of what is seen in the mirror is the same as whatever you were just looking at through the windshield, so your eyes do not need to re-focus.
    When you use a display in place of a mirror, your eyes must change from far-focus to near-focus, and as humans age that takes longer. In the context of driving it can feel uncomfortably long.
    Mccoy likes this.
  7. VelvetFoot
    VelvetFoot Active Member
    848
    301
    New York State
    2026 Prius
    Doesn't the aftermarket rear view mirror's camera get dirty like the backup camera? I find that happens a lot.
    Blackat and 2023p like this.
  8. Blackat
    Blackat Active Member
    463
    321
    Colorado
    2023 Prius
    Limited AWD-e
    On my other cars the back up camera is hidden and protected from mud/snow etc until you need it.
    It's one of the features Toyota didn't think thru
  9. Leadfoot J. McCoalroller
    8,111
    7,591
    Pennsylvania
    2018 Prius c
    Aftermarket units are limited for where they can be mounted. Many are set up to attach to the license plate bracket, because it's a nearly universal mount point on the back of the car. This also helps make them inexpensive.
    In newer OEM setups they're using cameras integrated into the rear of the sharkfin antenna on the roof. Those stay cleaner, without being as expensive/complicated/unreliable as the VW-style popout cameras.
    I haven't seen the new sharkfin cams on a Toyota yet but I reckon that's just a matter of time- they are fairly generic assemblies available to all car manufacturers.
    VelvetFoot likes this.
  10. broderp
    broderp Junior Member
    OH
    2024 Prius
    Limited AWD-e
    Not sure that will ever happen. The antenna is part of the roof, so a replacement would required covering the existing antenna and cutting a hole in the top or replacing the entire panel between the roof and rear hatch. Both would be very expensive to do.
  11. Leadfoot J. McCoalroller
    8,111
    7,591
    Pennsylvania
    2018 Prius c
    Sorry, I wasn't suggesting that as an aftermarket replacement.
    To clarify, I think it's likely that a future model will begin using the combo antenna/camera fin because it provides several desirable features with a single roof penetration and a shorter wiring run than anything trunklid or bumper mounted. Gentex can stamp 'em out by the pallet and reduce costs through volume since many cars can use an identical part, even across brands.
  12. mingc
    mingc Member
    Portland, OR
    2023 Prius
    XLE AWD-e
    Seems like a camera mounted on a fin will have a blind spot right behind and below the bumper area.
  13. Leadfoot J. McCoalroller
    8,111
    7,591
    Pennsylvania
    2018 Prius c
    On some cars it might. Hatchbacks and SUVs would be fine, and the latter is awfully popular lately.
