12 v Battery Drain
Discussion in 'Gen 2 Prius Main Forum' started by jfs2010, Dec 15, 2025.
  1. jfs2010
    jfs2010 Junior Member
    26
    Hudson Valley
    I've been having issues with my 3 year old 12v battery over the past week. First time was my fault when I put air in the tires, using a cigarette lighter compressor, when the car was not in ready mode. The battery has drained 2 more times since then, both in very cold weather. Weather went down to 5 degrees last night & the battery is drained again. Couldn't start it this morning, and I noticed this evening there is a horn beeping noise coming from the engine. Is this a result of the battery draining, or could it be the issue causing the drain? I'm having a hard time getting the battery replaced because I'm being told the battery is good. Thanks for any advice. Will be purchasing a jumper and trickle charger for future use.
  2. BiomedO1
    4,019
    2,109
    SacTown, Ca
    Well; if your battery was properly tested and came out good - You probably have a parasitic drain somewhere in your electrical system. You'll need to take it to an automotive electrical shop to diagnose that.
    In the mean time; someone that knows a bit of electronics should find the OBD2 plug for your car and follow that wiring harness back. Look for dealer installed alarms or trackers that may be malfunctioning, causing that parasitic draw on your battery. Remove it and see it that cures your issue.
    Good Luck.
    #2 BiomedO1, Dec 15, 2025
  3. bisco
    52,286
    who told you it was good? did they do a load test? draining these little batteries is often the beginning of the end, especially in the cold.
    you can get a free load test at most auto parts stores. has the battery been fully charged since draining?
  4. jfs2010
    26
    Hudson Valley
    AAA initially jumped my car after I accidentally drained it using an air compressor. The tech had a hand held device that showed the battery was good, Not sure if that qualifies as a sufficient test. They told me to drive it for two hours to charge, but the car was drained again the next day after very cold weather. I then took the car to Mavis (not my usual mechanic )and they also told me the battery was good, was taking a charge like it was new, and would not let me purchase a new one. Just a hunch, but I'm thinking the battery is not good, (1) because I had the same issue one year ago - battery died in my garage during extremely cold weather when it was only 1 year old. My mechanic kept it a couple of days and charged it up, no issue for a year, and (2) the current issue began when I accidentally drained the battery using a compressor, so I don't think it's a parasitic draw. It has drained 3 times the past week, and once last year. I have been reading up on battery sulphation and the effects on a drained battery.
  5. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    Buy a 2 to 5 amp smart charger and charge the 12v battery for 12 to 24 hours.
    jfs2010 and BiomedO1 like this.
  6. rjparker
    10,412
    6,521
    Three years is not old for an agm battery in a Prius. A few discharges are not "that" bad for an agm.
    Measuring parasitic draw would settle the issue. No draw over 35ma, I would replace the battery.
    No one is going to refuse your request to buy a battery; however getting a free or discounted replacement requires a failed load test.
    #6 rjparker, Dec 15, 2025
    BiomedO1 likes this.
  7. BiomedO1
    4,019
    2,109
    SacTown, Ca
    That AAA guy more than likely stated that "your battery is charging", because you can't load test a battery right after a jump start - it would fail because it's too low. You can't do that test until the battery is fully recharged; which is what your mechanic did when he kept your car for two days. That's a far cry from "your battery is good", then why did it need a jump???
    Have you attached a battery charger to your battery, since you've drained it???
    Have you had the battery tested after any of the three times you've drained it???
    You can believe whatever you want and ask ChatGPT what to do; but unless you TEST - it's all speculation and won't solve anything.....
    #7 BiomedO1, Dec 16, 2025
  8. VelvetFoot
    VelvetFoot Active Member
    1,135
    448
    New York State
    2026 Prius
    Do you drive it much? Short trips don't help. Over time, perhaps shortening the lifetime of the battery (I think, lol). The accidental drain didn't help.
    Cold weather brings out battery weakness.
    Even though only 3 years old, and maybe charging it up would work for a while, why not replace it?
    You're getting that battery jumper but who needs to get stuck in cold weather, messing around in the snow?
    If you could potentially get another 3 years out of a battery, I think it'd be worth the gamble.
    What do mechanics go for nowadays, $150/hr?
    I'm enjoying my new toy, a BM-2 battery monitor. It can even notify you on low voltage, so you can act before it totally dies.
    priumium likes this.
  9. Tombukt2
    13,291
    2,398
    You couldn't load test it per se after jump but ya can watch recovery of volts. After the event and things like that . Google how to setup fluke for parasitic drain 12v automotive it's really easy . Pull fuses slowly 2 at a time watch meter drop . That's the circuit that needs attention. Even if you can hand off car with this info . You saved yourself a few hours time in shop . Usually it's from poor installs of accessories.
  10. pasadena_commut
    pasadena_commut Senior Member
    2,776
    831
    Southern California
    The little electronic battery testers do NOT measure battery capacity. They do look for certain faults and can make a semi-accurate prediction of the short term current that the battery can provide. Unfortunately even a battery with only 5Ah capacity may be able to meet the CCA - it just can't do it for very long. The little electronic testers don't actually draw that sort of current, they estimate the CCA from frequency measurements on the battery. The Harbor Freight tester I have pretends that it can read Amp Hours, but it is clearly nonsense, since if you put in some random number on a good battery it will you a "reading" near that.
    The only way to get an accurate capacity measurement is to discharge the battery at 1/20 C (2.25A on the larger Prius 12V battery) until some predesignated voltage end point is reached. If the battery is working as designed it will take 20 hours to fully discharge one that started fully charged. (Lots of caveats, the main one being that the temperature should be a constant 25C.) If the capacity is reduced that voltage endpoint will be reached (much) sooner. The downside is that this sort of testing will damage an AGM battery, they do not like being fully discharged. I have been experimenting with a 2 hour discharge (at 2.5A, which is close enough to 2.25 so that the Peukert correction is small enough to ignore) followed by a 2 hour recovery. Here is the discharge curve for a brand new, fully charged Walmart S46B24R battery:
    IV discharge curves for a working Prius 12V battery? | PriusChat
    Dogma is that one should allow 24 hours for recovery. You can see from the recovery curve that it has a fast phase which is done in 2 hours. It may be that there is a much slower recovery mechanism that really does need 24 hours (at 25C) to complete. I have not yet done that experiment. Temperature is a big problem in these tests. I do them in the garage or the driveway, which aren't temperature controlled. So on a good day the battery can stay pretty close to 25C over four hours. Not over 24 though, any day of the year. Anyway, 4 hours is already quite a long test, and the battery needs to be isolated form the car to eliminate parasitic load during discharge and recovery. We can't easily speed this up, because drawing more current requires using the Peukert correction, and we don't know that factor for the individual battery, or even the battery model, and again, temperature matters.
  11. rjparker
    10,412
    6,521
    I would not suggest it takes hours to properly load test a battery. I will agree the lowest cost electronic versions don't load enough or for adequate time.
    However an old school resistor based tester CAN accurately test. Typically they draw a 100 amps over a few seconds which separate the men from the boys.
    If it is vented it is resistor/ceramic or carbon pile based.
    Retailers and shops make warranty replacement decisions based on load testers . They don't take more than a few minutes.
    $22 or buy the same unit with a name brand for $46.
  12. BiomedO1
    4,019
    2,109
    SacTown, Ca
    Yep; takes less than a minute and can be had at Wally's for less than $20 on sale.
    Battery Load Tester 100 Amp Load Type 6V-12V 100A Mechanics Car Truck Repair - Walmart.com
  13. Tombukt2
    13,291
    2,398
    Mine like this is made by Milton I think is real Old . Those bars under the Chrome can get red hot
  14. pasadena_commut
    2,776
    831
    Southern California
    The load testers referred to in the preceding three posts are for CCA or some other measure of peak current (in amps), they do not measure battery capacity (in amp hours). In particular, because of the Peukert effect it is virtually impossible to measure battery capacity quickly, the higher the current that is used in the test the stronger the effect. While it is theoretically possible to correct for this, it requires knowledge of a particular battery's Peukert constant, which is data that is essentially never available.
  15. BiomedO1
    4,019
    2,109
    SacTown, Ca
    I really don't care about capacity all that much. My main concern is starting the car - getting it into 'Ready' mode or getting the engine started; where the DC-DC converter or alternator kicks in to provide continuous power to everything I'm running. For that, the carbon-pile load tester does an excellent job telling you; if your battery is up to that task.
    A Prius camper or someone who likes sitting in their car and running their electronic accessories in NOT Ready mode would need to be concerned about capacity. Again; simple solution is to leave the car in 'Ready' mode.
    Just my two cents......
  16. pasadena_commut
    2,776
    831
    Southern California
    Does it though? It can tell you that the battery can deliver 40A (or whatever the load is set to, 40A would be plenty for modeling a Prius start) for a brief period of time. Rarely more than a few seconds, let's use 10 seconds. Total battery capacity used in such a test is quite small 40A * (1/360)h = 1/9 Ah. (This is not strictly correct because the current is so high.) A battery needs to be at death's door before it cannot pass that test - it would need to have a capacity measured in single digits of Ah. Conversely, a battery with a low capacity can sit for a week and then fail to start the car because it ran down too far from the normal parasitic load and self discharge.
  17. BiomedO1
    4,019
    2,109
    SacTown, Ca
    Now your just playing word games and making up scenario. There is an OEM capacity built-into the battery group installed in the car; that's why some people put small hobby batteries in and don't complain that it won't start after parking it for a few days. It's OBVIOUS that hobby battery doesn't have the same capacity of the OEM battery. Now if there was a parasitic draw on the battery, that's the battery's fault???
    Bottom-Line; I've never seen a battery that has the ability to pass a load test with a carbon-pile tester - NOT able to start a car. Now if someone decided to turn on their 2000W inverter and make themself a cup of coffee after the test and before starting the car - I suppose you can blame the battery tester for that too.
  18. pasadena_commut
    2,776
    831
    Southern California
    The battery I recently replaced had around 10 Ah of capacity left (measured at close to 25C). The electronic battery testers (mine and one in an Autozone) said it was still good.
    It was replaced because, despite the good tests, there were still plausible scenarios where it might not start the car.
    Parasitic load in this model is 20-25 mA. Using the larger value 10Ah/25mA is 400 hours or 16.7 days. While I'm not planning on parking the car for two weeks any time soon, it is a possibility (we might take a trip by plane, and we have had vacations that long) and the temperature conditions might not be ideal for battery longevity, it could be hotter or colder than is ideal. So, hypothetically, that battery could fail to start the car at the end of a trip. Even if the car did start, it would have discharged to a low SOC, and that is bad for the longevity of the 12V.
    A battery with OEM capacity is 45Ah. 45Ah/25mA is 1800 hours or 75 days. A full capacity battery can sit for 14 days and it will only use 8.4Ah doing so, and only be down to 81% SOC. That isn't considered a damaging level of discharge on an AGM, although the most conservative suggestions for extending battery life sometimes put the cutoff as high as 80%.
    Most of the mobility batteries people have installed have at least as much capacity as the OEM one, many claim to be 50Ah or 55Ah. On the other hand, probably none of those batteries can deliver a high discharge current for a load test.
  19. Tombukt2
    13,291
    2,398
    So we're doing all this testing to see if we can leave our car parked for 2 or 3 weeks? I do that all the time with five cars can't drive five . 1 everyday of week possibly. But mostly the other 4 on tenders just easier I've gotta 4 port tender ready w long cables for 4 vehicles the 4 I ain't driving. Seems to work ok .
  20. Tombukt2
    13,291
    2,398
    Tell us what is weird tho I gotta HV battery showing 176V won't start a 07 Prius with all else in car perfect no. Lights etc . Put it in another gen2 starts rt up.
