Does anyone remove/cut your Gasoline Particulate Filter (GPF)?
Discussion in 'Gen 5 Prius Main Forum' started by Axl, Dec 13, 2025.
  1. Axl
    Axl New Member
    Georgia
    2026 Prius
    GPF's negative effects are larger than positive effects. Especially in short trip.
  2. PriusCamper
    PriusCamper Senior Member
    13,055
    5,305
    Pacific Northwest, USA
    That might be slightly true in a V8 or V12 engine that's been run at max rpm on a race track. But driving a little four cyclinder Toyota around? There's no way that's going to be an issue.
  3. Gokhan
    Gokhan Senior Member
    6,537
    2,609
    Paramount CA
    I don’t think Prius and other Toyotas in the US have them as far as I know.
    In any case, it is illegal to tamper with any kind of emissions systems, not to mention that the car will fail the emissions inspection or test.
    PrimeDan, Tande and Blackat like this.
  4. bisco
    52,390
    maybe not in AL?
  5. Trollbait
    12,681
    Albania.
    Europe uses particle filters for gasoline cars. IIRC, it is the same limits as for diesel.
    Gokhan likes this.
  6. Gokhan
    6,537
    2,609
    Paramount CA
    So, no GPF and DPF in Albania? :)
  7. Trollbait
    12,681
    o_O
    Is Toyota making a Euro 5 emission Gen5 for importation to Albania?
  8. Gokhan
    6,537
    2,609
    Paramount CA
    LOL It was meant for humor, asking if Albania was exempt from GPF and DPF requirements.
  9. KMO
    KMO Senior Member
    2,011
    734
    Finland
    2023 Prius Prime
    This is a Europe/USA difference I'd missed. The GPF gets half a page in the European manual about the possible error conditions - posted here for the benefit of others.
    Gokhan likes this.
  10. notspam3
    notspam3 Member
    96
    51
    Toronto
    2024 Prius Prime
    XSE Premium
    Paint flames on your car, it will go faster. If you put bigger tires on the back you will always drive downhill and save gas.
  11. Trollbait
    12,681
    It appears Albania needs to import all their cars. The AI search response said those cars need to be at least Euro 5 compliant. 5b ended in January 2013.
    Pretty sure Euro 5 didn't require an exhaust filter on petrol cars, but getting a gen5 Prius without one would entail importing from outside Europe.
    Edit: Albania is also working towards becoming part of the EU.
    #11 Trollbait, Dec 16, 2025
    Gokhan likes this.
  12. Gokhan
    6,537
    2,609
    Paramount CA
    Albania is close to my homeland, where we have a lot of Albanians, too. It is kind of an obscure country, yes.
    But is the OP located in Alabama or Albania? I drove through Alabama. @bwilson4web lives there. He would know the local emissions regulations.
  13. Trollbait
    12,681
    Neither the EPA nor CARB require cleaning up the particle emissions of gasoline cars. Even though they can exceed the limits that put DPFs on all diesels. Requiring a GPF anywhere in the US would be big news.
  14. Mendel Leisk
    41,901
    AL…
    Cavalier location description (in OP’s avatar) is frustrating; half the posts hinge on it.
    It’ll never happen, but it’d be helpful if the site provided a database, that you had to choose from. If you’re in some obscure location: an option to choose nearby city with indication it’s “nearby”.
    So long to “earth”, “somewhere”, obscure suburbs, zip codes, and/or and country-only
    #14 Mendel Leisk, Dec 17, 2025
    Gokhan likes this.
  15. Axl
    Axl New Member
    Georgia
    2026 Prius
    I searched the manual, I can't find GPF in the manual, there seems not GPF equipped in US.
  16. Probity
    Probity Junior Member
    45
    34
    Covington LA
    2026 Prius
    I mentioned this in another thread, but since GFP's are being discussed....
    Some have mentioned concern for gasoline particulate filter (GPF) protection (like MillerCat's cat converter shield). My understanding is that US (and Canada?) models don’t have GPF’s on the 2.0 liter M20A-FXS. Europe/other countries Prius models a different story, but no GPF (yet) for the Gen 5. Nothing in US owners manual about regen warning/procedure, the VECI under hood sticker has no GPF notation. In the US, I thought that if a vehicle has a GPF it has to be indicated on the VECI, had to be described in EPA/CARB compliance info from the manufacturer.
    My ’26 VECI notes DFI (direct fuel injection) + SFI (sequential multipoint – electronic – fuel injection), and EGR (exhaust gas recirculation), and EGRC (EGR cooler), and WR-HO2S(2) (2 x wide range/linear/air-fuel ratio heated oxygen sensors), and TWC(2) (2 x three-way catalysts) – but no GPF.
    Toyota’s EPA/CARB Application for Certification 2026 Model Year (for both Prius and Prius PHEV), and CARB Executive Order approvals don’t mention GPF anywhere. Engine Control System Schematic (page 64 for Prius HEV Microsoft Word - FOI_TTYXV02.0H3B_APP_INI_R00(残りバッテリーラベルのみ), page 93 for PHEV Microsoft Word - FOI_TTYXV02.0H3W_APP_INI_R00) don’t show a GPF. Same for the US ’26 Corolla Cross Hybrid with the M20A-FXS.
  17. Gokhan
    6,537
    2,609
    Paramount CA
    It is obviously Alabama. I thought @Trollbait was joking about Albania, but then he seemed serious.
  18. Mendel Leisk
    41,901
    US 2-letter state acronyms leave worldwide viewers stumped. Invest 5 more keystrokes. :rolleyes:
    Gokhan likes this.
  19. Gokhan
    6,537
    2,609
    Paramount CA
    And I am even more confused by the Canada two-letter acronyms and six-character postal codes. :)
    Code:
    PO Box 5053 Stn Forces
    Belleville ON  K8N 5W6
    CANADA
  20. Mendel Leisk
    41,901
    Yeah, I have to catch myself: BC is not that informative. At least my avatar's fairly clear. Too, I'm off in a suburb "city", but part of Greater Vancouver. :)
    For US PriusChat members, solely using zip codes for "location" has everyone scrambling to look it up, nobody's got that memorized.
    Gokhan likes this.
