Mine plug up to the round d4s connector bulb goes on holder mine also have fans on this car. And in this 07 I did not bypass I can but did not because hid wer working . I just changed bulbs . And let my ole lady get back to her dashing. The 08nis same but bypassed . Same set of bulbs . Alla is no. Longer I think cannot find. Aux seems in same boat .
I'm beginning to believe that if your ballast goes bad 12 volt still passes through it or something along those lines . I put the one wires on a car the other day and 1 side was out bulb worked on other side . Applied d4s conversion bulbs both sides like new ...weird
Sale at DDM tuning Here's a set of fanless 35 watt DDM Tuning D4 LED's that use the HID connector on our prii and require a working ballast that are $78/pair Here's a 35 watt DDM D4 ballast for $45
Look carefully you'll find those for 50 bucks I was going to buy a set of those a few months ago when they first came out just the bulb itself no pigtail ford4 connector . 8 just bought the aux branded I've been buying awhile . They should be fine try it with you're fault ring ballast . I bet it ignites. Ut don't know for a fact
