Prius 2019 corner triangle next to the side mirror missing
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Northwest2, Dec 12, 2025.
  1. Northwest2
    Northwest2 New Member
    Northwest
    2019 Prius
    LE AWD-e
    This morning I noticed the corner triangle missing next to the passenger side mirror. I googled and ordered this part and it'll arrive in a week:
    Meanwhile, is it OK if it's exposed to the rainwater or should I tape it?
    Thank you.
    51,996
    idk, but i would tape it to be on the safe side unless someone knows for sure
  3. BiomedO1
    3,665
    1,899
    SacTown, Ca
    It'll be fine, that area is not water tight. I'd make sure the drain holes at the bottom of the door is clear, so any water that gets in there will be able to drain out.
  4. Tande
    Tande Active Member
    539
    322
    Mich.
    What am I missing? .....the area shown by the OP, has nothing to do with the door? ...:confused:
    BiomedO1 likes this.
  5. BiomedO1
    3,665
    1,899
    SacTown, Ca
    Ya, sorry - upper rear corner of the fender. Same applies, make sure there's a clear water drain path, so it doesn't puddle back there.
  6. Tande
    Tande Active Member
    539
    322
    Mich.
