12V Battery Replacement Recommendation
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Tonydavid, Jan 8, 2021.
  1. WiredKnight
    WiredKnight New Member
    Saturday
    Newberg Oregon
    2014 Prius v wagon
    It’s 2025, but just wanted to let anyone who might need it, Amazon has OBDII memory savers that hook into OBDII and a 9v transistor battery for ~17 dollars. Search using this on Amazon:
    9V Battery Powered Memory Saver for Car Battery Fit for All OBD ll 16-Pin Interface
  2. indel
    indel Member
    108
    35
    Northwest Indiana
    So you attach this device to the obd2 port while you are changing out the 12V battery? Would it not create excessive charge briefly when both the battery and this device are connected? Is that ok?
  3. ChapmanF
    18,204
    It doesn't: voltage sources in parallel do not add. 12 volts ∥ 12 volts = 12 volts.
    indel likes this.
  4. Mendel Leisk
    41,457
  5. indel
    indel Member
    108
    35
    Northwest Indiana
    Speaking of 12V chargers, has anyone used this Bosch charger?
  6. WiredKnight
    Saturday
    Newberg Oregon
    2014 Prius v wagon
    Mendel Leisk has experience using the obd2 port for memory saving. I’m new to this forum and not sure how to contact him. I haven’t tried (or purchased) it yet. The amazon page has user reviews on using the product I’m looking at, which may also be a good source.
  7. Mendel Leisk
    41,457
    Yeah I posted this the other day.
    That said, if I’m going to take brake calipers off the rotors, first thing I do is disconnect the 12 volt battery’s negative cable, without using a memory saver. It’s no big deal. I don’t really care about radio presets though.
  8. indel
    indel Member
    108
    35
    Northwest Indiana
    To me, radio preset loss is a trivial side effect of disconnecting the battery. One annoying side effect is the resetting of calendar date in the display dash. I still don't know what the thinking was behind it. Perhaps the most important items in memory are learned parameters which can impact gas mileage. Still, it's a no brainer that one should disconnect the battery (and not use any memory saver tricks) when repairing brakes.
