Just bought a 2016 Camry Hybrid. What parts should I change?
Discussion in 'Toyota Hybrids and EVs' started by 9Shenandoah, Dec 14, 2025.
  1. 9Shenandoah
    9Shenandoah New Member
    28
    Washington State
    2014 Prius c
    I just bought a 2016 Camry Hybrid with 135 K. I 'm going to recondition the Battery, change the Transmission Fluid, replace the belts and radiator hoses.
    Anything else I should do?
    Can I put off the water pump or is now a good time?
    mrmacklems likes this.
    52,354
    this is the gen 4 forum.
    check the 12 volt and radiator hoses, make sure the spare is pumped up. brake fluid if it's not on the schedule.
    has all the regular maintenance been done through 120k?
  3. 9Shenandoah
    28
    Washington State
    2014 Prius c
    It looks pretty well maintained.
    How do you feel about the Water Pump?
  4. Moving Right Along
    Moving Right Along Senior Member
    731
    588
    From what I've heard about transmission fluid, if it hasn't been changed by now with 135,000 miles, you're best not changing it since that could cause problems with gear slipping
  5. Prodigyplace
    12,662
    11,827
    Central Virginia
    With the hybrid transaxle?? That is the first I heard of that!
  6. bisco
    52,354
    while we've had 3 hycams, we've never had them over 100k. i don't know how the pumps hold up compared to prius. if you're going to keep it a long time, why not change it.
    be careful about parts though, there's a ton of undetectable counterfeits out there.
    Prodigyplace and Merkey like this.
  7. Moving Right Along
    731
    588
    I got that from the Car Care Nut on Youtube.
    Start from the 3:30 mark
  8. rjparker
    10,469
    6,564
    You have a lot to learn about hybrids. Car Care Nut was talking about conventional transmissions that have clutches to slip and torque converters to shudder. Your Toyota hybrid eCvt has neither. In fact the gears are engaged all the time. What you do have are large electric motors/generators inside with planetary gear sets and a differential. A drain and fill with Toyota hybrid specific eCvt oil is recommended but not required every 50k.
    #8 rjparker, Dec 14, 2025
    Prodigyplace and Mendel Leisk like this.
  9. Brian1954
    Brian1954 Senior Member
    2,396
    960
    South Central PA, USA
    View the video again. Look at 5:30 minute mark. The Car Care Nut is talking about a conventional automatic transmission with a torque converter and valve body. His video is not about an eCVT transaxle that is used in the Toyota hybrid cars.
    Edit: rjparker made his post while I was watching the video and composing my post.
    #9 Brian1954, Dec 14, 2025
  10. Tideland Prius
    16,611
    Moved to Toyota Hybrids and EV forum.
    Prodigyplace and Brian1954 like this.
  11. Prodigyplace
    12,662
    11,827
    Central Virginia
    So, you just made my point. There is no torque converter or filter in the Hybrid transaxle.
  12. BiomedO1
    4,096
    2,140
    SacTown, Ca
    Is there belts on a 2016 hycam and what do they drive? If it has a mechanical water pump, just inspect the weep hole otherwise you'll need to pay attention to the temperature gauge, if it has one.
    Clean out the traction battery cooling vents and motor. Make sure you don't place plastic bags or cover those intakes.
    Change both coolants (inverter & ICE), spark plugs, if they haven't been done.
    Good Luck....
    Prodigyplace likes this.
  13. Prodigyplace
    12,662
    11,827
    Central Virginia
    I know the 4th & 5th Gen hybrids had no belts but a 2016 HyCam would be a Gen3. i am not as familiar with them. I think @bisco may knoe though.
  14. BiomedO1
    4,096
    2,140
    SacTown, Ca
    If there's a belt, make sure you check the tensioner and idler bearings - if those lock-up, you'll shred your belt.
  15. bisco
    52,354
    no belt
  16. 9Shenandoah
    28
    Washington State
    2014 Prius c
    Electric water pump!
  17. mrmacklems
    mrmacklems New Member
    cali
    Two Eco
    At 135k, good plan
    Also consider:
    • Engine & inverter coolant (both circuits)
    • Spark plugs
    • Brake fluid
    • PCV valve
    • Clean EGR & hybrid battery cooling fan
    Water pump:
    Not urgent unless leaking/noisy — you can put it off, but many fail around 150–180k, so preventive replacement isn’t a bad idea.
    Uberdriver2710 likes this.
  18. mrmacklems
    cali
    Two Eco
    At that mileage, you’re on the right track. In addition to the basics, it’s smart to inspect belts, hoses, suspension bushings, and wheel bearings, and keep an eye on the hybrid battery cooling system. None may be urgent, but catching wear early saves money. When replacing service items like spark plugs, filters, or cooling components, using quality parts from Disfal, a trusted auto parts distributor, helps ensure long-term reliability.
