Verification of EGR cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusKyle, Dec 5, 2025.
  1. Mendel Leisk
    41,484
    Googling this:
    How much carbon coating on egr cooler fins is needed to impact cooling ability
    the AI summary is interesting.
  2. indel
    indel Member
    119
    Northwest Indiana
    Is our primary concern, temperature or flow of the exhaust gases re-entering the intake manifold?
    priumium likes this.
  3. Mendel Leisk
    41,484
    Both? The cooler is quite the contraption.
  4. priumium
    priumium Member
    238
    58
    Sweden
    I generally agree, but since one version is so much easier (no vowel) and still delivers above 21 kPa flow, it’s still relevant.
    The cooler will look terrible even if brand new, after some hours of engine running. That does not really indicate a bad flow…
    I have still failed to see any validation data of actual flow thru this cooler. This is likely why Toyota prefers blowing it with pressured air, since it will indicate flow exist - if the back is removed (I did not remove the back of the cooler since those bolts require wiper/cowel removal. So much ash blew out in the front (use mask)).
    Why are the exhaust gases cooled? Likely engineering explanations are due to the manifold is plastic, the delta between normal airflow temperature (hundreds of degrees difference) is very big, and with g3 this was a new tech. How do newer EGR treat this..? This is like a beta/alpha version in my analysis.
    The trick to block the throughput at the pipe is very smart and is done by Toyota to separate the vibration issue (my plug-in had massive vibrations at 30-60 kmh when car was bought at 270.000km) from the lovely head gasket issue.
    #24 priumium, Dec 19, 2025 at 7:43 AM
  5. priumium
    priumium Member
    238
    58
    Sweden
    This is true, but the super small passages of the manifold are much worse in that regard (again, since they can have added oil. This does/should not exist in the cooler environment (normally)).
  6. Mendel Leisk
    41,484
    How many hours do you think? ;)
  7. priumium
    priumium Member
    238
    58
    Sweden
  8. priumium
    priumium Member
    238
    58
    Sweden
    I wish I had checked the non-continous EGR monitor flow value before cleaning, would have be interesting.
    My plug in 2013 had no codes or indication of issue in the ECU, but the engine behaved very bad with morning rattle and massive vibrations when engaged at all speeds. All gone.
    Cheers to @Mendel Leisk and priuschat alumni - and YT folks (merv et al) helping! (y)
    #28 priumium, Dec 19, 2025 at 7:58 AM
  9. ChapmanF
    18,226
    o_O I'm not sure what you're getting at here. The car does a flow test routinely, and you can query for the most recent result at any time.
    Has Toyota expressed such a preference? I didn't think they had said much about cleaning the thing at all.
    I don't think it was such a new tech really; cooled EGR was being researched industry-wide, and gen 3 was when Toyota got around to adding it to the Prius.
    Industry publications like this one suggest that volumetric efficiency was a main attraction:
    Gasoline engine exhaust gas recirculation – A review
    Hot EGR mixing with the intake air heats that too, decreasing its density, so you get even less of it into the cylinder per stroke; you'd need a bigger-displacement engine to get the same power as one with cooled EGR.
    That's what I take away from reading the abstract and section snippets of that paper; I might have access to the full text through my organization but haven't checked that yet.
  10. priumium
    priumium Member
    238
    58
    Sweden
    I work at that kind of organization. Here it is attached as PDF in full. Science should be public domain…
    European Union (Gasoline): EOBD (European On-Board Diagnostics), which monitors emission control systems including EGR, was made mandatory for all new gasoline vehicles sold in the EU starting in the 2001 model year.
    Fascinating Prius 1-2 avoided this due to the hybrid concept.
    ATTACHMENT Copyright © 2025 Elsevier B.V., its licensors, and contributors. All rights are reserved, including those for text and data mining, AI training, and similar technologies. For all open access content, the relevant licensing terms apply
    #30 priumium, Dec 19, 2025 at 10:35 AM
  11. priumium
    priumium Member
    238
    58
    Sweden
    As you recently stated, this flow is measured at the MAP sensor. There are many passages afore, so it’s not a measurement of actual cooler flow?
    That is, in an interpretation, an indication of Toyotas preference to ignore it as a culprit. But indirect knowledge via my Toyota source and TCCN indicates they instructed about blowing it out.
    True indeed, and also validates my point it’s a beta test for Toyota, as they were forced to introduce it and did it not ideally due to lack of experience.
    #31 priumium, Dec 19, 2025 at 10:50 AM
  12. Mendel Leisk
    41,484
    All Toyota had to do was run a few pre-production gen 3's around a track for 200k miles, and we wouldn't be where we are, with clogged EGR, blown head gaskets and runaway oil consumption (the latter largely due to to the low-tension piston rings they spec'd, till sometime in 2014 model year).
    Like any corporation, their public statements are VERY terse and guarded. There's no way they're going to recommend any sort of preemptive EGR cleaning; they'd rather turn their backs on the dumpster fire of blown head gaskets.
    What's the kilometers on yours? I seem to recall reading 270k kms somewhere, and it's a relatively recent acquisition?
