1. peterw
    peterw New Member
    los angeles
    2025 Prius Plug-in
    SE
    Previously, I have a 2011 prius for 10 year, and I know that use a 12v AGM battery.
    Recently, got a 2025 prius plug-in SE, by looking at the 12v battery, I am not sure it is a AGM type. It has six cap to add water (I unscrew one of them and just like a conventional 12v). So is it a AGM ?
    Gokhan likes this.
  2. Roy Peterson
    Roy Peterson Member
    99
    130
    Richland WA
    2024 Prius Prime
    That is not an AGM battery. Same battery that came in my 2024. It’s a Yuasa flooded lead acid battery. FYI, I replaced the OEM Yuasa with an AGM last year after the OEM battery went flat one day. AGM has worked very well in my car to date
    Cheers
    Keithstef2 and Gokhan like this.
  3. peterw
    peterw New Member
    los angeles
    2025 Prius Plug-in
    SE
    thanks, for more assurance. Although searching (include priuschat), still can have a sure answer, but seem that a flooded one to me too.
    The reason what to know is for a tickle charger setting.
  4. Mendel Leisk
    42,387
    5th gen batteries have the larger, North American sized posts?
    Googles AI is saying they’re still the Japanese Industrial Standard (skinny) posts. The pictured battery looks to have the larger NA posts. Maybe just my eyes, trying to install the cable clamps will confirm.
    #4 Mendel Leisk, Dec 20, 2025
    Gokhan likes this.
  5. peterw
    peterw New Member
    los angeles
    2025 Prius Plug-in
    SE
    Yes, indeed it is same size as the other car I have that use a flooded 51R battery
  6. Gokhan
    Gokhan Senior Member
    6,722
    2,672
    Paramount CA
    No, Gen 4/Gen 5 battery size is BCI 140R, which is a standard battery type, also known as DIN H4 and EN LN1. Only Gen 2 and Gen 3 use those weird Japanese batteries.
  7. Gokhan
    6,722
    2,672
    Paramount CA
    The OEM Gen 4/Gen 5 battery is definitely a flooded cell.
    If you go aftermarket, definitely go AGM, which is an upgrade. The Uplus BCI 140R/DIN H4/EN LN1 AGM battery on Amazon is very cheap.
    otatrant likes this.
  8. Mendel Leisk
    42,387
    I thought AGM was mostly needed due to battery being in the cabin, concerns about hydrogen venting and spillage (in a crash). What else about it is "superior", longevity?
    Still, puzzling: gen 4 had battery in engine bay, for first time, and battery was switched from AGM (used in Gen 2 and 3) to flooded-acid. Then it's back in the hatch in gen 5, but STILL flooded-acid.
    Gokhan likes this.
  9. Gokhan
    6,722
    2,672
    Paramount CA
    AGM batteries last longer and are more resistant to abuse and/or heavy-duty use. They have a higher CCA, too.
    In Gen 5, it has an exhaust tube attached to a side vent hole.
    The OEM Gen 5 battery is slightly different than the OEM Gen 4 battery in that it has side vent holes for exhaust-tube attachment. If you go aftermarket, they usually come with side vent holes and a plug for the unused vent hole, but check before you buy.
    Last but not least, AGM batteries vent, too, and make sure that they come with a side vent hole and a plug for the unused hole. They are known as centrally vent batteries. See the following thread for more info.
    AGM battery for Gen 4/Gen 5 Prius/Prius Prime and observations on the 12-V charging system | PriusChat
  10. Gokhan
    6,722
    2,672
    Paramount CA
    Incorrect. Gen 4/Gen 5 BCI size is 140R.
  11. VelvetFoot
    VelvetFoot Senior Member
    1,408
    547
    New York State
    2026 Prius
    So, @Gokhan , it's your observation that the Gen5 Prius can handle the switch from flooded to agm seamlessly?
  12. Mendel Leisk
    42,387
    If they have higher CCA it's by design. I'm out of depth, but I've heard it depends on the thickness and quantity of internal plates. Also, higher CCA comes at the price of lower AH (Amp Hours).
    FWIW the stock third gen battery is AGM, and it's CCA is (I believe) around 325. My tester asks for CCA value, and there was nothing on the battery label, but after a lot of rooting around on Yuasa website I "think" I found that value.
    Well ours has, an Optima Yellow Top, but it pretty much LIVES on a charger, in between uses of the car. I'm not sure as a whole that longevity is much different, if at all. It's hard to determine to, since every car owner imposes different conditions on the battery.
  13. Gokhan
    6,722
    2,672
    Paramount CA
    Yes. I think an AGM cell works better than a flooded cell, in fact.
    I have a Gen 4 prime, but Gen 4 and Gen 5 BMSs are practically identical. The only difference is that, in Gen 5 PHEV, the DC–DC converter turns on with voltage at 14.1 during active AC charging, whereas in Gen 4 PHEV, a sub DC–DC converter inside the charger is used to supply about 13.0 V during active AC charging, which keeps the battery at float but doesn’t charge it.
    VelvetFoot likes this.
  14. Gokhan
    6,722
    2,672
    Paramount CA
    AGM cells have thicker plates than flooded cells; so, they have a higher CCA.
    No, the capacity on my BCI 140R AGM is 50 Ah, whereas the one on the BCI 140R flooded cell Toyota OEM (GS Yuasa) is 45 Ah. So, AGM wins there, too, though not by a huge margin.
